Old 06-03-2015, 09:50 PM   #1
fluffy-reindeer-slayer
Drives: fr-s and tc2
skunk 2 intake owners, oil cooler fitment question.
Im looking into purchasing an oil cooler, mainly the mishimoto unit. my question for skunk 2 owners is, will it fit? given the air box is very close to the oil filter.if anyone is running an oil cooler can you post pick of the routing for the oil feed return lines.or confirm fitment of x kit, whatever you may have.thanks in advance.
fluffy-reindeer-slayer is offline   Reply With Quote
Old 06-03-2015, 10:39 PM   #2
wootwoot
Drives: FRS
I have a custom set up but I used a skunk2 oil sandwich plate, a liquid to liquid core, and I made my own 8an lines. I was just barley able to fit it all in with the intake.
The Following User Says Thank You to wootwoot For This Useful Post:
fluffy-reindeer-slayer (06-04-2015)
Old 06-04-2015, 10:53 AM   #3
Mishimoto
Drives: 2013 Subaru BRZ
Thanks for the interest in our oil cooler kit! Unfortunately, due to oil filter housing proximity, it does not appear as though there will be enough clearance to run our oil cooler kit (in its current configuration) with this particular intake system. It appears as though most are running a taller spacer to raise the sandwich plate in order to run the lines for larger airbox systems (such as the Skunk2 setup).
Sorry for the inconvenience!
-John
Mishimoto is offline   Reply With Quote
The Following User Says Thank You to Mishimoto For This Useful Post:
Mishimoto Oil Cooler filter fitment issue woode Engine, Exhaust, Transmission 6 09-24-2018 10:41 AM
Skunk 2 PowerBox Intake 86SPEED Groupbuys 34 03-27-2015 02:37 PM
help please skunk 2 intake installation fluffy-reindeer-slayer Engine, Exhaust, Transmission 1 12-22-2014 05:53 PM
fitment question aaguilar3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-07-2014 08:27 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
