Old 06-01-2015, 01:29 PM   #85
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
Originally Posted by WORKS View Post
Here you go.
As noted in the image, our WORKS Air Filter, Front Pipe, Mid Pipe & Axle Back Muffler were installed at the time of the Stage 2 readings.
Thank you @WORKS!
I'm out here in CA so I hope your CARB certs go well too!
Can't wait to see this kit in action, just the amount of oomph this car needs!
stoked_on_spool is offline   Reply With Quote
The Following User Says Thank You to stoked_on_spool For This Useful Post:
WORKS (06-01-2015)
Old 06-02-2015, 05:10 PM   #86
FR-Sizzle
Drives: brz
WORKS Stage 2 Turbo Kit Preview Thread
Originally Posted by boredom.is.me View Post
There is nothing in the overpipe. The cats are in the header and front pipe.
I believe that he is referring to the fact that per CA law, technically any modification of the exhaust system BEFORE the last catalytic converter is not CARB legal and is grounds to fail a SMOG inspection. So even if I just throw in a Motiv Concepts overpipe and leave the rest of my exhaust intact, it's still no bueno.
Again, as dumb as it sounds, even though it's just replacing one overpipe with another and retaining both factory cats, it's technically still not street legal. Hopefully they'll "do the right thing" and make this kit CARB legal though.
That's what I meant and I ale meant to say the front pipe. Look at the picture there front pipes are replaced. He even says they are coated too. I always thought if any of the stock cats are replaced you can't get carb approval.
FR-Sizzle is offline   Reply With Quote
Old 06-02-2015, 05:16 PM   #87
raven1231
What pictures are you referring to? the dyno graph? I think the actual production kit retains it. I know for a fact the stage 1 at least only replaces the over pipe.
Old 06-02-2015, 05:18 PM   #88
FR-Sizzle
Drives: brz
Here you go flippy.
Really, how are you going to miss this and they stated the over pipe AND front pipes are replaced in another posy
Old 06-02-2015, 05:21 PM   #89
raven1231
No...they stated that the car on the dyno had aftermarket over pipe and front pipe, not the kit itself. How did YOU miss the very first post:
Our WORKS Stage 2 Turbo Kit is nearing completion so it's time for its own dedicated info thread.
As things progress we will update it with more information and answer your questions as best as possible!
For now, a smattering of development photos and specs to whet your appetite.
Cheers,
WORKS Motorsports
  • Air-to-liquid intercooler
  • 30 row radiator
  • 9.25"x3.5"x3.5 intercooler size
  • ~12 psi peak boost
  • Retains factory airbox & exhaust system (only the exhaust overpipe is removed)
  • In process of obtaining CARB exemption
tyrantcf (06-02-2015)
Old 06-02-2015, 07:06 PM   #90
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Regarding the exhaust system, both of our kits only require the removal of the over pipe.
Cheers.
WORKS is offline   Reply With Quote
The Following User Says Thank You to WORKS For This Useful Post:
raven1231 (06-02-2015)
Old 06-03-2015, 07:30 PM   #91
WORKS
WORKS's Avatar
Stage 2 installed with front bumper on.
The Following 2 Users Say Thank You to WORKS For This Useful Post:
CxG (08-01-2015), raven1231 (06-03-2015)
Old 06-03-2015, 07:40 PM   #92
raven1231
Want! I'd remove the grill though
Old 06-03-2015, 09:00 PM   #93
stoked_on_spool
@WORKS If you need someone in CA to run the kit through its paces at track days in the hot socal weather let me know and I'll be happy to run it and log data for you! haha
WORKS (06-05-2015)
Old 06-04-2015, 01:49 AM   #94
Kaotic Lazagna
Drives: GR Corolla
Any differences in handling characteristics since the passenger side engine room brace can no longer be used?
Old 06-04-2015, 04:24 PM   #95
WORKS
WORKS's Avatar
We've done multiple track testing sessions with and without the passenger side strut brace mounted and our drivers have not noticed a change in handling characteristics.
For those interested in additional bracing, we have confirmed that the Whiteline KSB652 strut tower brace will fit with our Stage 1 Turbo Kit. We imagine that bar will also fit with Stage 2, but have not had a chance to confirm.
Cheers.
CxG (08-01-2015)
Old 06-04-2015, 05:42 PM   #96
Kaotic Lazagna
Drives: GR Corolla
Cool. Thanks for answering. Waiting for that CARB approval
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
WORKS (06-04-2015)
Old 06-09-2015, 07:51 PM   #97
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
[ame="https://www.youtube.com/watch?v=3vM-2MijcQQ"]https://www.youtube.com/watch?v=3vM-2MijcQQ[/ame]
Thanks again WORKS and Cam Tuning https://www.facebook.com/camtuning
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ
2017 ss1le
2017 Honda Civic Type R #1353
2002 Rsx Type s
GhostOp86 is offline   Reply With Quote
The Following 6 Users Say Thank You to GhostOp86 For This Useful Post:
clayrush (06-10-2015), hmong337 (06-14-2015), Kaotic Lazagna (06-10-2015), raven1231 (06-09-2015), SPCorBUST (07-19-2015), WORKS (06-10-2015)
Old 06-10-2015, 11:29 PM   #98
Fred E
Drives: WRB BRZ
Nice numbers! I'm not sure yet when I'll be able to get my intercooler on, but I'm hoping @moto-mike will be able to get a similar result out of my setup!
Fred E is offline   Reply With Quote
The Following 3 Users Say Thank You to Fred E For This Useful Post:
GhostOp86 (06-11-2015), raven1231 (06-11-2015), WORKS (06-11-2015)
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 05:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 07:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 08:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 01:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 08:24 PM
