Old 05-27-2015, 08:19 PM   #1
donoman
donoman's Avatar
Drives: '13 FR-S
Contemplating new ARP studs ... anyone with bad experiences?
After breaking studs and then reading on on the forum, looks like the studs that came with this car are crap. I'm now looking at making a $200 investment on new studs and lugs. Not to mention the time investment of installing the damn things. Few questions for you guys:
1) Anyone still have problems with ARP studs?
2) Anyone with brake ducting have studs break?
3) Anyone with BBK have studs break?
4) Anyone ever break a REAR stud?
My hypothesis is that the front studs overheat from braking. I'm not sure if it's worthwhile to go the studs route or just go and grab a BBK/brake ducting to lower temps.
Problem with brake ducting is that it's not something that I really am looking forward to installing on the car, whereas a BBK has extra bling factor
donoman is offline   Reply With Quote
Old 05-27-2015, 08:25 PM   #2
CSG Mike
CSG Mike's Avatar
ARP is the tried and proven solution
1- nope
2- yup
3- yup
4- yup
Ultimately, it's your responsibility to make sure you're not cross threading studs.
We have ARP studs and lug nuts in stock and ready to go.
Old 05-27-2015, 08:55 PM   #3
renfield90
The Stig's German cousin
The ARP studs are worth every penny. Zero problems with mine, MANY wheel changes.
Old 05-27-2015, 09:03 PM   #4
donoman
donoman's Avatar
Drives: '13 FR-S
Mike I just searched your website for FR-S and the studs do not show up.
Old 05-27-2015, 09:26 PM   #5
CSG Mike
CSG Mike's Avatar
@CounterSpace Garage....
PM me and I'll have it invoiced to you directly.
Old 05-28-2015, 01:07 PM   #6
donoman
donoman's Avatar
Drives: '13 FR-S
Anyone else?
Old 05-28-2015, 01:09 PM   #7
superpenguin
Some Random
superpenguin's Avatar
Drives: 2015 FRS
I'd love to go ARP, the only thing stopping me right now is the cost as I don't have acess to a press and I can't really have the car on jacks for a couple days while I drop the hubs off at a machine shop
But there's a reason just about every serious track car you'll see has gone over to ARP studs. They are the industry standard, period.
"You see, nursie, men love women. But even more than that, men...LOVE...CARS!" - Rush
2015 FRS NASA AZ #550
superpenguin is offline   Reply With Quote
Old 05-28-2015, 01:50 PM   #8
donoman
donoman's Avatar
Drives: '13 FR-S
How hard is the install? The hubs are fairly easy to remove as I just did it this weekend. I don't think the front hubs need to come off, but the rears do. Alternatively I've read that non-extended studs don't require hub removal so I may have them machined down.
I have a 1-Ton press at work I can use. I also have this stud installation tool below. Do you think this is enough to get the job done? I can't see pressing the studs in straight but I do think it will be OK with this "puller" tool.
[ame="http://www.amazon.com/Lisle-22800-Wheel-Stud-Installer/dp/B000ETUD22"]Amazon.com: Lisle 22800 Wheel Stud Installer: Automotive[/ame]
The Following User Says Thank You to donoman For This Useful Post:
CSG Mike (05-28-2015)
Old 05-28-2015, 01:52 PM   #9
gramicci101
Off Topic
Here's a DIY thread:
http://www.ft86club.com/forums/showthread.php?t=21563
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 05-28-2015, 03:33 PM   #10
wparsons
wparsons's Avatar
I can confirm that fronts can be done with the hubs in the car (remove the rotors though), and rears can definitely not. Stock studs can probably be done in the rear, but the ARP are WAY too long to have a chance of getting in.
flickr
Old 05-28-2015, 03:47 PM   #11
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Doing the rear on a Saturday wouldn't be too difficult. I used a brass hammer against the stock stud, and had someone else smack the brass hammer with a sledge. (Not hard, just enough to knock them out). Took maybe 5 minutes, then took the hub apart. Used a spacer I had to help install the ARPs. Just lubed up the spacer and lug then tightened it down. Worked great and went quick.
Old 05-28-2015, 04:18 PM   #12
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I had a bad experience with them.
I blame it partially on my lugs though. I had Kics R40 Open End Lug Nuts paired with spacers and ARP studs.
The lugs and studs went to shit after about a year or so. Granted, I took wheels on and off quite a bit for drift events and such. Also, since I'm in Oklahoma, the lugs and studs got exposed to some of the harsher weather.
If it were closed lugs, and I didn't take wheels on and off frequently, I think they would have lasted quite a bit longer.
Old 05-29-2015, 02:45 AM   #13
donoman
donoman's Avatar
Drives: '13 FR-S
Looks like i need shorter ARP studs... then I'll have the best of both worlds: easy install and less chance to strip.
Old 05-29-2015, 01:27 PM   #14
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
This...
It took me 2 hours to do the whole car (and I did a suspension swap at the same time). I used washers and an old lugnut method to put new ones in. You can lightly tap the oldones out with a hammer. (keep wheel bearings in mind and take your time instead of smashing them out)
I had Ichibans and 3/10 of them spun in the hub. That was an expensive lesson. Only use ARP.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
At what point do we need to upgrade head studs and main studs? Amir Ghadiri Forced Induction 5 03-03-2015 11:13 AM
Experiences with CPO? heisenbergbrz BRZ First-Gen (2012+) — General Topics 20 04-22-2014 09:44 AM
Experiences with plasti dip Chen Northwest 24 10-30-2013 12:18 AM
Contemplating buying used BRZ with tons of mods but is it worth it? Sebaru BRZ First-Gen (2012+) — General Topics 48 07-19-2013 10:25 AM
Contemplating Raven Purchase Please Advise steve87j Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2012 09:44 PM
