Doborder, Moto-P, orthojoe
Old 03-22-2015, 09:25 PM   #141
wired
Drives: Scion FR-S 2015
Originally Posted by Moto-P View Post
I've sampled Cusco Street, RS*R Sports-i, and both of them were extremely well behaved and designed for medium grip to high grip tires. Both worked really well at FULL SOFT setting on both ends, even with track radials like the Azenis RT615K. So going stiffer is only needed perhaps, to compensate for wear of the dampers, and also to settle the car at really high speed tracks where stability is in order over quick vector changes.
Both do come at a price of nearly $2000 but with the ability to be 30mm lower, and unlike lowering springs on stock shocks, that allow maybe 20mm max on short rear shocks of the FRS/BRZ, the fully-tapped coilovers can go a full 35mm lower with all of the original stroke range, and has adjustability to actually make the ride more comfortable with more sophisticated valving that is not cost-constrained like the stock shocks.
So if budget is the key, Racecomp's 20mm drop springs are really ideal.
If ride qualities of the stock is a bit harsh for you, you can use either of the more expensive setup to improve that while retaining all the of the nice handling capability with much lower height around 30~35mm drop.
I've also found that 20mm drop is ideal for dynamic alignment (as designed), and 35mm still retaining pretty good alignment as well.
I'm reviving this thread because I really need some suspension advice and this post seems to hit the nail to the head.
I'm a fairly new 2015 FR-S owner in CA - 1200 miles.
Coming from Greece, I used to drive a 9yo RX-8. Surprisingly, the Greek roads felt a lot smoother w/ the RX-8 than the South Bay CA roads feel w/ my new FR-S.
Now, there are a lot of differences between the two cars, so it's not a fair comparison, but for public road driving in CA I feel the FR-S suspension is a bit too stiff. I'm pretty sure that in a race track with decent asphalt the FR-S will shine, but I haven't been to one yet (was patiently waiting for the 1k mile mark).
Unfortunately on typical public roads around here it feels that the car struggles a lot to stay level - I test drove the car 3 times and didn't notice. The moment I did tho, after buying it, it was like my eyes were opened and I can't stop noticing it anymore. Things get even worse on mountain roads where asphalt quality sucks even more.
Will the more expensive setups help fix this feeling without ruining my future track experience?
Thanks
wired is offline   Reply With Quote
Old 03-22-2015, 11:32 PM   #142
SilverFRS
Drives: Silver FRS
You may want to check out this thread:
http://www.ft86club.com/forums/showthread.php?t=69248
I have owned first and third gen MR2 and 98 M3, the FRS has a less controlled or comfortable ride than any of them over less than ideal roads. My MR2 spyder feels more composed over tight low speed roads than the FRS, roads that I did not consider bumpy until I owned this car.
SilverFRS is offline   Reply With Quote
The Following User Says Thank You to SilverFRS For This Useful Post:
wired (03-25-2015)
Old 03-23-2015, 03:54 AM   #143
wired
Thanks, this was a very useful link. I've commented there and will probably try out a few of the things mentioned in that thread.
Old 03-25-2015, 09:47 PM   #144
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
Why isn't this a sticky?
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold)
2001 BMW 325ci 5MT (sold)
1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold)
Stewie is offline   Reply With Quote
Old 05-26-2015, 02:18 AM   #145
Trackrat86
Drives: 2014 Scion FR-S
I recently had TRD springs put on my 2014 FR-S, I believe they lower the car 1 inch if I remember correctly. Have I unknowingly compromised the handling capability of the car if I change springs only? I also planned down the road to get lighter wheels and the Sprint BBK for weight savings and tracking the car. I was planning on using the OEM tires because I like them. Are there negative effects to the suspension due to the drop and reduction in weight??? I honestly did not consider this until reading this thread
Trackrat86 is offline   Reply With Quote
Old 05-26-2015, 02:46 AM   #146
troek
troek's Avatar
Drives: 2012 Toyota 86
I think you'll be fine, i put my best lap time down ever on rsr lowering springs and stock shocks. i have hks coilovers now, and while the car performs better at high speeds on bumpy surfaces for sure, on a smooth race track stock shocks and springs worked great for me.
troek is offline   Reply With Quote
Old 05-26-2015, 07:18 PM   #147
Trackrat86
Thanks
Thanks for the info.. Happy motoring
Old 06-06-2015, 05:33 PM   #148
bilsteinmotorsport K
Drives: Subaru Brz 2015 manual
well , im running bilstein B6 shocks with racecomp lowering spring . handling is just perfect and the car is comfort as well .
bilsteinmotorsport K is offline   Reply With Quote
The Following 2 Users Say Thank You to bilsteinmotorsport K For This Useful Post:
Marrk (06-06-2015), Racecomp Engineering (06-07-2015)
Old 06-09-2015, 11:49 AM   #149
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Why B6 and not B8 if you have lowering springs?
MGPAX is offline   Reply With Quote
Old 06-09-2015, 06:11 PM   #150
well . you are right ... why not B8 !!! i should install the B8 because travel is lower than B6 and works better with lowering springs .
will swap them soon to PSS10 kit
but absolutely B8 is better when u have lowering springs . B6 for oem springs
Old 11-09-2015, 05:00 PM   #151
tofumania
Drives: Frs red
I have koni yellow full strut replacement, and eibach sportline. i have the whiteline crash bolts in the front at -1 degree, and whiteline rear control arms, at 0 degrees. i was thinking of getting the car realigned with -2 in the front and -1 in the rear. Is this a good setup? the car is alittle lower the the 20-30 mm mark and is more like 34 mm. is this bad? should i get a front swaybar? the car to my knowledge still handles good, the rear looses grip a little more abruptly the stock.
tofumania is offline   Reply With Quote
Old 11-09-2015, 10:11 PM   #152
0 camber in the rear is not good...even -1 is not enough IMO.
-2 front -1.5 rear should be fine for you. 0 toe front and a tiny bit of rear toe in.
IMO those springs are lower than ideal for handling and ride quality but fix the alignment first and see what you think.
- Andrew
BAOVAN (12-22-2016), sam69 (02-07-2016)
Old 11-12-2015, 03:17 AM   #153
Brayden_23
Drives: Asphalt 2015 FRS
Subscribed!
Lots of great information in this thread. I am going to get Rays 57extremes 18x8.5 square set up with 235/40 tires and wanted to upgrade springs at the same time. Looks like it's between RCE Yellows, Tein H techs, or RSR Super downs. I'm only looking for a small drop while maintaining the playfulness of the current ride. I also want to avoid tire rub and dropping it too low where I have to worry about making it over bumps. These options seem like the best ones to go with for what I'm looking for (DD with occasional spirited driving on backroads). Anybody have anything to say about the above listed springs as to which ones I should go for? Want to maintain the oversteer as close to stock as possible.
TIA!
Brayden_23 is offline   Reply With Quote
Old 02-06-2016, 05:56 PM   #154
afishl1
Drives: Raven FRS MT
Any tire recommendations for Rsr Sport-i, lowest height and softest setting with camber, stock wheels, so-cal weather, not track driven, occasionally hard street driven.
afishl1 is offline   Reply With Quote
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 10:11 PM
Lower car 1.5 - 2.0 inches F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-23-2012 09:30 PM
BRZ spotted in lower mainland! kidgogeta CANADA 21 04-29-2012 02:20 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
