Old 06-09-2015, 08:45 PM   #1
CB762
CB762's Avatar
Drives: Scion FR-S
Wheel with spacers on a road course
It is rainy summer here, I may need to use wheels with spacers on the track.
Does anyone have a personal experience?
I've already searched on Google ... seems to be OK if properly mounted and torqued between sessions.
Thanks!
CB762 is offline   Reply With Quote
Old 06-09-2015, 08:51 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
while it may be okay, most track hosts will not allow you to run with bolt-on spacers.
Sandwich in general are better.
-alex
CB762 (06-09-2015)
Old 06-09-2015, 10:00 PM   #3
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
I ran on Oregon Raceway Park with bolt on spacers on my car. I'm mostly stock so I wasn't doing anything too crazy but they were fine. But like mav1178 said you should check and see if they allow them at your track.
sirbobbinhood is offline   Reply With Quote
The Following User Says Thank You to sirbobbinhood For This Useful Post:
CB762 (06-09-2015)
Old 06-10-2015, 01:56 AM   #4
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Spacer failure at Zwartkops Raceway South Africa about 2 weeks ago.
He was lucky to escape with such minor damage.
Fish Eagle is offline   Reply With Quote
Old 06-10-2015, 03:44 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Is there a reason for using spacers on the track?
Old 06-10-2015, 04:49 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
On track people might use them not for some flush looks, but simply to be able to clear their brakes with wheels they use (if it's some smaller one for less weight, that won't fit with brake kit used, unless spacers are used).
That pic intrigued me. First time seeing some failure because of spacers. Most of a time i've heard opinions that their usage is safe enough.
Old 06-10-2015, 09:12 AM   #7
CB762
CB762's Avatar
Drives: Scion FR-S
Precisely my case. OEM wheels with street tires won't clear AP racing brakes, don't have room for two sets (dry/rain) of track-only wheels inside. 100 miles to track, will use street tires if rains to standing water.
Old 06-10-2015, 12:02 PM   #8
gramicci101
Off Topic
What size spacers do you need to clear your brakes?
Old 06-10-2015, 12:25 PM   #9
wheelhaus
wheelhaus's Avatar
This seems relatively rare. Looks like the spacer itself is OK? Have any more pics or info? Has he had any offtrack incidents that could have overstressed some studs? Could have been an overtorqued or undertorqued stud, etc. I'd need more info before I point a finger at a specific component.
If someone wants to run bolt-on spacers (and your track allows it), I'd recommend sticking with 20mm or more to ensure there's substantial material under the spacer bolts, and only from a reputable brand that uses strong treated aluminum, not cheap, soft untreated stuff. If you need 15mm or less, I'd recommend longer studs and sandwich spacers. I tracked with 20/25mm spacers on the stock tires and didn't worry about it, especially because they get such little grip there's no way I could overstress anything. However with wide, grippy tires, that could be a different story, more heat, more strain...
Longer studs and sandwich spacers are the way to go for a good permanent, guaranteed safe solution with the fewest points of failure.
Old 06-10-2015, 12:42 PM   #10
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yeah, I could get a lot more info because I know him quite well, but I'm not going to because I don't want to in any way support the thought that "spacers might be OK if..."
IMO, anybody going onto a racetrack with spacers (any spacers, under any circumstances) must have rocks in the head. QED.
YMMV
Old 06-10-2015, 12:47 PM   #11
wheelhaus
wheelhaus's Avatar
YMMV
At the same time I don't want to spread unnecessary FUD because a few people have seen spacers break. Anything can break.
The Following User Says Thank You to wheelhaus For This Useful Post:
Fish Eagle (06-10-2015)
Old 06-10-2015, 01:05 PM   #12
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Who knows - somewhere between our different points of view lies the truth.
The Following User Says Thank You to Fish Eagle For This Useful Post:
wheelhaus (06-10-2015)
Old 06-10-2015, 01:10 PM   #13
mav1178
mav1178's Avatar
You should invest in longer studs to solve your problem.
I have this problem w/ running large brakes and no spare tire that will clear the caliper. I always keep one of my H&R 15mm spacers in my car so that in case I get a flat, I can put a spare on the front of the car without issue as I have ARP studs.
-alex
CB762 (06-10-2015)
Old 06-10-2015, 08:43 PM   #14
CB762
CB762's Avatar
Drives: Scion FR-S
-alex
I already have longer studs and quality steel long open end lug nuts.
Specer is 10mm sandwich type, Eibach brand. Another factor: if it rains then I won't be as aggressive as on slicks.
Thanks!
The Following User Says Thank You to CB762 For This Useful Post:
mav1178 (06-10-2015)
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
wheel spacers? rocketbunnyfrs86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 12-27-2014 01:03 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 02:35 AM
WTB: Wheel Spacers bhbnuckle Canada Classifieds 0 03-15-2014 01:37 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
