Old 06-02-2015, 09:33 AM   #15
xxscaxx
Drives: 2013 SWP BRZ
Yep was going to say, upgrade the BOV spring.
Just for reference, ill be using the Boomba Check valve for my setup.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
drambo136 (06-02-2015)
Old 06-06-2015, 11:39 AM   #16
ft86me
ft86me's Avatar
Drives: 2013 FRS
Hmm interesting. I have the catch cans here and haven't put them on yet but I can say that my idle is nice and strong w a 8psi spring w my bov being on the ic passenger side. I'll report back after the catch can install.
What kind of idling symptoms ? Stock injectors ?
ft86me is offline   Reply With Quote
Old 06-06-2015, 12:29 PM   #17
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Idle fluctuates any were from 2000 to 0 rpms. My bov is on the intake pipe so I'm assuming its that. I have a yellow spring on the way. I have DW 700cc injectors
drambo136 is offline   Reply With Quote
Old 06-06-2015, 01:15 PM   #18
ft86me
ft86me's Avatar
Drives: 2013 FRS
Idling issue happened only after the catch can install? Any issues before w the injectors in?
Old 06-06-2015, 01:21 PM   #19
drambo136
drambo136's Avatar
I disconnected the ccs the other day to see if it would idle but no luck. I put the injectors in with the turbo so I can't comment on whether or not its that. My tuner said it wouldn't be that tho. I guess he can see that they r working.
If u haven't noticed I'm pretty new to tuning and fi
Old 06-06-2015, 01:26 PM   #20
ft86me
ft86me's Avatar
Drives: 2013 FRS
So disconnecting the catch can didn't help with idle.
Have you driven the car for idling issues? For example if you rev to 3 k and let the idle come back down will it die and or if you're driving and push in the clutch at 3k and coast to a stop the engine will die ?
Old 06-06-2015, 01:29 PM   #21
drambo136
drambo136's Avatar
Yes if the car is warm and I let the rpms drop to idle anytime it'll stall
Old 06-06-2015, 07:19 PM   #22
ft86me
ft86me's Avatar
Drives: 2013 FRS
alright. can you open ecutek and take a look at your short term trims after it's warmed up and you're idling?
Old 06-06-2015, 08:36 PM   #23
drambo136
drambo136's Avatar
It fluctuates anywhere from -0.8 to 5.5
Old 06-07-2015, 06:13 PM   #24
drambo136
drambo136's Avatar
Idk if this can help diagnose the problem, but heres a log i did yesterday. It has a couple 2nd and 3rd gear pulls. Please keep in mind that I need a new clutch(it's waiting to be installed).
http://www.datazap.me/u/drambo136/jd...og=0&data=6-30
Old 06-09-2015, 06:56 PM   #25
drambo136
drambo136's Avatar
Ok im annoyed. I replaced the bov spring with a yellow one today and at first it swwmed fine, but then it started to stall again and I got the same code again.....fml
Old 06-10-2015, 11:06 AM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Are you logging with EcuTek? If the MAF is staying closed at idle now, then it is something else and could be your tune.
Old 12-23-2015, 09:28 AM   #27
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Did you ever get resolution to this problem? I have the same symptoms at times.
xkalelx is offline   Reply With Quote
Old 12-23-2015, 10:47 AM   #28
FRS Justin
Drives: 2013 Asphalt FRS
Ok so I have a tial q bov that stays open at idle but its before the maf. That tuner says its fine. And what vvt parameter should I check
First off you need to fix the BOV it should only be open when relieving boost. Change the spring until it remains closed at idle. Under boost it will remain closed from the boost pressure on top of the spring, when you left off the gas it will open because the pressure will be greater on the other side of the BOV. That has to be done first, to fix idle quality.
Then hook up the catch can as the instructions say on the passenger side. On the drivers side let the catch can vent to atmosphere. If you try to use the turbo inlet as a source of vacuum it will pull oil out of the motor and into the turbo. PM me if you have further questions. I use dual Radium Catch cans.
Where is your BOV getting its vacuum source from?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (08-30-2016)
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
FS: Radium Universal Catch Can - BRZ/FR-S Setup F1point4 Engine, Exhaust, Bolt-Ons 8 04-09-2015 01:08 PM
Radium Catch Can - $150 - SOLD TemeCal Engine, Exhaust, Bolt-Ons 2 02-04-2015 09:59 PM
Parting out car - Radium Catch Can, XM Receiver and more TemeCal Engine, Exhaust, Bolt-Ons 59 01-28-2015 04:49 PM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 12:36 AM
