Old 06-02-2015, 06:16 PM   #687
Sleepless
Drives: 2016 FR-S
Anyone have the PIDs for the knock sensor data?
Sleepless is offline   Reply With Quote
Old 06-02-2015, 11:25 PM   #688
Astroboy
Astroboy's Avatar
Drives: None
Look up torque nock detector under the playstore
Astroboy is offline   Reply With Quote
Old 06-03-2015, 12:04 AM   #689
Sleepless
Drives: 2016 FR-S
Thanks, I'm aware of that plugin. However, that is a simple calculated knock detector. I'm looking for the knock sensor values like knock correction, learned knock correction, etc.
Old 06-03-2015, 08:38 AM   #690
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
If all else fails, pickup an open port. It provides logging and flashing abilities. $169
http://www.tactrix.com/index.php?opt...hk=1&Itemid=53
B-R-Z is offline   Reply With Quote
Old 06-03-2015, 02:07 PM   #691
bear89103
Old Fart
bear89103's Avatar
I put in the oil temperature PID exactly how it states to put it in, but the readings I get are really erratic. It jumps constantly from as low as 6.4 all the way up to 498,536.
What could be causing this?
Project Panda86 Journal -
bear89103 is offline   Reply With Quote
Old 06-03-2015, 03:55 PM   #692
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is yours set up like this?
I also have "use Celsius" unchecked.
Old 06-03-2015, 06:17 PM   #693
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
With the newest torque update you don't need the PID. The stock oil temp gauge works perfectly.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-03-2015, 06:32 PM   #694
bear89103
Old Fart
bear89103's Avatar
Yessir. That's how I have it
Old 06-03-2015, 10:41 PM   #695
fika84
fika84's Avatar
I have found this site talking about Toyota PID's and I put some of them in.. looks like the wheel speed PIDs seem to be working! I haven't jacked up the car and tested each wheel individually, but I can say that when I'm turning slowly in a parking lot they are all reading different as they should (outside faster than inside) and when I'm going straight they all read what my speedo is reading! I'm going to play with some other ones and see if they are right or accurate. Have fun!
http://www.toyota-4runner.org/5th-ge...orque-app.html
@G_Rossney I know you were looking for these too! Not sure if you still are.
fika84 is offline   Reply With Quote
Old 06-04-2015, 10:45 AM   #696
bear89103
Old Fart
bear89103's Avatar
Doesn't work. I tried the stock oil temp. It's not green, so it's not reading anything.
Old 06-04-2015, 11:17 AM   #697
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
What app version are you running? You need at least Torque Pro v.1.8.49 for it to work.
Old 06-04-2015, 12:44 PM   #698
bear89103
Old Fart
bear89103's Avatar
i have version 1.8.52
Old 06-04-2015, 01:54 PM   #699
Astroboy
Astroboy's Avatar
Drives: None
So does the boost only read up to 5.2 with the oem map sensor?
Old 06-04-2015, 01:54 PM   #700
Astroboy
Astroboy's Avatar
Drives: None
I know it's been mentioned before in regards to a different car, but how accurate is the boost reading on our car on stock sensors?
Just want to make sure I'm not missing anything before I bug my tuner.
I'm only seeing a max of 5.2 psi when I should be seeing something closer to 9.
Did you ever figure it out?
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
