#29 |
| The Following 3 Users Say Thank You to grichardt For This Useful Post: |
#30 |
Drives: 2013 FR-S Hot Lava
Thanks for the update! Looks like I'll be ordering one of these.
#31 | |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
This is your life and it's ending one minute at a time.
#32 | |
Drives: 2017 Golf R
#33 |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | Sabretooth (06-02-2015) |
#34 |
Drives: 2013 FRS- Hot Lava
How's the bolt access for the head x header portion? Some of the aftermarket headers are absolutely horrible for this.
It looks a bit less "UEL" than the OFH; very curious to hear how it sounds! |
#35 |
Drives: 2015 Scion FR-S
can you make a video or something . i want to know what it sounds like before i buy. does it sound anything close to the tomei?
#36 |
Yeah a video would be awesome!
#37 |
Will get a video tomorrow. Definitely not loud, has the rumble I wanted. Might look at a front pipe with a resonator to get some extra volume while eliminating the last cat.
#38 | |
Install was a piece of cake. Took longer getting the underpanel off. |
#39 | |
Drives: Neptune GR86
| The Following 2 Users Say Thank You to Andrew025 For This Useful Post: | DAEMANO (06-11-2015), DriftinFRS (06-03-2015) |
#40 |
The pictures of those <cough> collectors are just sad. The reentrant turbulence caused by those protruding pipes would be significant. Sharp edges and bends all rob power. The pros go to great length to ensure a perfect match between the exhaust port and intake manifold, including the gasket itself. A well designed/manufactured collector is crucial.
It's disappointing to see what's being passed off as an "upgrade." As always, caveat emptor.
#41 |
Drives: 2014 GT86
How much collectors impact header performance is yet to be measured. Or you have some data of _exactly_ the same header with only difference of different collector? It might aswell be difference of just 0.5hp, more then worth not to do it for vendor/manufacturer, if it costs extra 50-100$ in end price. Until singled out just different collector designs get tested/compared, i wouldn't blindly bash this design bit in cheaper headers.
| The Following User Says Thank You to churchx For This Useful Post: | Strife26 (10-26-2015) |
#42 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
At least it all lined up. Cheap stuff tends to not slide right on like that so that's a plus.
| Borla Unequal Length Header Review and DIY | F1point4 | DIY (Do-It-Yourself) Guides | 92 | 05-10-2021 04:06 PM |
| Tomei unequal length header | Thatguyjeremy | Engine, Exhaust, Transmission | 5 | 02-11-2015 03:15 PM |
| WTB: FA20Club Unequal length header | Chrisposey | Want-To-Buy Requests | 3 | 09-03-2014 02:59 PM |
| ****Rev Works 4-1 UEL (Unequal Length) Header - $699!**** | Rev Works | Engine, Exhaust, Bolt-Ons | 206 | 08-01-2014 05:10 PM |
| Unequal Length Header Noise | fuse614 | Engine, Exhaust, Transmission | 55 | 07-30-2014 11:06 PM |
