Old 05-29-2015, 10:45 PM   #533
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by lamawithonel View Post
Those ridges look intentional. Do they serve a purpose?
Have you been reading this thread?
Originally Posted by gramicci101 View Post
Would it be beneficial for the inside of the horn to be polished smooth, or is it not a big deal? Or do the slight ridges perform some function that I am unaware of?
Originally Posted by NotEric6 View Post
It is not a big deal. That is just how this machinist decided to finish the bell horns. The ridges are very small and more aesthetic than actual ridges (probably 10 thou max between peak and valley).
Like previously stated, between peak and valley their is only 10 thousandths of an inch difference. We are not concerned that the ridges reduce or add any performance. We will not be sanding them.
Captain Snooze is offline
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
Calum (05-30-2015), civicdrivr (05-29-2015), fika84 (05-30-2015)
Old 05-30-2015, 01:25 AM   #534
FRS Justin
Drives: 2013 Asphalt FRS
I would assume to direct airflow.
FRS Justin is offline
Old 05-30-2015, 01:35 AM   #535
Captain Snooze
Drives: Red Herring
Are you trolling? From the very post above yours:
Old 05-30-2015, 01:43 AM   #536
Captain Snooze
Drives: Red Herring
The bellhorns serve a different purpose from these:
Blu-by-U (05-30-2015), cdrazic93 (05-30-2015), civicdrivr (05-30-2015)
Old 05-30-2015, 02:16 AM   #537
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
No, I haven't been following that closely.
But I was thinking more like this.
Shark-skin surfaces for fluid-drag reduction in turbulent flow
DOI: 10.1098/rsta.2010.0201
Of course, there are no scales here-- no trailing edges, so I'm not sure if it would work. @eric6 and @NotEric6, have you run any simulations?
*question everything*learn something*answer nothing*
lamawithonel is offline
The Following User Says Thank You to lamawithonel For This Useful Post:
FRS Justin (05-30-2015)
Old 05-30-2015, 02:34 AM   #538
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
You intake temps probably sky rocketed at cruising/idle speeds but at WOT I would be willing to bet they were close to what they were before. I could be very wrong though. Properly designed plastic pieces are extremely expensive like you said. Most of that cost is in tooling though..
Bingo... Since I'm sure most of us drooling here drive our cars on the street too... We do need to take that into consideration
And yep, tooling costs are the issue. I think it's fairly easy to tweak your design for plastic upper plenum bits, but meh.
DocWalt is offline
Old 05-30-2015, 03:16 AM   #539
Calum
That Guy
Drives: 2013 asphalt FRS MT
These are headed my way to test. Using logs and virtual dyno I should be able to deduct which set is best for NA and go to the dyno with that set. Please be patient as we are all dying to know how it does as well .
I wasn't expecting such small differences in height. How much do you expect those to change the tuned rpm of the runners.
As its 4 in the morning and I don't feel like doing the math, I'm guessing about 100 rpm from one size to the next.
Calum is offline
Old 05-30-2015, 05:19 AM   #540
Captain Snooze
Drives: Red Herring
@NotEric6 @nelsmar
Will you be in a position to tell me/us if this manifold will be ok to run without a tune?
I appreciate it would not be optimal but for myself organising a tune takes time*.
*It gets fitted locally then book a tune 350 kms away,
organise the wallet, organise time off from my work, the wife's work, stay 2 or 3 nights, yadda yadda.
Old 05-30-2015, 06:24 AM   #541
FRS Justin
No I would really assume they would direct air flow. Let me enlighten you a little on air flow.
1. Everyone knows that if you have a rough surface it will cause turbulence, swirling and a bunch of other problems I am not going into I suggest researching port and polishing to get a better idea
2 Cylinder ports and intake ports are reshaped to enhance flow for obvious reasons once again do some research.
3 If you have a surface that is too slick air will tumble and not follow the port design resulting in hp loss Trust me I found out the hard way. I had to remove the heads and rough up the port and presto 20hp SO before you jump to trolling ask a question I'm not perfect only human and due to make a mistake from time to time but never a troll
Good day sir
Old 05-30-2015, 07:25 AM   #542
Captain Snooze
Drives: Red Herring
No worries
Old 05-30-2015, 07:45 AM   #543
FRS Justin
No worries
Cool Brother
Old 05-30-2015, 08:07 AM   #544
raven1231
Members of this forum patient ? looking good though guys!
raven1231 is offline
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
Blu-by-U (05-30-2015), civicdrivr (05-30-2015)
Old 05-30-2015, 08:46 AM   #545
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Boundary layer is good. A little rough flows better than mirror polished.
themadscientist is offline
The Following User Says Thank You to themadscientist For This Useful Post:
abraxis (05-31-2015)
Old 05-30-2015, 11:31 AM   #546
churchx
churchx's Avatar
Drives: 2014 GT86
Laminar flow usually flows better & with less resistance, then turbulent one. Though i don't know if that's the case here, who knows, maybe more turbulent air in intake might somehow help fuel dissipation in air, or not that applicable here with on-off pulsating flow depending on cylinder cycles and cams open/closed. Only experiments may tell, but my bet that mirror finish might be slightly better .. but will that be enough for extra work/costs?
churchx is offline
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
