Old 05-17-2015, 11:10 PM   #281
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
I have a question, if I flash e85 tune and after when I get pump gas, I must reflag back to pump gas tune?
2. If I want to flash e85 again, did ECU will learn e85 again?(no high rev,etc)
ZHoward is offline   Reply With Quote
Old 05-17-2015, 11:14 PM   #282
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Whats up guys Anyone want to share there turbo base map for the oft I plan on going turbo soon just wanted to get an idea of what its gonna look like since I'm going to build my kit not buy one and want to keep the oft. Thanks guys
el-92 is offline   Reply With Quote
Old 05-17-2015, 11:15 PM   #283
ZHoward
ZHoward's Avatar
OFT has turbo tune? LOL, I only see supercharged tune
Old 05-17-2015, 11:17 PM   #284
el-92
el-92's Avatar
Yeah the SBD turbo kit I think there's one more plus I oft is going to offer a kit soon not 100% sure though.
The Following User Says Thank You to el-92 For This Useful Post:
ZHoward (05-17-2015)
Old 05-17-2015, 11:20 PM   #285
ZHoward
ZHoward's Avatar
Cool, thanks, than we don't need to flash Ecutek for 1000$$$$...
Old 05-17-2015, 11:24 PM   #286
el-92
el-92's Avatar
I wouldn't save your money for parts and tires
Old 05-17-2015, 11:41 PM   #287
steve99
Drives: FT86
see here
http://www.ft86club.com/forums/showthread.php?t=70073
The Following 2 Users Say Thank You to steve99 For This Useful Post:
D_Thissen (05-18-2015), el-92 (05-18-2015)
Old 05-27-2015, 07:01 AM   #288
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Got my second hand OFT yesterday and downloaded the latest OTS tunes on to the device. Then in my infinite wisdom I loaded up the wrong CAL .bin file (B00 vs B001) for 93 Stage 1.
Dumb question I think, but safe to say I should be flashing back to stock until I can load the proper CAL file at home? Im not sure what the differences are between them all and my google-fu wasn't much help.
I drove to work on this file and it was only when I got here and started playing with the 'Info' section of the OFT that I realized the error.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 05-27-2015, 07:10 AM   #289
steve99
Drives: FT86
No need to do anything its all good.
OFT will not let you load/flash incorrect calid, it knows your original calid
Read the first post.
OFT V2xxx tunes are based on latest compatible rom for your car in your case stock rom would be B00C/D so OFT will only let you load the B00C/D rom however this tune will actually be based on the B01C/D rom so you get latest factory revision plus the tune enhancements
PollosHermanos (05-27-2015)
Old 05-27-2015, 07:14 AM   #290
PollosHermanos
Open Flash Tablet - OFT TIPS Trick’s & FAQ
Thanks Steve - I saw the note in that 1st post and I think I'm just being overly cautious since it's my first go-around. I've always managed to find new ways to work around even the most idiot-proof systems
EDIT: A response in 10 minutes at 7:10AM. Talk about service!!
The Following User Says Thank You to PollosHermanos For This Useful Post:
steve99 (05-27-2015)
Old 05-27-2015, 12:11 PM   #291
FISHBURGLAR
Drives: whiteout fr-s
HEY I HAVE ofh with motive front pipe uppipe and non resonated perrin 2.5. running oft 93 octane stage two uel. have changed the cold start for quicker cold start. also have dropped the launch control. when i start the car in the morning only, i sometimes get code P0462 and P050B ... any ideas as to why i can get these two codes together?
FISHBURGLAR is offline   Reply With Quote
Old 05-27-2015, 06:13 PM   #292
steve99
Drives: FT86
Its normal to get P050B after making cold start mods, just disablec it with romraider
P0462 indicates you may have problems with the fuel level sender in tank check \clean plugs on sender or replace sener unit. should be covered under warantee
Old 05-27-2015, 06:28 PM   #293
FISHBURGLAR
hmm everything was fine until stage two tune came on. maybe oft fried it? or just a confusion? possible to be a batch of bad gas? after a fillup the code came on.
Old 05-27-2015, 06:59 PM   #294
steve99
Drives: FT86
P0462 is a hardware issue nothing to do with tune
P050B you will need to disable else it will keep coming back its cold start ignition performance due to quiet start mods, disable it and flash new tune that will also reset ecu and clear the other code, if the P0462 keeps coming back then it likely their is a problem with fuel tank sender unit.
FISHBURGLAR (05-28-2015)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
