Old 06-10-2015, 05:49 AM   #1
aslanteye
aslanteye's Avatar
Drives: 2014 base frs
Super vs turbo
Alright so I've been lurking on this sub forum for awhile now. I've been doing a ton of reading on what the best forced induction solution would be for my car.
I had thought I was going to settle on a supercharger because it was a simpler setup, would provide boost at lower rpm, and be easier overall for me to deal with since this is my first nice car.
But this past weekend I was talking with a friend about going with a super charger kit and he mentioned that he thought a turbo would be s better choice given that we have such a small engine.
I'd really appreciate your guys' thoughts on the matter. A little more background, this vehicle is my dd so reliability is the most important aspect, I'm honestly looking to get just a bit more torque, not a ton.
Sent from my SM-N910T using Tapatalk
aslanteye is offline   Reply With Quote
Old 06-10-2015, 05:56 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Header.
Old 06-10-2015, 06:16 AM   #3
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
It depends on what your looking to get out of the car. I see you say you just want the car to be a daily driver and your not looking for to much hp/tq increase.
If that's all your looking to do then, in my OPINION a supercharger would benefit you for your needs. It keeps your curves more "n/a feeling" wich for a daily driver would be nice.
As far as keeping it reliable, thats going to depend highly on your tune...no matter what forced induction you choose. Its been proven these engines can last quite some time with boost, but get a bad tune and it might not last the drive home from the dyno.
Now, I would also like to say that even though I gave my opinion that a supercharger would benefit your needs, I am in no way saying its a better choice then a turbo. With a small enough turbo you CAN achieve CLOSE to the same "instant boost" as a supercharger, however you'll always have that slight lag due to the need of exhuast gas pressure to spin your turbine as opposed to a pulley thats connected to the crank via a belt.
WHITE is offline   Reply With Quote
Old 06-10-2015, 09:39 AM   #4
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Ah, the good ol' SC vs turbo debate. I prefer a SC. As stated before, it gives instant power as soon as you step on the gas. While small turbos can spool fast, they will still not give you INSTANT power (but close to it). I'm not a peak HP kinda guy. I like steady, linear power that I can use to weave in and out of traffic and take off from a stop light without having to rev my engine to achieve boost. While the BRZ I bought the wife is not currently FI, if she wants more power after the warranty is up, I will end up installing a SC.
Both turbos and SCs are great. It really does depend on what you want out of the car and how you intend to drive it.
Helios is offline   Reply With Quote
The Following User Says Thank You to Helios For This Useful Post:
Dream20b (06-11-2015)
Old 06-10-2015, 11:06 AM   #5
bfrank1972
Drives: 2013 FR-S Argento
Nitrous
Old 06-10-2015, 11:16 AM   #6
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
lol...
dpgfunk is offline   Reply With Quote
Old 06-10-2015, 12:05 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Maybe the search function doesn't work on Crapatalk:
http://www.ft86club.com/forums/showt...ighlight=turbo
There are five threads just in the last year. If you want reliability and a bit more torque, not a ton. Then this is not the section for you. Go get yourself a nice header/exhaust setup and a good tune.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
cdrazic93 (06-10-2015), fika84 (06-11-2015), flippy (06-11-2015), shortcut (06-10-2015)
Old 06-10-2015, 12:25 PM   #8
gramicci101
Off Topic
You should stay away from FI then. By putting either a supercharger or a turbocharger on your engine you're completely voiding any portion of the warranty that the dealer can tie to the significant increase in power. So if your engine shits itself on the dyno (this has happened) or just driving down the street (also happened), then you're out a functional car. These cars seem to be reliable below 300 hp, but accidents happen.
The dealer will likely void your warranty for a header and tune as well, so you still need to consider what's more important to you. I stopped at a stage 1 reflash, because I like my warranty. They could still void it because of the reflash, but that's a lot harder to detect than a shiny new header. Once my warranty is up then I'll probably throw a header on there.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 06-10-2015, 02:14 PM   #9
The Feds
Government Issued
The Feds's Avatar
Drives: Unicycle
Maybe the search function doesn't work on Crapatalk:.
I know it doesnt work on my Samsung Galaxy Note II Which sucks!
The Feds is offline   Reply With Quote
Old 06-10-2015, 02:24 PM   #10
sw20kosh
Drives: 2013 Black FR-S
Header + FP + E85 done
Old 06-10-2015, 05:06 PM   #11
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
If you want low RPM power, don't get any of the centrifugal super chargers (JRSC, Kraftwerk, Vortech). You'll need something like the Cosworth kit or something similar.
Sleepless is offline   Reply With Quote
Old 06-10-2015, 05:29 PM   #12
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Do you like the feeling of a nice linear powerband that pulls right to the top? Centrifugal blower. Do you like the feeling of lots of torque in the mid range? Turbo. Do you want a bit of a mix that may fall off up top slightly? Roots style blower.
IMO.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-10-2015, 05:30 PM   #13
aslanteye
aslanteye's Avatar
Really really appreciate the replies guys.
Old 06-10-2015, 05:34 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Oh gawd an S/C vs turbo thread again?
The Following 5 Users Say Thank You to cdrazic93 For This Useful Post:
Calum (06-10-2015), Dream20b (06-11-2015), kbogarto (06-11-2015), STV3 (06-11-2015), Yoda (06-10-2015)
Super plus Turbo PLEASE MOVE TO FORCED INDUCTION Captain Snooze Forced Induction 2 01-24-2014 08:21 PM
Turbo+super firl21 Forced Induction 8 04-16-2013 12:51 PM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 11:13 AM
Turbo or Super Charger Ryan86 AFRICA 7 11-21-2012 09:14 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
