Old 06-09-2015, 02:37 AM   #2493
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Wayno View Post
Hey mate, I went around in circles for months changing that fueling additive table, until I read Td-d's description in the definition which states it's only active when IAM < 1.
I did not know that. The description in my def just states this:
This is the compensation to the open loop base fueling target based on load and engine speed. Other compensations (some undefined), are also applied.
Do you know whether it is blanket applied for IAM < 1 or increases, with a hidden multiplier perhaps, as IAM decreases?
@Td-d
.: Stealth 86 :.
Kodename 47 DJ:
Wayno (06-09-2015)
Old 06-09-2015, 02:43 AM   #2494
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
@Td-d
Ah, that's because the description is on the Primary Open Loop Fueling Base table
<description>This fuel map is used in open loop when the ignition advance multiplier (IAM) is equal to 1.0. When the IAM is less than 1.0, this fuel map is used as a base and the 'Primary Open Loop Fueling Additive' enrichment map is added to determine the final primary open loop fueling. An estimated AFR for this final fueling can be calculated as follows: 14.7/(((14.7/(Base AFR map value)) + (Additive map value * (1.0 - current IAM))). For example, if the 'Primary Open Loop Fueling Base' calls for an effective AFR of 10.5:1 and the 'Primary Open Loop Fueling Additive' map calls for 0.10 enrichment offset compensation and the current IAM is 0.75, then the final primary ol fueling would have an estimated AFR of 10.3:1.</description>
But yeah, I was adding to that sucker for months and my AFR would still spike at the location I thought I was adding fuel.
The Following User Says Thank You to Wayno For This Useful Post:
NicFromTheNorth (05-08-2021)
Old 06-09-2015, 02:44 AM   #2495
Kodename47
Kodename47's Avatar
Drives: UK GT86
guess would be its like base timing tables A safe mode B normal
There are a few tables that have A and B. I doubt it's a normal and safe type. From what others have said it may be that they are independently looked at during different routines, or even both are used similar to the closed loop fueling tables. Similar to the fact there is multiple MAP sensor scaling. My general consensus would be to just make sure they are the same.
.: Stealth 86 :.
Kodename 47 DJ:
steve99 (06-09-2015)
Old 06-09-2015, 04:20 AM   #2496
steve99
Drives: FT86
quite possible ,agree if they are both the same originally then keep them both the same is safest option
Old 06-09-2015, 09:38 AM   #2497
Wayno
Wayno's Avatar
Made some more progress, of sorts.
Before:
http://datazap.me/u/wayne/206-stg2-u...1023-1039-1063
After:
http://datazap.me/u/wayne/v63-2-pull...3103-3129-3028
It's not spiking lean between 2400-3000 after the high load, instead going rich.
Instead of adjusting the maf @2.97V which will effect CL and OL at light throttle, I think I'll set the load limiter to 1.15 or so and see if it leans it up.
Also getting this weird rpm drop a second after WOT sometimes which could be due to the low timing in the high load cells.
http://datazap.me/u/wayne/v63-2-pull...54-681-700-721
I might try to fix the high load at low rpm by adjusting the throttle instead so prevent all this from happening all together. Or rescale the Load limit tables so the last cell is 4000 rpm instead of 3200.
Old 06-09-2015, 12:32 PM   #2498
Wayno
Wayno's Avatar
I re-scaled the load limit tables and made them my total bitch!
Ignore the lean AFR, it's with literally 10min of learning time.
Before:
http://datazap.me/u/wayne/206-stg2-u...zoom=1225-1433
After:
http://datazap.me/u/wayne/v64-1?log=...zoom=4459-4716
Just need to extend the 1.10 limit closer to 4000 I think.
ztan (06-09-2015)
Old 06-09-2015, 01:26 PM   #2499
Wayno
Wayno's Avatar
Should do the trick.
Old 06-09-2015, 04:57 PM   #2500
ztan
Drives: Toyota 86
v65?
After 3 in the morning?
Respect.
Let us know how this goes. My suspicion is when the torque converter is engaging initially, there is a bit of slippage that leads to erratic, erroneous load values being sent to the ECU and taking the engine rich.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
Wayno (06-09-2015)
Old 06-09-2015, 09:02 PM   #2501
steve99
Drives: FT86
@phrosty you might want to have a look at what @Wayno is doing here (few posts above) with load limits ect might help with your rpm dip issue with auto transmissions on E85
phrosty (06-09-2015)
Old 06-09-2015, 11:17 PM   #2502
Wayno
Wayno's Avatar
I haven't fully tested these yet, but they are a bare minimum for all AT's running the OFT tune as I haven't ever seen one that doesn't have these issues. It's pretty obvious openflash never had an AT with E85 on a dyno.
The load limiter is different between petrol and E85, though I won't have a chance to test the petrol one, I'm confident it will be an improvement between 3000-4000rpm.
Also, because of this, my OL MAF scale now more closely matches the likes of @steve99's MT scale, which is a great indicator.
3.20V = 66 (-6.00%)
3.44V = 86.5 (-0.94%)
3.71V = 110.80 (-1.57%)
3.91V = 130.44 (-3.20%)
4.06V = 148.68 (-3.20%)
4.30V = 177.80 (-3.20%)
4.49V = 206.87 (-3.20%)
4.73V = 246.00 (-3.20%)
5.00V = 304.80 (-3.20%)
The CL portion is the Stg2 petrol scale.
Old 06-09-2015, 11:37 PM   #2503
D_Thissen
D_Thissen's Avatar
Just picked up my OFT today. I flashed the car in the driveway and had a quick question. Are there preloaded Stg 1 91 and 93 tunes on the tablet? Or do I have to use OFM to load those onto the tablet?
Old 06-10-2015, 12:44 AM   #2504
steve99
Drives: FT86
pretty sure the preloaed stuff is 93 tunes.
to be certian just load up the required v2.06x tunes via ofm
Old 06-10-2015, 01:28 AM   #2505
D_Thissen
D_Thissen's Avatar
Thanks Steve. Just did that but in step 2, they both have the same name once you select them in ofm. I think they both say "Stage1AO1C.bin'
Sorry for my newbness
Old 06-10-2015, 01:45 AM   #2506
steve99
Drives: FT86
They will be in different folders from memory
D_Thissen (06-11-2015)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
