Old 04-22-2015, 10:47 PM   #1
klittl06
Drives: FRS?
Scrothe Rallye 3 Harness - Pictures Installed
I recently got a Scrothe Rallye 3 Harness and someone asked for pictures of it installed. Feel free to ask any questions.
Please excuse the dog fur
Driver side view
Passenger side view
Left side attachment
Right side attachment
Rear attachment
klittl06 is offline   Reply With Quote
The Following 4 Users Say Thank You to klittl06 For This Useful Post:
BAMF86 (04-24-2015), BRZ68 (04-22-2015), fminicooper (07-29-2019), kevaughan (07-09-2024)
Old 04-23-2015, 02:53 AM   #2
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Do you have the rear section mounted to the factory shoulder strap location.
Ranatsu is offline   Reply With Quote
Old 04-23-2015, 03:19 AM   #3
ryoma
ryoma's Avatar
is it fine to have the rear mount off to one side? aren't you putting uneven tension on the harness that way?
Old 04-23-2015, 03:26 AM   #4
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Negative. It's a rally 3 it's designed to be installed that way. I have one installed in my car for over a year now. I did with it now too. After tracking with it on I feel so loose in any seat without one now.
Makes a WORLD of difference.
FRSfan111 is offline   Reply With Quote
Old 04-23-2015, 05:18 PM   #5
klittl06
Drives: FRS?
Yes, this is per the instructions.
Old 04-23-2015, 05:21 PM   #6
klittl06
Drives: FRS?
As @FRSfan111 said, it's designed to be installed this way. Everything is adjustable for a snug fit.
And you really do feel loose with just using the factory seat belt after you've used the harness. That long driver seatbelt buckle has to be to blame, at least partially.
Old 04-25-2015, 05:25 PM   #7
Ranatsu
Cone basher
Yea I was aware, just wanted to confirm.
Thanks
Old 04-27-2015, 11:51 AM   #8
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I admit I haven't researched harnesses because I'm not at that point yet, but aren't there some safety issues associated with not using an actual harness bar and going all the way to the baby seat attachment points?
raul is offline   Reply With Quote
Old 04-27-2015, 11:59 AM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
Yes. I believe this install goes to the rest shoulder strap mount.
No idea on safety of the two straps around your neck...
Old 04-27-2015, 01:30 PM   #10
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Some would say a harness bar that is attached with bolts right behind your head is even less safe in a crash.
Kostamojen is offline   Reply With Quote
Old 04-27-2015, 03:54 PM   #11
xwd
The attachment point most of us are using is the seatbelt mount which is very sturdy. There are some groups who won't let you use this harness on track because they don't believe in the ASM technology.
Old 04-27-2015, 05:16 PM   #12
FRSfan111
Completely agree. My local Porsche auto x group and hpde group allow it. Just ask around.
Old 04-27-2015, 09:37 PM   #13
klittl06
Drives: FRS?
+1
This harness is also dot approved because of the asm technology, although, I don't dd with the harness in use. There is a clip just behind the headrest in the pics so it quickly and easily stows. I wouldn't be able to get my coffee out of the cup holder with the harness on.
The Following User Says Thank You to klittl06 For This Useful Post:
jbailey8748 (11-16-2015)
Old 06-04-2015, 09:04 PM   #14
1Cor10:23
1Cor10:23's Avatar
@klittl06 could you offer some detail as to how to access the rear mounting point?
Schroth Rallye 3 4-point ASM Harness (Black) smbstyle Interior Parts (Incl. Lighting) 5 03-09-2015 01:09 AM
Making My Own Harness Pad(s) Pictures Inside FRS_FIEND Cosmetic Modification (Interior/Exterior/Lighting) 2 07-28-2014 09:20 AM
**JAPAN TOM'S LED Tail Light for FRS / 86/ BRZ - INSTALLED PICTURES INSIDE!! nigel-jdmparts Exterior Parts - Lighting 88 04-10-2014 07:49 PM
