Old 05-29-2015, 02:30 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You can still mess up ARP if you don't keep the threads clean, especially with open-ended lug nuts.
Old 06-01-2015, 10:48 PM   #16
ka-t_240
No issues with ARPS. I swapped them on the front of my BRZ 2 weeks after I bought it. My old STi had them the whole way around as well. I have my wheels off every other week. Studs look great after the year, I do see some rust in my lugs, but I'm not worried about that.
I know a lot of people with the GR WRX had issues with studs breaking as well.
ka-t_240 is offline   Reply With Quote
Old 06-01-2015, 11:41 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by superpenguin View Post
I'd love to go ARP, the only thing stopping me right now is the cost as I don't have acess to a press and I can't really have the car on jacks for a couple days while I drop the hubs off at a machine shop
But there's a reason just about every serious track car you'll see has gone over to ARP studs. They are the industry standard, period.
You don't *need* a press. I use one because I have one. Multiple ways to safely install them though.
OP: I never broke OEM ones on the BRZ, but I've never broken an ARP on any car. It's the first thing I do to my track cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG Mike (06-01-2015)
Old 06-01-2015, 11:42 PM   #18
puma
crew chief
puma's Avatar
Drives: Race car FR-S
yeah from what i remember they were pretty damn easy to do, no messing with changing the bearings and all, even the rear can be removed with the axles in place, follow the how to and it really shows how to do it.
I beleive i didn't use my press when i did them, maybe when taking them out? not sure.
puma is offline   Reply With Quote
Old 06-02-2015, 12:59 AM   #19
SVLTE
but the ARP's wont fit back in.
I had no need for a press either. Once you get the hubs off (fronts can be challenging, I did them without taking the hubs off. Rear hubs are really easy to take off), find a deep well socket or two blocks of wood to support the hub around the stud you're removing, and hit it with a small sledge hammer. It'll pop right out with one or two whacks. Use the pass through lug nut/washer method to pull the new ones into place (very easy with an impact wrench). One tip: if you're pulling the studs into place in rapid succession, use a new lug nut on each one because they will build up a lot of heat in the process and shed metal onto your pretty new bronze studs.
SVLTE is offline   Reply With Quote
The Following 2 Users Say Thank You to SVLTE For This Useful Post:
CSG Mike (06-02-2015), mav1178 (06-02-2015)
Old 06-02-2015, 08:48 AM   #20
puma
crew chief
puma's Avatar
well you still have to remove the bearings hubs but you don't need to remove the whole carrier and drain the rear diff, etc, that's what i meant. Only 4 bolts and the bearings can be taken out with the axles still in place in the rear diff.
Old 06-02-2015, 12:50 PM   #21
dgerny
Drives: 2013 Scion FRS
I did it in a few hours using a hammer and a impact wrench.. I just broke the top off of one of my old lug nuts and hammered them all out. For the fronts you can just slide them in on the back of the hub. No one told me that, till I figured it out saved some time!
dgerny is offline   Reply With Quote
At what point do we need to upgrade head studs and main studs? Amir Ghadiri Forced Induction 5 03-03-2015 12:13 PM
Experiences with CPO? heisenbergbrz BRZ First-Gen (2012+) — General Topics 20 04-22-2014 10:44 AM
Experiences with plasti dip Chen Northwest 24 10-30-2013 01:18 AM
Contemplating buying used BRZ with tons of mods but is it worth it? Sebaru BRZ First-Gen (2012+) — General Topics 48 07-19-2013 11:25 AM
Contemplating Raven Purchase Please Advise steve87j Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2012 10:44 PM
