Old 06-03-2015, 10:19 AM   #29
RFB
RFB's Avatar
Drives: FRS
snowman snot variation
Stationary store sticky snot is instantly removable.
There is a substandard snot that is to sticky, and will run in hot weather.
If by chance you get the substandard, you will not have wasted your 99 cents, just mix some room dust in it and it will be fine.
Tape leaves an area uncovered (outside top edge,) under the fender at rear, while snot can be pushed in with a credit card.
I did NOT replace the gaskets, just sealed them with gasket sealer.
Goin fine since I figured out the problem in June of 2012 - no wa wa !
RFB is offline   Reply With Quote
Old 06-04-2015, 01:41 PM   #30
keonigt
Drives: 2022 BRZ
Originally Posted by Danklvr View Post
do a google search for Poster Putty / mounting putty. Scotch / 3m / UHU Tac all sell a variety.
Thanks bro! Found it just now.
keonigt is offline   Reply With Quote
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 07:14 PM
Car leaking davebrus Issues | Warranty | Recalls / TSB 4 03-21-2014 11:23 AM
Oil leaking? grgonium CANADA 7 07-30-2013 04:08 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
