Old 06-05-2015, 01:13 AM   #15
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Originally Posted by 1Cor10:23 View Post
@klittl06 could you offer some detail as to how to access the rear mounting point?
You need to take apart the airbag cover of the C pillar to get started.
Follow steps 1-2 on http://www.ft86club.com/forums/showt...terior+removal
Once you get all the covers off, you'll see the bolt holding in the stock seat belt mounting point, you want to reuse that one with the rallye 3
BAMF86 is offline   Reply With Quote
Old 06-05-2015, 06:38 AM   #16
klittl06
Drives: FRS?
Yup, this is what I followed. The rear attachment was a bit of a pain but totally worth it.
klittl06 is offline   Reply With Quote
Old 06-05-2015, 09:45 AM   #17
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@klittl06 @BAMF86 thanks gents, any advice on how to manage the white popclips in part 2? Potentially losing them and creating a rattle in the rear has me a bit concerned.
Also, did you guys re-use the OEM bolts or the one included in the kit?
1Cor10:23 is offline   Reply With Quote
Old 06-05-2015, 01:16 PM   #18
BAMF86
much slow
BAMF86's Avatar
You want to apply pressure to where the popclips are and gently pry the panel with your other hand so they don't come loose.
OEM bolt works fine for the mounting point, just don't have a passenger use the rear seatbelt while the harness is in use
The Following User Says Thank You to BAMF86 For This Useful Post:
1Cor10:23 (06-05-2015)
Old 06-05-2015, 01:37 PM   #19
Kostamojen
I lost one of those pop clips in the chassis somewhere
My only recommendation is to buy extras and be cautious.
Old 06-05-2015, 01:52 PM   #20
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
How about DD? Comfortable if u use OEM seat belts?
ZHoward is offline   Reply With Quote
Old 06-05-2015, 02:05 PM   #21
1Cor10:23
1Cor10:23's Avatar
@BAMF86 @Kostamojen to clarify, should the white clips remain on the frame or on the trim piece itself.
Also, is removing the trunk liner (2 black pop clips) in step 2 necessary for this?
Thanks!
Edit: or is it the large trim piece below the triangle piece (around the seatbelt mount) that can get loose / apply pressure to this?
Old 06-06-2015, 12:07 AM   #22
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
They can be pushed out of the way easy also the rear attachment has a disconnect that can be used to allow the belt to lay down to the sides should you feel the need.
FRSfan111 is offline   Reply With Quote
Old 06-06-2015, 01:24 AM   #23
Kostamojen
Thanks!
Be prepared to remove every piece of plastic in the rear of the car.
Old 06-06-2015, 01:26 AM   #24
Kostamojen
For DD I tuck the harness under the seat and use rhe seatbelt. Thats the beauty of this setup.
The Following User Says Thank You to Kostamojen For This Useful Post:
ZHoward (06-06-2015)
Old 09-01-2015, 08:42 AM   #25
TMF
TMF's Avatar
Drives: '14 FRS TT5
Here are the torque specs for the bolts that you need to remove for install and re-torque:
Front seat belt receiver (attached to the seat): 31 ft-lb
Front seat outer belt assembly (both the top bolt and bottom bolt on the B pillar): 22 ft-lb
Front seat bolts (to the floor): 39 ft-lb
Rear seat outer belt assembly (both bolts on bracket on D pillar): 22 ft-lb
It took forever to search through the crude FSM's that are available so I thought I would share this info!
TMF is offline   Reply With Quote
The Following 5 Users Say Thank You to TMF For This Useful Post:
Brzerker (09-29-2016), jmimac351 (11-13-2015), kevaughan (07-09-2024), MrSkubi (04-28-2022), ScionOfHorus (11-18-2015)
Old 11-11-2015, 09:34 AM   #26
Donbrz
Drives: 2015 Brz Blue Series
Even with warning, I also dropped a clip during re-install of cover. Clips easily slips out of cover due to slot. Hindsight would be to place small piece of tape over slot in cover to prevent clip from sliding out.
Donbrz is offline   Reply With Quote
Old 03-10-2019, 12:13 AM   #27
Hworang
Drives: 2017 BRZ
Hey guys, bringing this back but I'm having trouble with the rear driverside passenger seat belt bolt. I can thread the bolt loose or tight. I'm able to turn it quite easily both directions but when I try to tighten the bolt back in its having touble finding the threads. This is with and without the schroth belt bracket. Alll I can think about is that the bolt isn't lining up in the hole but it's not working. Any tips?
Hworang is offline   Reply With Quote
Old 03-10-2019, 11:53 AM   #28
i8ur911
Drives: 17 BRZ Series.Yellow
Wondering if this set up is actually approved by Schroth? I can't find the approval anywhere.....
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Schroth Rallye 3 4-point ASM Harness (Black) smbstyle Interior Parts (Incl. Lighting) 5 03-09-2015 12:09 AM
Making My Own Harness Pad(s) Pictures Inside FRS_FIEND Cosmetic Modification (Interior/Exterior/Lighting) 2 07-28-2014 08:20 AM
**JAPAN TOM'S LED Tail Light for FRS / 86/ BRZ - INSTALLED PICTURES INSIDE!! nigel-jdmparts Exterior Parts - Lighting 88 04-10-2014 06:49 PM
