Old 06-04-2015, 05:59 PM   #1
PBlack09
PBlack09's Avatar
Drives: 2015 Scion FR-S Firestorm
What is this on my overpipe?
I have a JDL UEL catless header and pictured was my Private Label MFG overpipe. The thing rattled against the subframe like crazy despite all efforts against that, so I'm switching it out for a Perrin overpipe.
I had this overpipe installed maybe a few days and noticed this bronze stuff covering the flanges after uninstalling it, but only the overpipe flanges and not the header or front pipe. It also comes off if I scratch it a little hard. I may be wrong, but I don't think it came like that.
I used the GS gaskets on both sides. Was there a leak or what? I had no CEL (also have OFT stage 2 tune), I don't think I smelled a leak (I have a horrible nose all year round thanks to allergies), didn't feel any air coming from flanges after installing (although the fan shroud makes it kind of hard to feel little stuff).
Any opinions?
PBlack09 is offline   Reply With Quote
Old 06-04-2015, 06:57 PM   #2
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Check your cam plate directly above the overpipe on the back of the engine and see if it's leaking oil?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
kch (06-04-2015)
Old 06-04-2015, 08:59 PM   #3
celek
Resident Gear Head
celek's Avatar
I believe it a flux component PLM uses for quick welding.. Hence why it is inside too. or maybe an acid dip to clean off impurities or sealer for the weld
celek is offline   Reply With Quote
Old 06-04-2015, 09:24 PM   #4
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
Most likely. Seems to be an organized portion so it would lead me to believe it's part of the unit itself and came like that from the company. Keep us posted tho if you find out any info.
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Old 06-04-2015, 09:55 PM   #5
celek
Resident Gear Head
celek's Avatar
I had the same thing on a PLM header years ago, I won't recommend them ever, but my comments and thoughts on there product are outweighed by the price.
You can see the dark brown stuff on flange here too.
Old 06-04-2015, 10:17 PM   #6
Poodles
Drives: 2015 Series.Blue
Maybe magnaflux residue?
Old 06-04-2015, 11:12 PM   #7
PBlack09
PBlack09's Avatar
Thanks for all of the replies. I'm pretty sure it's a chemical PLM coats the end of their pipes in (inside and out) that turns bronze/brown with intense heat.
My cam plate wasn't leaking and I highly doubt there was an exhaust leak.
Like celek said, I wouldn't recommend buying PLM. The Perrin overpipe had breathing room between it and the subframe even after I wrapped it in a titanium exhaust wrap. The PLM was maybe 2cm even when pushing up on it to get it as high as it could go.
I kind of see overpipes similar to HDMI cables. It's all pretty much the same damn thing performance-wise. It's just how wide you want to go and how it fits that really matter.
Old 06-09-2015, 02:25 PM   #8
SamGam
Drives: '13 BRZ SWP 6MT
Was there any tape on that area when you got it? Looks like burnt tape residue.
SamGam is offline   Reply With Quote
WTB - 3" overpipe & Perrin 2.5" overpipe for sale DAN_BRZ Canada Classifieds 1 02-27-2015 02:15 PM
WTB Overpipe wbradley Canada Classifieds 10 02-26-2015 11:10 PM
WTB: OverPipe tonypalomo Want-To-Buy Requests 5 01-21-2015 05:26 PM
which is better the p&l overpipe or motiv overpipe Anthony7515 Engine, Exhaust, Transmission 15 04-08-2014 08:00 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 03:03 AM
