Old 06-01-2015, 01:28 PM   #29
AlexWood
Drives:
Mine does something similar. If I pull it out of gear and coast to a stop and the AC is on, it will make a chattering noise for about 1-2 seconds. Seems to me that it's due to the rpms dropping too low. If you aren't comfortable downshifting then I would just coast with the car in gear and use the brakes to slow you down. Once the rpms drop to about 2000-1500, drop it into neutral. That's fixed it for me at least.
AlexWood is offline   Reply With Quote
Old 06-03-2015, 08:01 AM   #30
Itzed
Drives: 2014 BRZ Limited
I agree with your method of "fixing" it, I do the same. But I don't think it's specifically related to RPM. I've looked at the tach several times while I hear it and it's rock solid with no dip or movement when the sound is starting or stopping. Many people on the other thread think it's flywheel chatter. Sounds more like the FI switching over to me. Whatever, I've learned to not worry about it.
Itzed is offline   Reply With Quote
Strange sound when shifting into first or second Jfheisenberg Engine, Exhaust, Transmission 35 06-23-2015 03:13 PM
strange fluttering sound at high rpm for SC JoonPrime Forced Induction 4 10-10-2014 03:17 PM
Yet another strange interior sound. DCStorm Issues | Warranty | Recalls / TSB 5 10-25-2013 12:05 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 07:16 PM
Strange sound coming from gas tank? nocurfew Engine, Exhaust, Transmission 6 07-31-2012 03:37 PM
