Old 06-08-2015, 09:59 PM   #1
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
Rough Idle, Cel, Skid light...
Well after doing a ton of research on this forum I cant find anyone with the same Issues/codes I am getting. I do see alot of posts related to Rough Idle, skid light, shaking, etc. But all those posts have a CEL of p0016-p0019.
Car currently has around 43,000 miles, Only engine related mods are Blitz intake, ARK exhaust, and catch can. Intake and catchcan have been on for almost 2 years, exhaust about 5 months.
Car started to idle rough a few days ago, RPMSs dropped to below 400 and would stall I did not rev it. Also when i came to a stop the DRL's would turn off and on. CEL came on and at time the skid light would light up and stay on. Also cant use the cruise control, "assumed that was just a precaution of the CEL"
Took it to the dealer today and the codes they pulled are
P0172 Bank 1 rich code
P1170 Fuel performance port injector
P1178 Fuel performance direct injector cooler
P1604 Start ability malfunction
Tomorrow I will try reverting intake setup back to stock and do a battery disconnect / clear codes with torque.
Anyone have any opinions on the the problem?
Freeze2196 is offline   Reply With Quote
Old 06-09-2015, 02:00 AM   #2
steve99
Drives: FT86
Sounds like intake ,catchcan air leak or exhaust leak near or prior to o2 sensors.
stuffed 02 or maf sensor
dirty maf sensor
Freeze2196 (06-09-2015)
Old 06-09-2015, 11:58 PM   #3
Freeze2196
Freeze2196's Avatar
dirty maf sensor
Thanks for the info steve99.
I removed the catch can, and reverted intake back to stock. After clearing the codes the rough idle is almost gone. Was only able to put about 80 miles on it today, no CEL as of yet.
Need Advice on Chirps and rough idle Jake_86 Scion FR-S / Toyota 86 GT86 General Forum 23 01-30-2015 02:32 PM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
CEL, Skid Light, Rough Idle ... SherbFrs Issues | Warranty | Recalls / TSB 8 07-18-2013 06:43 PM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
