Sam Strano
Old 06-04-2015, 08:29 PM   #3193
ksconekiller
Drives: Subaru BRZ
Originally Posted by ChrisV View Post
Note that the loudest voice of them being illegal is someone who hasn't held them or measured them, but is rather asserting since you can get more camber they must be illegal, completely disregarding the legal factors that would result in a lower ride height and more camber.
Who is that? Someone on this board, or somewhere else?
ksconekiller is offline   Reply With Quote
Old 06-04-2015, 09:08 PM   #3194
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by ButteR View Post
Get the crash bolts from a Subaru dealership. One per side, to replace the top bolt. ~ 5 degrees of camber.
For the part numbers, I believe they are still listed in the first post in the thread.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 06-04-2015, 09:18 PM   #3195
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
RMP is offline   Reply With Quote
Old 06-04-2015, 10:08 PM   #3196
ChrisV
Drives: 2014 FR-S 6MT
Originally Posted by markw View Post
I did the scientific method. 16mm wrench fit over the rear bar, 21mm fit over the front. Car drives great with both bars, springs and koni's.
Mark
I can confirm 16 in the rear, the front measured 20.7 on mine, but they are powder coated so that could account for the 0.1 difference.
ChrisV is offline   Reply With Quote
Old 06-04-2015, 10:26 PM   #3197
ChrisV
That someone was you declaring a part illegal on grounds not specified in the rulebook without having actually measured stock vs Konis.
Old 06-04-2015, 10:59 PM   #3198
solort
Drives: Series 10 FRS
Mark
i forgot the wrench method. Thx for doing that. I hope to build my new to me Series 10 over the summer to get it ready for next year Nationally..
Will try to pick up some tips and pointer from the large CS group at Moultrie Match Tour this weekend. Great weather and a great sticky slab of concrete. And I hear the CS group is awesome. A win/win/win...
solort is offline   Reply With Quote
Old 06-05-2015, 12:14 AM   #3199
ksconekiller
Drives: Subaru BRZ
That's what I figured you meant.
"Grounds not specified in the rulebook"? Not sure what you mean by that, but the only rule a person needs to know is that the replacement strut mounting points have to be the same dimensions as the factory unit. If an aftermarket unit is different, it is technically illegal. Just so you know, I have Koni full replacements on my car. Both bolt holes on each strut are round, and I got the same camber as with the OEM struts. Everything measured the same as the factory parts. What I said earlier was that apparently some people have been able to get more camber with the Konis than with stock struts; I am not one of them. My comments simply stated that if someone had struts that had slotted holes, they would not be able to use that to gain more camber than OEM struts.
I wouldn't want to see the Konis get banned any more than the next person, but if they were slotted, something would have to be done. Fair enough ?
Old 06-05-2015, 06:43 AM   #3200
solort
The Koni full replacements allow too much camber up front. If you are using the full Koni struts along with the smaller camber bolts maxed out, you will have an illegal amount of front camber. I'd say over 2.5 degrees is easily possible. I personally wouldn't have a problem with someone using the replacements as long as they keep the camber where it's possible with OEM struts (1.5 or less).
If the strut dimensions are identical to the original struts and you use the legal camber bolt, the resulting negative camber attained is legal unless the FSM limits the max camber (by stating it in the FSM) with an exact #. The older Dodge Neon ACR used to be limited to -2.4 as stated in their FSM. The SRT4 ACR has no such max camber limitation but limits what you can do to get negative camber. Read the Scion or Subaru FSM and follow it and you will be legal on your alignment.
And other people around pages 141-142 had similar feelings to what you stated. Camber envy.....
I hope when I get my car sorted out that mine will be towards the high side. But it may not, and I will also have camber envy...
Old 06-05-2015, 07:46 AM   #3201
ChrisV
As Clay references below, you're shifting your goalposts now.
From 13.5.A:
"The make of shock absorbers, struts, and strut housings may be substituted
providing that the number, type (e.g., tube, lever, etc.), system
of attachment and attachment points are not altered, except as noted
below."
As long as the system of attachment, attachment points, overall extended length is within 1 inch +/- and the spring load bearing surface is in the right spot, you're ok.
There is also no requirement to stay within the FSM specs for camber when using factory authorized camber bolts.
13.8.E:
E. If offered by the manufacturer for a particular model and year, the use of
shims, special bolts, removal of material to enlarge mounting holes, and
similar methods are allowed and the resulting alignment settings are
permitted even if outside the normal specification or range of specifications
recommended by the manufacturer
. If enlarging mounting holes
is specifically authorized but no material removal limits are specified,
material removal is restricted to the amount necessary to achieve the
maximum factory alignment specification.
We are fortunate enough to have a car that has factory authorized camber bolts. Between the lower pressure Konis, the TRD springs, and the camber bolts, and a smart alignment (two guys - one muscling the hub while the other torques the bolts), a range of camber exceeding the factory specification is both achievable and completely legal.
If you use legal parts, your alignment specs are not able to be protested. I'd hate to see a protest on an actual number rather than the hardware used anyways, as it's incredibly difficult to police. It'd be like the dyno testing fiasco from NASA last year.
Old 06-05-2015, 08:07 AM   #3202
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
As mentioned above, the mounting holes to the knuckle are not the same as stock, which allow more camber, thus making them illegal. Nothing to do with spring perch height, shock length or pressures
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 06-05-2015, 08:47 AM   #3203
ChrisV
Chris, look at post 3225.
When mine come in I'll measure them, but it would be an epic fail on Koni's part to make the struts illegal for a (the?) target market.
Old 06-05-2015, 09:15 AM   #3204
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I read that, however other people have stated other wise. Bottom line is that the full replacements, which don't change length or perch height are getting around a degree more camber than you can achieve on the stock housing. Essentially, how is that possible if everything is exactly like OEM? And we all know its not gas pressures, cmon now. Either way I said this before and I will say it again. I personally don't give a damn, but someone in another model car might. So do it at your own risk if you are hardcore about competing a major events.
Old 06-05-2015, 09:31 AM   #3205
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Looking forward to this, hopefully with pictures?
No point in continuing the argument until @ChrisV posts up the comparison of hole diameter and hole distance to strut center-line.
From there, it is pretty black and white. If they match the OEM struts then they are legal regardless of the resulting camber.
DylanFRS is offline   Reply With Quote
Old 06-05-2015, 09:43 AM   #3206
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Originally Posted by renfield90 View Post
It's in the same location as stock. I don't particularly feel like taking mine apart for the 3rd time this year, but it is a circular hole - not slotted.
Believe me if they were slotted there would've been a pretty urgent phone call to Koni to ask wtf, as I didn't really inspect these very closely until the car was in the air sans front suspension.
So yours appear to have exact measurments to stock, what is you camber at? I understand you probably have TRD springs
I believe I am the one who posted about it on here, however its been talked about at the events in my area. Figured Id bring it up and stir the pot. I personally have not done any measurements and have only seen 1 car with full replacements on stock springs and stock camber bolts. It was obvious, later confirmed with conversation regarding alignment settings. So either somebody is lying about what was done to that car, koni's are not exactly OEM, or I am making shit up. Trust me I don't even have a dog in this fight as my car was replaced earlier this week. My intentions here were/are to help those who drive 1000s of miles to national events. The "buzz" about this is out there. Maybe this thread will can that or prove it to be right.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
