Old 06-01-2015, 02:51 PM   #1345
churchx
churchx's Avatar
Drives: 2014 GT86
How well those 15" clear brakes?
Old 06-01-2015, 05:27 PM   #1346
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
the rear fitment looks so damn good. post up some slips and pass video's when you're done!
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
spitfire481 (06-01-2015)
Old 06-01-2015, 06:15 PM   #1347
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I struggled to work out rear offset because of the massive bulge of the tire. Worked out just right though
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
hmong337 (06-02-2015)
Old 06-01-2015, 06:16 PM   #1348
spitfire481
Drives: 2JZ FRS
Had to do some caliper shaving because of the step in the barrel. We have custom Weld wheels in 15" that bolt right up though. Different barrel step design
MoTeC
Build Thread
@spitfire481
Old 06-01-2015, 08:31 PM   #1349
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
How meaty of a tire can I go with stock suspension and wheels that are 18x8.5 +42 offset?
I'd like to weigh my options for tires before my wheels come in, so I can plan accordingly.
Any help is appreciated!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 06-01-2015, 11:46 PM   #1350
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Originally Posted by spitfire481 View Post
my drag setup seems pretty meaty. 26/11.5/15 mickey thompson et street radial
This guy won the meaty thread
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
S84kam (06-06-2016)
Old 06-02-2015, 08:43 AM   #1351
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
If only the rear counts.
Old 06-02-2015, 10:50 AM   #1352
Xtreme-86
Xtreme-86's Avatar
Drives: 13 whiteout frz
Will a 275/30 fit our rear on a 19x10 +50 wheel?
Xtreme-86 is offline   Reply With Quote
Old 06-02-2015, 11:41 AM   #1353
Jive Turkey
the tuna, no crust.
i wouldn't go bigger than a 245 for strut clearance purposes up front. in the rear you can go bigger if you want though i think
i think in the front that offset is too high, the rear might be okay because of the width.
why are you doing with such a massive rim size, you can fit a 275 better with a 9.5 +40 or +38
Old 06-02-2015, 11:55 AM   #1354
Xtreme-86
Xtreme-86's Avatar
Because I just bought a set of Vossen cvt 19x8.5 and 19x10 so I'm trying to buy tires. Tire rack is back ordered on the tire I want in a 265/30 so I figured why not go wider with a 275/30 just trying to see if it fits before I order them.
Old 06-02-2015, 01:45 PM   #1355
Xtreme-86
Xtreme-86's Avatar
Oh here's the setup
Rim: vossen cvt
Front: 19x8.5 +45 tire 235/35
Rear: 19x10 +50 tire 275/35
Will it fit without issues?
Old 06-02-2015, 05:23 PM   #1356
Jive Turkey
the tuna, no crust.
why not a 245 in the front? 235/35 is like no sidewall and on an 8.5 i don't think thats enough rubber personally.
hm, i know for fact 18x10 +45/+42 fits no issues. i think you will be okay, MAYBE might need a 5mm spacer, but i honestly do not know. also depends on the type of tire you're doing.
Old 06-02-2015, 06:14 PM   #1357
Xtreme-86
Xtreme-86's Avatar
Dunlop dz102
Old 06-02-2015, 07:18 PM   #1358
x1UP
One & Done (AOZORA)
x1UP's Avatar
I was going for 235/40 on all four. Is that sidewall fine? Your advice matters, so any help is appreciated!
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
