Old 04-14-2015, 01:45 PM   #29
D K
Stig's dark passenger
Set it to what number exactly?
Originally Posted by fika84 View Post
In @stugray defense, what he is looking for isn't in that tech article about how the valves work. They do have 2 different kinds of electric valves, but not to do what he wants. He wants a way to SET the point (pressure) at which the valves open.. these all have preset values and no where does it say that you can adjust that preset value.
D K is offline   Reply With Quote
Old 04-14-2015, 01:57 PM   #30
fika84
fika84's Avatar
Whatever number he wants.. whenever he wants.. on the fly.
fika84 is offline   Reply With Quote
Old 04-14-2015, 02:34 PM   #31
celica73
Other than pre-start oiling and on the race track, the Accusump is likely going to be closed, so the pressure swings are not that big of a deal. A 3 quart Accusump will not deliver 3 quarts of oil. It is 3 qt total volume, that can be oil or air. If it's got 3qt of oil in it, then that's at zero psi and it won't help.
The last time I ran one, it was in a car that made about 65 psi (max). I put 30 psi air in the sump (empty) and let the car fill it. That gives about 1.5 quarts of oil at up to 30 psi (look up the ideal gas equation). I would run the crank case about 1 quart low (good for power) and let the pan over fill it a bit when fully discharged (not so much to be an issue).
Old 04-14-2015, 02:38 PM   #32
stugray
Drives: 2013 GBS BRZ Limited
I never said there is a valve you can manually set.
They have different valves set at different pressures as you yourself have listed.
pick a pressure that would be ideal for you.
See if there is a valve that corresponds to that pressure.
D
Ahhh... So it is not MY reading comprehension that is in question.
"I never said there is a valve you can manually set. "
So to my statement
I wish that accusump would make an electric valve that has an adjustable setpoint.
You responded:
Do alittle more research man. Its all out there
Which in pretty much every way that it can be interpreted means that you are telling me that "IT" (an electric valve that has an adjustable setpoint) "IS OUT THERE"
I countered with:
Please just post a link.
where your smart-ass response was:
So you were trying to say that I am stupid and all I have to do is GOOGLE it or RTFM and I would have my answer.
So yes you did say there was such a thing, just not directly and with a little attitude.
Maybe YOU are the one who needs to learn how to google and work on your reading conprehension before insinuating that someone ELSE is the dumb ass.
SO now back to the ORIGINAL POINT that I was responding to:
Originally Posted by LS1M View Post
Wow, I had no idea that these engines had such variable oil pressure! No wonder my BRZ didn't come with an oil pressure gauge - it'd freak out the customers. I mean, holy cow, it's all over the map - 125 cold to 15 PSI warm idle?! There's no way an accusump can maintain oil pressure when it's swinging all over the place like that. Not the 3-quart model, anyway. Otherwise the oil level in the engine is going to be all over the map as well. Am I missing something here? Either you're 2.5 quarts low at 7000 RPM or 2.5 quarts over-full at 1000 RPM. Or a little of each perhaps.
Accusump also make a 1-quart model that might be a better choice for these little engines. The 3-quart accusump was fine in my V8, where oil pressure stays in a 40-PSI range. A 1-quart sump can still pre-lube the engine and provide some high-rpm stability, without making the oil level vary so much.
I will reiterrate: Too Bad ACCUSUMP does not make an electric valve with an adjustable setpoint so that we could set it BELOW 15 PSI
Old 04-14-2015, 11:34 PM   #33
D K
Ok buddy..
good luck with your install
So to my statement
You responded:
I countered with:
Old 05-24-2015, 03:20 PM   #34
philooo
Drives: 13' Scion FRS Track car
I' dlove to see some picture of the accusump install, where you installed it , where the piping is routed , ect...
always good insurance to have one of these on non dry sump engine on the track
Other best thing, a dry sump system, but I have not seen anybody selling a kit ready to install.
philooo is offline   Reply With Quote
Old 06-02-2015, 01:54 PM   #35
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
I Emailed ARE dry sump folks. They responded that they have no plans for a kit for the FA20 engine.
Brzzee is offline   Reply With Quote
Old 06-02-2015, 02:57 PM   #36
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Here's where we mounted it in the race car.
crazyfrenchbiker is offline   Reply With Quote
Old 06-02-2015, 05:22 PM   #37
puma
crew chief
puma's Avatar
Drives: Race car FR-S
did you get before and after logs of the oil pressure?
Where are the details on this car?
puma is offline   Reply With Quote
Old 06-02-2015, 06:08 PM   #38
crazyfrenchbiker
Hot Lava 6MT
The details are... mostly on facebook but we will be glad to answer any questions you have.
No logs, it didn't run into any pressure issues last season, but the car spent most of the season broken with transmission issues. That will be resolved with the hollinger.
Old 06-02-2015, 06:34 PM   #39
stugray
With it setup as a manual valve operation as in the pic, the sump will constantly charge & discharge with the oil pressure in the engine.
How do you choose to operate it?
Do you close the valve after the sump is up to pressure, and drive that way, or do you leave it open the whole time and hope you remember to shut it off before you kill the engine?
Curious
Old 06-03-2015, 07:04 AM   #40
puma
crew chief
puma's Avatar
i don't want to answer for him but we had the same setup on our previous racecar and it is pretty much like you said, always open and you need to shut it before you stop the car.
What we usualy did was to raise the rpm a little to raise the pressure and than shut the valve.
If the car hasn't been started for a long time, you can open the valve prior to starting the car, this will help to bring oïl to the engine to avoid it running dry. You need to shut it back up before starting though because the pressure will take longer to build, this is important that the valve always be shut when you start the car.
If i install an other one, i'll have an electric valve because the pilot forgot about it too often.
Old 06-03-2015, 07:05 AM   #41
puma
crew chief
puma's Avatar
can you post the link to Facebook or send it in PM?
Old 06-03-2015, 07:53 AM   #42
philooo
I am curious about the plumbing as well. And my biggest problem with the manual version is that it is indeed too much to remember. I think electric is the way to go. When you are about to get on the track or coming back from it, the last thing you want to do is going through a checklist for all the button you have to press.
PS: is that an AIM MXG dash ?
LCA install WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-16-2014 05:47 AM
Which mod to install first .... ?? humfrz Scion FR-S / Toyota 86 GT86 General Forum 9 11-09-2013 09:07 PM
MTX install Deadspool Electronics | Audio | NAV | Infotainment 1 06-27-2013 07:21 AM
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
Need help with HID install ortizwyld Cosmetic Modification (Interior/Exterior/Lighting) 4 02-21-2013 11:12 PM
