Old 05-15-2014, 09:44 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Motive Power Bleeder, which one?
Motive power bleeder has a lot of part numbers to fit different vehicles.
Anyone know which one I need to fit the BRZ? I guess the WRX one would fit, please help.
Old 05-15-2014, 09:57 AM   #2
OrbitalEllipses
Drives: Attitude
Ford/Import #1107.
We have several threads where this has been discussed. You're bad and should feel bad, but at least you'll bleed your brakes faster.
ZionsWrath (05-15-2014)
Old 05-15-2014, 10:11 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Ford/Import #1107.
Thanks man, but do you know the full kit that includes that attachment? The 1107 part does not include the actual power bleeder.
For example: http://www.summitracing.com/parts/mvp-0252/overview/
Old 05-15-2014, 10:36 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
The kit is #0107
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Old 05-15-2014, 11:26 AM   #5
OrbitalEllipses
Drives: Attitude
^that.
Old 06-04-2015, 12:20 PM   #6
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
There is also a 0117 kit. It has a metal cap versus the plastic cap. I've emailed Motive regarding the differences and the metal cap unit is supposed to be better and if you plan to bleed more frequently then occasionally, it's the way to go.
Myself, we have a track car and hope to be adding a second to the stable soon. We try to bleed brakes after each track day and will do a full flush once a year (at least). I'm leaning towards the 0117.
G_Rossney is offline   Reply With Quote
Old 06-06-2015, 03:18 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
I have the "non black" one. Is perfect. Used it almost a dozen times now. Paid for itself after one use. Everyone should own one.
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-15-2022 11:38 PM
Brake Bleeder Hose? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-20-2017 11:44 AM
Motive Power Bleeder THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 09-25-2017 11:13 PM
FS: Motive 1107 Brake Bleeder Adapter xman11 Brakes, Suspension, Chassis 5 09-19-2013 09:15 PM
Motive Brake Bleeder Adapter xman11 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-23-2013 10:24 AM
