View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 05-28-2015, 04:10 PM   #407
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
@King Tut
Add me to the list...
AVO Turbo Kit - full 3" catless exhaust
-Ecu Controlled boost 10-15psi
-Overboosted to 22psi in 5th gear on the highway and developed a knock (all vacuum lines intact)
-23,000km with no issues up until this
Sucks to hear about this... I really admired how your car was doing... I hop I don't encounter any issues like this with my car
Astroboy is offline   Reply With Quote
Old 05-28-2015, 05:29 PM   #408
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
wasn't going to read through 19 pages to see, if i made the cut for blown engines.
I can account for two FA20s going to pieces. One at 14psi and the other one at 10psi. Both condensed their rods into nothingness, broke them, and hammered their way out the block.
Based on my observation, these engines are not designed for the boost, period. Not lets run less boost, your tune was garbage, you got bad gas, your girlfriend was in the car, etc. They aren't designed for it. If you want to do it right, build it. Forged this and forged that.
Or you can weigh the options, you pop your engine, it catches fire, and your fr-s / brz burns to the ground. Even if it doesn't, you're out of $3000. Buy a new engine instead, and that's $5000 or more.
Take it from me, GO BUILT, then GO BLOWN !
killerkid08 is offline   Reply With Quote
Old 05-28-2015, 11:51 PM   #409
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
This engine was actually designed for boost. The pistons were not. The rods are plenty strong.
The Following User Says Thank You to Reaper For This Useful Post:
ATL BRZ (05-29-2015)
Old 05-29-2015, 12:24 AM   #410
killerkid08
Cool Stuff
Drives: Cool Car
You sir are so wrong its funny. 2 engines, several condensed rods. Twisted, broken in half, rattling in my oil pan, and coming up through my block. I can speak from my experiences that the rods failed twice in a row.
Old 05-29-2015, 12:30 AM   #411
Billion
Drives: 2013 Toyota 86
Who did your tune?
Billion is offline   Reply With Quote
Old 05-29-2015, 08:57 AM   #412
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
@Reaper is actually right as he has accumulated tens of thousands of miles on high boost+E85 with stock internals. You have bad luck or a bad tuner, or both.
Originally Posted by Billion View Post
Who did your tune?
I have a feeling the answer to this will be very revealing.
ATL BRZ is online now   Reply With Quote
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
Astroboy (05-29-2015), civicdrivr (05-29-2015), raven1231 (05-29-2015), shifter907 (05-29-2015)
Old 05-29-2015, 11:34 AM   #413
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Who tuned the car and do you intend to let them blow your forged motor as well?
Old 05-29-2015, 11:40 AM   #414
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I suspect a garbage tune, and your girlfriend was probably in the car.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Old 05-29-2015, 12:22 PM   #415
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Your tune blows...
engines.
BOOM!
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following 2 Users Say Thank You to Phantobe For This Useful Post:
Astroboy (05-29-2015), raven1231 (05-29-2015)
Old 05-29-2015, 02:18 PM   #416
Reaper
Reaper's Avatar
Drives: violent
Rods are plenty strong it's the pistons that break. I've seen astronomical hp made on stock rods with good pistons.
Astroboy (07-29-2015)
Old 05-29-2015, 03:23 PM   #417
Illuminaughty
Drives: 2013 Subaru BRZ Limited 6MT
So is it usually a melted piston that takes the rod with it? I've seen some builders swap out rods and not pistons, claiming that the stock pistons are just fine. When I decide to bump the power up and get forged internals I planned on dropping new pistons in either way, since I'll already have the bottom end apart and pistons really aren't that expensive in the grand scheme of things.
Illuminaughty is offline   Reply With Quote
Old 05-29-2015, 03:24 PM   #418
Reaper
Reaper's Avatar
Drives: violent
Stock pistons are very very thin at the wrist pin and not fully boxxed. An over rev alone can pull the wrist pin out of the bottom of them. Stock rods are strong.
The Following 3 Users Say Thank You to Reaper For This Useful Post:
Astroboy (07-29-2015), civicdrivr (05-29-2015), Illuminaughty (05-29-2015)
Old 05-29-2015, 05:26 PM   #419
killerkid08
Cool Stuff
Drives: Cool Car
My tunes were provided by FA20Club and Visconti. (Whether one of these tuners or both is garbage is possible)
I don't think the pistons were the issue on my failures, though i can report, i have looked through my initial engine's teardown photos to find one piston had melted down. The second engine though had sound pistons, and wavy and snapped rods. I've got chunks of block that i keep in a baggy on my desk as a reminder. Gotta beat myself up sometimes.
1 for the rods ----- 1 for the pistons
For the guy who said my GF was in the car, my wife actually was during one of the runs. The hilarity that ensued after a dinner and night out, followed by a highway pull between exits, and ended with the thorn in her side exploding was glorious for one of us.
Not trying to start a war here, just delivering my two cents based on two junk engines. I'm technically on my fourth FA20 now, between 2 FR-S's.
Old 05-29-2015, 05:50 PM   #420
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Full Blown kit with garrett 57 trim.
Full 3" exhaust
MAP Oiler Cooler
Full Blown Large Aluminium Radiator
AZ/CA/NV 91 oct
100% stock long block
399whp/329wtq @ 11.5psi 3rd gear 4500ft elevation, 85 degree ambient air temp
Motor is doing great! at 6k miles, 5k have been boosted.
Tuned by Mayhem Tuning
Kuros is offline   Reply With Quote
The Following User Says Thank You to Kuros For This Useful Post:
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
