Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 05-27-2015, 08:11 PM   #15
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Originally Posted by weedtank View Post
Having the squeaking issue too and it sounds like it's coming from inside the cabin
Yes it will sound like that. lube up the fork in the picture and press the clutch like 50 times and it'll get better.... eventually hahaha.
fantah is offline   Reply With Quote
Old 05-28-2015, 11:58 AM   #16
weedtank
weedtank's Avatar
Drives: Ultramarine
Can't wait to try it. Will Autozone or Pepboys have the marine grease?
weedtank is offline   Reply With Quote
Old 05-28-2015, 03:17 PM   #17
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I would think so. I bought mine at Walmart. Let us know if the noise goes away for longer than a month. I want to know how you applied yours and do the same to mine. So far, mine lasts only for 1 to 3 weeks.
Old 05-29-2015, 09:39 PM   #18
fantah
fantah's Avatar
Yeah any auto store. Its like $5.
Old 08-05-2015, 03:22 AM   #19
Holyshiba
Drives: 2013 FRS
Originally Posted by Cooperdh View Post
It will most likely keep coming back like mine did. If you are still under warranty, ask them to do a courtesy service. They had to pull out the tranny to get to the fork I was talking about it my recent post. They wanted to initially charge me over $1200 because of the labor. There must have been other issues reported because Toyota USA covered the charge.
So what actual work did servco do to fix the problem? They only lubed the clutch fork? Has your squeak come back at all? Did they completely rule out the throw out bearing? None of the work was covered under warranty but Toyota USA covered the work done? Thanks in advance. I just got the squeak today...
Holyshiba is offline   Reply With Quote
Old 08-05-2015, 03:24 AM   #20
Holyshiba
Drives: 2013 FRS
do you still regularly lube the clutch fork or was it just a one time and done sort of thing? Thanks in advance.
Old 08-05-2015, 03:43 PM   #21
Sigh-on-Rice
He's not from Hawaii.
I saw your posts on another thread too.
I'll let you know next week Monday who in Servco you should talk to about this problem. If you talk to the wrong person, they will charge you $600-$700 just for diagnosis (not including fixing cost). If you talk to the right person, they will fix it under warranty. Is your car still under basic warranty?
Old 08-05-2015, 09:56 PM   #22
Holyshiba
Drives: 2013 FRS
Yes, car is almost 2 years with almost 17k miles. Thank you! I could feel it today when I was driving home today, kinda a stiff push back when fully depressing the clutch.
Old 08-05-2015, 10:17 PM   #23
Sigh-on-Rice
I know exactly what you're talking about. You can feel it on your foot. When I talked to them, it sounded like this issue is covered under the basic warranty and not the powertrain warranty. Toyota on the mainland seems to be covering it under the powertrain warranty. Not sure if Servco is ok to make their own rules, but I didn't go any further since mine is covered under warranty.
Old 08-05-2015, 10:21 PM   #24
Holyshiba
Drives: 2013 FRS
Is this still your DD?
Old 08-05-2015, 10:29 PM   #25
Sigh-on-Rice
Yes, still my DD.
Old 08-06-2015, 09:46 PM   #26
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Drives: 2013 Scion FR-S- lava
If you are having the squeaking issues and it continues to come back, I would go to Toyota and ask to speak to the service manager directly. Tell him you have spoken to others about this issue and the only fix was to take apart the tranny and lube the fork or whatever part it is they call it. It was not the bearing in case they ask. After the service guy was done with it, he admitted that it was bone dry and would have caused major problems had they not performed this service. Mine wasn't just squeaky though, there seemed be a sort of crunchy feel to the clutch when depressed. Ask them to submit a request to Toyota to cover the service. Good luck. BTW, the clutch sill runs like a champ.
Cooperdh is offline   Reply With Quote
Old 06-29-2016, 01:25 PM   #27
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Its exposed. No tools needed. Just wipe away the old gunk with a towel and smudge on the new lube. 30 secs. The logest part of this process is going to the store and buying haha. Ill include pictures in next post
where did u lub?
Should I spray all the way down to inside of dust boost?
bhbnuckle is offline   Reply With Quote
Old 07-01-2016, 10:11 PM   #28
fantah
fantah's Avatar
Originally Posted by bhbnuckle View Post
where did u lub?
I just rub the exposed metal, then step on the clutch about 50 times. It gets better the more you do it.
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 10:24 PM
Squeaks when shifting gears/happens every 15 or so seconds while holding speed Simon99 Issues | Warranty | Recalls / TSB 10 10-11-2014 03:54 PM
door handle/pull squeaks NRG x FRS Issues | Warranty | Recalls / TSB 1 11-27-2013 09:38 PM
I knew about cabin squeaks before I bought the car but... NOMNOM Issues | Warranty | Recalls / TSB 10 05-23-2013 05:00 PM
