-   -   Wheel with spacers on a road course (https://www.ft86club.com/forums/showthread.php?t=89792)
CB762 06-09-2015 08:45 PM
It is rainy summer here, I may need to use wheels with spacers on the track.
Does anyone have a personal experience?
I've already searched on Google ... seems to be OK if properly mounted and torqued between sessions.
Thanks!
mav1178 06-09-2015 08:51 PM
while it may be okay, most track hosts will not allow you to run with bolt-on spacers.
Sandwich in general are better.
-alex
sirbobbinhood 06-09-2015 10:00 PM
I ran on Oregon Raceway Park with bolt on spacers on my car. I'm mostly stock so I wasn't doing anything too crazy but they were fine. But like mav1178 said you should check and see if they allow them at your track.
Fish Eagle 06-10-2015 01:56 AM
Spacer failure at Zwartkops Raceway South Africa about 2 weeks ago.
He was lucky to escape with such minor damage.
boredom.is.me 06-10-2015 03:44 AM
Is there a reason for using spacers on the track?
churchx 06-10-2015 04:49 AM
On track people might use them not for some flush looks, but simply to be able to clear their brakes with wheels they use (if it's some smaller one for less weight, that won't fit with brake kit used, unless spacers are used).
That pic intrigued me. First time seeing some failure because of spacers. Most of a time i've heard opinions that their usage is safe enough.
CB762 06-10-2015 09:12 AM
Precisely my case. OEM wheels with street tires won't clear AP racing brakes, don't have room for two sets (dry/rain) of track-only wheels inside. 100 miles to track, will use street tires if rains to standing water.
gramicci101 06-10-2015 12:02 PM
What size spacers do you need to clear your brakes?
wheelhaus 06-10-2015 12:25 PM
This seems relatively rare. Looks like the spacer itself is OK? Have any more pics or info? Has he had any offtrack incidents that could have overstressed some studs? Could have been an overtorqued or undertorqued stud, etc. I'd need more info before I point a finger at a specific component.
If someone wants to run bolt-on spacers (and your track allows it), I'd recommend sticking with 20mm or more to ensure there's substantial material under the spacer bolts, and only from a reputable brand that uses strong treated aluminum, not cheap, soft untreated stuff. If you need 15mm or less, I'd recommend longer studs and sandwich spacers. I tracked with 20/25mm spacers on the stock tires and didn't worry about it, especially because they get such little grip there's no way I could overstress anything. However with wide, grippy tires, that could be a different story, more heat, more strain...
Longer studs and sandwich spacers are the way to go for a good permanent, guaranteed safe solution with the fewest points of failure.
Fish Eagle 06-10-2015 12:42 PM
Yeah, I could get a lot more info because I know him quite well, but I'm not going to because I don't want to in any way support the thought that "spacers might be OK if..."
IMO, anybody going onto a racetrack with spacers (any spacers, under any circumstances) must have rocks in the head. QED.
YMMV
wheelhaus 06-10-2015 12:47 PM
YMMV
At the same time I don't want to spread unnecessary FUD because a few people have seen spacers break. Anything can break.
Fish Eagle 06-10-2015 01:05 PM
Who knows - somewhere between our different points of view lies the truth. :D
mav1178 06-10-2015 01:10 PM
You should invest in longer studs to solve your problem.
I have this problem w/ running large brakes and no spare tire that will clear the caliper. I always keep one of my H&R 15mm spacers in my car so that in case I get a flat, I can put a spare on the front of the car without issue as I have ARP studs.
-alex
CB762 06-10-2015 08:43 PM
-alex
I already have longer studs and quality steel long open end lug nuts.
Specer is 10mm sandwich type, Eibach brand. Another factor: if it rains then I won't be as aggressive as on slicks.
Thanks!
