Old 09-13-2014, 11:44 PM   #57
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by SkAsphalt View Post
So, for everyone who has done this, do you have to take apart the centre console? or can you just pull the pin and disconnect the shifter from below like @Supermassive supposes you could? I am doing this tomorrow.
Thanks guys! (shouting out to these knowledgable fellows below) @alpine @Sportsguy83 @king_tut @NickFRS @gdrider77 @protpibe
If you just remove the pin for the shifter itself from underneath and then remove the two pins holding the shift tower to the trans, you don't have to touch the interior of the car.
The Following 6 Users Say Thank You to Dipstik-sportech For This Useful Post:
H1C (10-23-2018), Respect BRZ (04-08-2016), SkAsphalt (09-14-2014), Sportsguy83 (09-14-2014), sroby (11-24-2020), thriller (12-01-2018)
Old 09-14-2014, 08:41 AM   #58
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I thought there had to be a way to leave the shift tower in there intact but had never explored it. That is awesome and thanks.
Old 09-14-2014, 07:47 PM   #59
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Well we did the clutch install today, took just under 2 hours..
Yes..under 2 hours. The joys of a lift and two very friendly mechanics (my dad and his friend.. watching 50+ year old best friends working together on a car is great)
Now to break her in nicely. Bye bye terrible chatter from the stock clutch springs.
Regarding the shifter removal, it takes like 30 minutes or less..so it was worth doing it to be sure.
Thanks everyone with the advice! Great thread here.
The Following User Says Thank You to SkAsphalt For This Useful Post:
sroby (11-24-2020)
Old 09-15-2014, 01:52 PM   #60
Bent42
Bent42's Avatar
Huge thanks for the tutorial! Did it on my back by myself in 4.5 hours start to finish. Thanks again!
Bent42 is offline   Reply With Quote
Old 09-15-2014, 02:11 PM   #61
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
^^ This guy. Awesome work. Nicely done man!
Old 11-28-2014, 11:10 AM   #62
bren5279
Drives: series.blurrr
Originally Posted by marcoaferrer View Post
DO NOT F**K WITH THIS PLATE.
Just made the same mistake.
3 notes for a faster installation:
1. MAKE SURE THAT PLATE IS LINED UP
2. the interior does NOT need to even be touched. You can pull the rubber cover over the linkage and remove the pin from under the car
3. if you're careful you do not need to unplug the starter connections, just move it out of the way
4. the lower panel can be taken apart as one piece if you leave the 4 small screw bolts between the two together.
bren5279 is offline   Reply With Quote
The Following 4 Users Say Thank You to bren5279 For This Useful Post:
Astroboy (12-31-2015), GhostOp86 (12-25-2015), marcoaferrer (11-28-2014), vaderbloke (04-10-2015)
Old 04-08-2015, 11:12 AM   #63
vaderbloke
Drives: 2014 Subaru BRZ
Rubber cover split
My linkage rubber cover split while pulling it over the pin. Any suggestions? I thought I was careful, but I guess not enough
vaderbloke is offline   Reply With Quote
Old 04-08-2015, 11:20 AM   #64
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I wouldn't worry unless you drive your car in winter
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Old 04-10-2015, 06:52 PM   #65
vaderbloke
Thanks I live near the gulf coast and get salt spray so I thought I would be safe and buy a new one.
BTW removing the pin from under the car works great. I think that's where I went wrong, trying to get the boot up into the interior.
Old 04-10-2015, 06:56 PM   #66
vaderbloke
Great tips. I wish I had read them earlier
I found that the plate was very loose on my car, so I put a tiny dab of superglue behind it.
I attached the cables to the starter first on reassembly. Made the job much easier.
Old 06-05-2015, 10:33 PM   #67
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
I'm having a bitch of a time getting the trans back on. I get it on the lower two studs but can't seem to line up the trans shaft and the center of the flywheel. Any advice will be helpful. I'm close to wanting to tow the car in just to finish up
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 06-06-2015, 12:18 AM   #68
wootwoot
Drives: FRS
Been there.
I used a jack under the oil pan to tip the motor toward the back of the car. With the trans off the car the motor tips forward. This makes it hard to get the trans bolted back up. It took me forever. If you can get someone to help wiggle it back it will make life better.
Don't give up!
Old 06-06-2015, 12:18 AM   #69
protpibe
protpibe's Avatar
Did you align the clutch properly?
If so, just just keep wiggling it and it should just "click" into place
Old 06-06-2015, 12:21 AM   #70
BadCompany235
#TrackAddicts
Yeah, I even double checked. I get the two bolts at the bottom lined up and then just can't get it to take the last 2 inches or so. I jacked up the engine and everything. I've never had this much trouble with a clutch change. I gave up. Gonna tow it into a shop tomorrow.
The Following User Says Thank You to BadCompany235 For This Useful Post:
Astroboy (12-30-2015)
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Chase Bays Clutch Line, Full Replacement Chase Bays Transmission and Driveline 1 02-11-2013 02:57 PM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 12:25 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
