Old 05-17-2015, 02:59 PM   #155
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I purchased the 3" CAI to go with my supercharger system. As I'd like to prep as much of the car before I get a shop to install, can I install the 3" CAI prior to my tune or should I wait until after the install and tune of my supercharger?
Chad86 is offline   Reply With Quote
Old 05-18-2015, 11:35 AM   #156
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Chad, you're going to need a tune to run the 3" intake. I'd wait on the install till when you're installing the supercharger, since you're going to have to take the bumper off anyway.
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Chad86 (05-18-2015)
Old 06-11-2015, 11:44 AM   #157
HaloFRS
Drives: 2020 Subaru BRZ Limited
I was going to ask a question about the hp gain differences on the 2.75 and the 3 CAI but found my answers here. http://blog.perrinperformance.com/3-...-dyno-results/
Now my only question is If I run lean with the 3" will it trigger CEL? MY car is 2 months old and as much as I would like a retune after an install I wouldn't like to risk my warranty. (Noobie here)
HaloFRS is offline   Reply With Quote
Old 06-11-2015, 11:51 AM   #158
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by HaloFRS View Post
I was going to ask a question about the hp gain differences on the 2.75 and the 3 CAI but found my answers here. Now my only question is If I run lean with the 3" will it trigger CEL? MY car is 2 months old and as much as I would like a retune after an install I wouldn't like to risk my warranty. (Noobie here)
YES, there is about a 30-40% difference in the MAF tables (between stock and perrin provided for 3"), your fuel trims will go into a range that triggers a CEL.
Decay107 is offline   Reply With Quote
Old 06-11-2015, 11:54 AM   #159
HaloFRS
Ugh. That's a bummer. I would love to get the 3" over the 2.75 and run lean til my warranty is done....
Old 06-11-2015, 11:57 AM   #160
Decay107
Decay107's Avatar
I assume that means you don't currently have a tune? If you do, the maf scale tables are really easy to edit and Perrin provides a new scale that is optimized for the 3" intake (they also have one for the 2.75, but it's not absolutely necessary)
Old 06-11-2015, 12:23 PM   #161
HaloFRS
Yes. Everything is stock since I just got the car. So if I just edit the MAF scales it wouldn't affect my warranty? Is there anyway the dealer would know if we flashed our ecu? Sorry for the noob questions. I'm just starting to get more into cars. Thanks btw.
Old 06-11-2015, 12:33 PM   #162
Decay107
Decay107's Avatar
The only way your warranty is 100% safe is if you keep everything stock and never do any trackdays/autocrosses. After that you end up in a grey area where you will need to know about the Magnuson–Moss warranty act and potentially be willing to escalate issues beyond your local dealer to the regional level.
Toyota cannot know if you have tuned your car, but they are able to see the total number of re-flashes on the ECU. OFT allows you to easily go back to stock tune, Ecutek permanently alters the factory programming to add in extra features.
Old 06-11-2015, 12:43 PM   #163
HaloFRS
I've talked to the dealership about it. And same as the Manuson-Moss warranty they said they are cool with basic like intake and exhaust and some minor bolt ons as long as it doesn't directly affect what is wrong with the car. I was just not sure about an ecu tune. So will they say anything if they see the number of reflashes? Doesn't the ecu count a reflash when you unplug the battery?
Old 06-11-2015, 12:54 PM   #164
Decay107
Decay107's Avatar
Don't believe so, never checked my flash count for changes after a battery disconnect specifically though. As with all warranty claims, it starts with the dealer service department. Some are open to mods others are not. Once you get into ECU tuning, the dealer service department has some pretty firm ground to deny warranty claims on most powertrain maladies, but again it all comes back to how cool your dealer is.
The Following User Says Thank You to Decay107 For This Useful Post:
HaloFRS (06-11-2015)
Old 06-11-2015, 01:36 PM   #165
HaloFRS
Unhappy
I guess im just gonna stick to the 2.75 and run lean for now.
Old 07-19-2015, 01:08 AM   #166
Dukerade
Drives: 2015 brz
I am wondering if i am required to disconnect the negative pole for the battery prior to installation.
Dukerade is offline   Reply With Quote
Old 07-19-2015, 01:33 AM   #167
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Required?
No
General good idea?
Yeah
Old 09-28-2015, 03:00 PM   #168
tracerit
Drives: '13 SSM BRZ Limited 6MT
Would the 3" version be louder than the 2.75" version? I love the sound of the CAI and as with any modification I'm afraid I won't notice much of a difference so this time I'm going to consider going going with the "better" version in hopes of making sure the difference is more noticeaBLE.
tracerit is offline   Reply With Quote
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 10:01 PM
Perrin Catback Exhaust Installation and Review! Sony Engine, Exhaust, Transmission 316 01-24-2016 01:01 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
