Old 06-06-2015, 09:39 AM   #239
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
If next gen RX is based off the ND then expect it to be around the weight of the FR-S. If the next RX7 comes with a turbo rotary(295hp/280tq) plus weigh 2750-2800lbs and cost 30-32k it will be the best sports car under 60k in my honest opinion. I think if this happens an 86 turbo will come after.
SUB-FT86 is offline   Reply With Quote
The Following User Says Thank You to SUB-FT86 For This Useful Post:
strat61caster (06-07-2015)
Old 06-06-2015, 10:21 AM   #240
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
A new production rotary car AND a factory turbo twin?
The Following 5 Users Say Thank You to themadscientist For This Useful Post:
DAEMANO (06-06-2015), drewbot (06-06-2015), Rampage (06-06-2015), strat61caster (06-07-2015), tahdizzle (06-08-2015)
Old 06-06-2015, 10:34 AM   #241
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Sideways&Smiling View Post
Really? Sources? I've always seen the RX7 and S2K listed as 50/50.
S2000 brochure had it 49F/51R, and that's what mine weighed in at with me in it and 1/2 - 3/4 tank of fuel at New Hampshire Motor Speedway. Also: http://media.caranddriver.com/files/...ers-vitals.pdf
I've seen multiple tests that showed 48/52 for the FD, probably with a 3/4 to full 20 gallon tank and driver. Here is one: http://www.fd3s.net/magazine_article...article02.html
Old 06-06-2015, 10:39 AM   #242
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
I think the Miata is cross-shoppable with the Twins as they are both fun track cars that can be used as daily drivers. For me personally, I'm not a convertible guy so wouldn't buy a Miata. I also needed four seats (however small lol) for kiddos.
STR also-ran
TRACE_on is offline   Reply With Quote
Old 06-06-2015, 10:47 AM   #243
themadscientist
Hotlink Terrorist
Sorry, but the back seats in the twins are only usable for people with no legs.
Old 06-06-2015, 10:51 AM   #244
DAEMANO
Time Traveller
I've put people (mostly women under 5'7"ish ) back there on short lunch type trips many times. All you have to do is slide the front seats forward. Its roomier than it looks especially on the passenger side..
Old 06-06-2015, 12:41 PM   #245
thill
Yes and when you move the front seat forward the wheel is in your chest and your face is against the glass.
Old 06-06-2015, 02:11 PM   #246
abraxis
Drives: many
Originally Posted by fatoni View Post
those same people should realize that having double the cylinders means you need bigger brakes, wheels, tires, drivetrain, chassis etc.
No it doesn't. You could have a 2.4L V8 or 2.0L 6-banger. Think you mean displacement.
I think that's an oversimplification that misses the point. A Camaro and Challenger don't weigh 4000lbs because of the power. Corvettes had the same or more power pushing 3100lbs. It's just being cheap. Cheap steel weighs more. Period.
abraxis is offline   Reply With Quote
The Following User Says Thank You to abraxis For This Useful Post:
Old 06-06-2015, 02:14 PM   #247
abraxis
Drives: many
You have something against disabled people?
Old 06-06-2015, 03:47 PM   #248
fatoni
it doesnt miss the point. are you trying to say that if the 370z was 80k and 800 lbs lighter it would be a better comparison to a twin?
Drive upgrades. Don't buy them.
Old 06-06-2015, 05:10 PM   #249
themadscientist
Hotlink Terrorist
Hey, that's "differently-abled" there, wingnut.
Old 06-07-2015, 02:22 AM   #250
abraxis
Drives: many
Bizzare thought process you have there. At least you acknowledge cars aren't heavy just because they make more power or have bigger engines.
Okay, I'll play along with the bad logic. Are you saying if the 86 had a 3.5L V6 making 270hp it would have to weigh 700lbs more like a Nissan?? Obviously then, if the 86 made 400hp it would have to weigh 1000lbs more like a Chevy. Put like 250lb rotors on each corner to stop that beast!! Oh wait, higher performance brakes can usually be lighter. Maybe you need like three 350lb offensive linemen strapped in the back to keep the car from flying off into space with all that powah!
The Following 2 Users Say Thank You to abraxis For This Useful Post:
DAEMANO (06-07-2015), Jaden (06-07-2015)
Old 06-07-2015, 02:29 AM   #251
fatoni
Okay, I'll play along with the bad logic. Are you saying if the 86 had a 3.5L V6 making 270hp it would have to weigh 700lbs more like a Nissan?? Obviously then, if the 86 made 400hp it would have to weigh 1000lbs more like a Chevy. Put like 250lb rotors on each corner to stop that beast!! Oh wait, high performance brakes are usually lighter. Maybe you need like 3 NFL offensive linemen strapped in the back to keep the car from flying with all that powah!
a bit of a stretch. im not saying that you just add more weight because you have more power. its okay to put words in my mouth. im not saying cars are heavy just because they make more power.
Old 06-07-2015, 05:04 AM   #252
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Please stop.
Ok.
ineedyourdiddly
4th gen ND Mazda MX-5 Miata Dark Other Vehicles & General Automotive Discussions 1392 12-16-2021 01:09 PM
Twins vs 2016 Miata (ND body style) will be revealed in 15 minutes glamcem FR-S / BRZ vs.... 56 09-13-2014 06:11 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 08:41 PM
Motor Trend Car of the Year... Dorb BRZ First-Gen (2012+) — General Topics 1 11-13-2012 07:33 AM
