CANADA Canada
Old 06-02-2015, 07:52 PM   #43
Skurj
Drives: SOLD...
iGarage quoted me what I consider a good price for install... I just emailed em Sunday and had my quote Monday morning.
I just have to find the money to buy the kit now...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 06-08-2015, 09:13 AM   #44
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@Skurj jrp has stock of mishimoto coolers usually
Sent from my SGH-I317M using Tapatalk
1Cor10:23 is offline   Reply With Quote
Old 06-08-2015, 09:31 PM   #45
1Cor10:23
1Cor10:23's Avatar
@RFB do you still get any minor seepage of oil? I have a tiny bit coming through right between the sandwich plate and the lower spacer
@Mishimoto
Old 06-09-2015, 10:42 AM   #46
RFB
RFB's Avatar
Drives: FRS
YUP
@Mishimoto
I did, a lot !
Deep socket 40 sumthin, re-tightened, all is well, and still good after a full day at Mosport big track, and Shannonville full track.
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Skurj (06-19-2015)
Old 06-09-2015, 11:09 AM   #47
1Cor10:23
1Cor10:23's Avatar
@RFB yeah mine did well at track but I think heat cycle must have loosened things. After drive back from Shannonville, checked plate day after noticed a tiny bit seeping through. Retorqued to 30 (digital reader said it was at 20 ft lbs after tracking, when it was installed at 30).
Do you mean you torqued it to 40?
Thanks!
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Skurj (06-19-2015)
Old 06-19-2015, 06:32 PM   #48
Skurj
Drives: SOLD...
Got mine installed yesterday and yup I have the seepage as well. Going back for a retorque early next week (iGarage)
Paid for Mar 2018
Old 06-20-2015, 08:24 AM   #49
RFB
RFB's Avatar
Drives: FRS
Thanks!
Meant socket size , but it felt like we ended up torqueing to 140 !
Old 06-22-2015, 06:41 PM   #50
Skurj
Drives: SOLD...
Well just got back from the shop after they checked everything over and reinstalled the sandwich plate etc, and it still leaks..
Maybe time to take it up with Mishi..
Pending their response I may pull the filter myself and check the torque.. First visit to CTMP GP track July 4,5 I don't wish to run this thing as is... it either stops leaking or its pulled before then.
Paid for Mar 2018
Old 06-23-2015, 05:10 PM   #51
Skurj
Drives: SOLD...
I let the car sit since yesterday and just pulled the filter and re-torqued the big nut, I was surprised how much it took, over 1/4 turn. Maybe installing these things while the car has any significant amount of heat in it is a waste of time..
Hoping I am closer.. if it still leaks after this, I'll try taking it to 35-40
Sent an email and a pm to Mishimoto, but no response yet.
Paid for Mar 2018
Old 06-23-2015, 08:34 PM   #52
1Cor10:23
1Cor10:23's Avatar
@Skurj don't go anymore than 35. Notice that there's a gap between the oil catch and the sandwich plate? Over torque and the oil catch will collapse since its just aluminum. That's what happened to me first time. Check that oil isn't coming from banjos - that was my most recent issue, just got replacement ones.
Old 06-23-2015, 08:35 PM   #53
1Cor10:23
1Cor10:23's Avatar
I should clarify that I only went to 30 ft lbs when I installed and it collapsed - must have had a lemon.
Edit: whoops I quoted myself. No point on changing
Old 06-24-2015, 02:51 AM   #54
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Does anyone know what torque settings Subaru uses when they install the OEM plate on their turbo motors? From what I have found it looks like it should be 39-40 lbs.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 12:30 PM
Perrin Oil Cooler Install & Snorkel Mod BC-Boy Engine, Exhaust, Transmission 4 05-14-2014 11:06 AM
Help! Oil Cooler Install brillo Tracking / Autocross / HPDE / Drifting 13 07-17-2013 04:55 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 10:41 PM
Any Portlanders bored tonight? Help install oil cooler? stockysnail Northwest 2 03-14-2013 12:15 AM
