Old 05-27-2015, 03:02 PM   #15
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by Byrd View Post
Do you think a engine oil cooler and mishimoto radiator / hose / caps will be cool enough for the AT?
For spirited drives it would probably do, but for track, no. I installed a bar and fin type AT cooler, went that route because I did not want to block anymore airflow to the radiator. If you want more info, check my build thread. For spirited runs tranny temps hover around 90C-100C. But during my last trackday, temps rose to 130c-140C. That was on a 40C day, and the cooler was not getting enough airflow. I'm switching to a bigger B&M AT cooler and will find ways to mount it at front.
A larger radiator will help, but in track situations when oil/water temps are running hot, it won't help the tranny as much.
Tye300 is offline   Reply With Quote
Old 05-27-2015, 04:10 PM   #16
LS1M
Drives: 2015 BRZ
B&M makes a trans cooler (70297) with its own fan if you're running out of real estate in front of the radiator. I put a similar one on my Camaro as a stand-alone, bypassing the radiator completely. Never saw temps over maybe 175F on hot Texas days.
LS1M is offline   Reply With Quote
Old 05-27-2015, 04:39 PM   #17
Koa
Originally Posted by DAEMANO View Post
Get catch cans and oil cooler. If you end up with a lot more power, you might need more tire too and in that case, perhaps more brakes. Suspension mods not required, but are more of a nice to have at this point.
Driver mods > tires > Suspension mods > power mods
YMMV
The Following 2 Users Say Thank You to Koa For This Useful Post:
Dream20b (05-29-2015), themajesticone (05-27-2015)
Old 05-27-2015, 04:54 PM   #18
themajesticone
themajesticone's Avatar
Drives: '13 UM86
YMMV
Absolutely true. I was at Laguna Seca this past Saturday and someone ran a 1:48 lap time in a lightly modified frs and a 1:44 lap time in a heavily modified + turbo FRS the same day.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
The Following User Says Thank You to themajesticone For This Useful Post:
Koa (05-28-2015)
Old 05-27-2015, 05:35 PM   #19
Tye300
Tye300's Avatar
I got the 70268. I also purchased the Laile front beam brace and will try to figure out how to fit my intercooler, oil cooler, AT cooler, and radiator adequate airflow.
Old 05-27-2015, 11:12 PM   #20
CSG Mike
CSG Mike's Avatar
Originally Posted by themajesticone View Post
Absolutely true. I was at Laguna Seca this past Saturday and someone ran a 1:48 lap time in a 100% stock FRS. I believe a modded out, turbo FRS got a 1:44 lap time the same day. Conclusion... the driver is hands down the most deciding, important and dominating factor.
Stock class, but not 100% stock
Old 05-27-2015, 11:17 PM   #21
CSG Mike
CSG Mike's Avatar
Automatic Transmission
I'm going with either the Jackson Racing or Vortech. My goal is not to be the best on the track, but to have a blast without breaking or overheating. I'll make it easy and show you my list of mods; If any of these mods are extras and not really needed for the longevity of my engine please let me know, as well as suggesting other parts.
***Maximum of 6 track days a year + beginner autocross + shit loads of mountain runs***
Currently Own:
-Perrin Lightweight Crank Pulley
-Borla catback Exhaust
-Borla fp / op (catless)
Going to buy:
- Bilstein B14 Coilovers
- Flex Fuel Kit
-Stage 1 or 2 Brake package (ft86speedfactory)
-Catch Can
-Sway Bar
-Oil cooler that comes with Supercharger
&& get everything ECUTEK tuned of course
I believe I'm the most qualified individual here to answer this.
- Dump the crank pulley. It's not needed.
- Do either the coilovers or the supercharger, but not both at the same time. One change at a time to learn the change
- Get the Flex Fuel kit from the get go, so you don't need to tune twice.
- Don't bother with a "staged" brake package. They're glorified street setups that do little to nothing to help you on track. Instead, get yourself a set of real track pads and good fluid. Unless you care only about your mod list, those packages are a waste of money.
- Catch cans are a must for a track/canyon car with FI.
- Sway bars are fine tuning tools. Hold off on these until you've got suspension on your car, and have identified what exactly you want to change about the behavior of the car.
- Oil cooler is 100% mandatory for any car driven hard.
We can package everything together for you if you're interested. I don't believe anyone on this board has our amount of experience combining a track/suspension/fi setup for mixed street/track/spirited duty.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Chad86 (06-06-2015), Jmonty (05-30-2015), midnight23 (05-28-2015), themajesticone (05-27-2015)
Old 05-27-2015, 11:29 PM   #22
themajesticone
Drives: '13 UM86
Oops misspoke! Were tires different? still impressive all together nonetheless
Old 05-27-2015, 11:37 PM   #23
CSG Mike
CSG Mike's Avatar
Tires, alignment, pads, header, tune. Not sure if anything else, but just what I noticed from a cursory glance.
Old 05-27-2015, 11:46 PM   #24
themajesticone
Drives: '13 UM86
Oh gotcha I didn't realize header and tune were in stock class unless I heard wrong about the class
Old 05-27-2015, 11:53 PM   #25
CSG Mike
CSG Mike's Avatar
http://www.ft86club.com/forums/showt...ighlight=86cup
That'll help
themajesticone (05-28-2015)
Old 05-28-2015, 12:15 AM   #26
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
Ironically, the guy who did the 1:44 was the same guy who ran the 1:48 in his friend's car
ImperiousRex is offline   Reply With Quote
The Following 2 Users Say Thank You to ImperiousRex For This Useful Post:
CSG Mike (05-28-2015), themajesticone (05-28-2015)
Old 05-28-2015, 12:23 AM   #27
themajesticone
Drives: '13 UM86
didn't even realize but that still solidifies my point haha
Old 05-28-2015, 02:18 AM   #28
CSG Mike
CSG Mike's Avatar
Because he's a #BOSS
VORTECH SUPERCHARGER KITS!! READY TO SHIP F-T Forced Induction 4 12-03-2013 01:00 AM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 12:07 PM
Evasive Breaks 405WHP and 306TQ on HKS Supercharger and getting ready for Pikes Peak! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 09-05-2013 01:09 AM
supercharger ready this year for FR-S? carbonBLUE Engine, Exhaust, Transmission 11 04-04-2012 02:56 PM
