Old 02-24-2015, 02:29 PM   #155
speeddemon
Drives: Scion frs
This might be a stupid question but how to you torque the filter to spec? In the past with other cars I have just gotten it hand tight and that was fine.
speeddemon is offline   Reply With Quote
Old 02-24-2015, 03:43 PM   #156
Koa
hand tight is fine..
Old 02-24-2015, 04:29 PM   #157
Marrk
Drives: Honda Fit
^As Koa said, usually hand tight is fine. My Honda filters have instructions on them as to how far to turn the filter beyond hand tight. In any case, we are not talking about a lot of torque here.
EDIT: You can always use a torque wrench on it if that makes you feel more comfortable about things.
Marrk is offline   Reply With Quote
Old 05-26-2015, 04:53 AM   #158
GT86_PRAGUE
Drives: GT86
I have a noob question, can someone post a photo of a dipstick and marked levels where should oil be?
GT86_PRAGUE is offline   Reply With Quote
Old 05-26-2015, 06:46 AM   #159
CoupedUpSubie
Drives: 2013 BRZ Limited
Full is at the upper hole. As our oil is fairly light it can be hard to read because it doesnt hang onto the stick. I recommend pulling the dipstick and putting it against a paper towel. The oil will show on the paper towel easily.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Chaetagnath (05-26-2015)
Old 05-26-2015, 07:34 AM   #160
GT86_PRAGUE
Drives: GT86
I dont have problem to identify where the oil is, I have problem with knowing where it should be. Also you measure this on bottom side on cold car?
Photo would be awesome.
So I suppose oil has to be between those two holes, close to the upper one?
Old 05-26-2015, 10:34 AM   #161
CoupedUpSubie
Yes, between the two holes.
GT86_PRAGUE (05-26-2015)
Old 05-30-2015, 02:06 PM   #162
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Even though it has been a while since Toyota updated their part number for the FRS oil filter. I do not see the part number being post here. The part number is 90915-YZZS1 and it is only used by the FRS.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
Marrk (05-30-2015)
Old 07-30-2015, 02:57 PM   #163
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Will the Dimple Magnetic Drain Plug work with factory crush washer?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-11-2015, 11:32 AM   #164
Westen
Native Texan
I tried to change my oil this morning and for the life of me I can't get the drain plug out. I'm using a 14mm socket wrench, it seems to fit fine, but I can pull on the nut so hard that the rest of my body moves and it still won't budge. Any advice on how to get this thing out?
Also, I'm putting in 5W-30 motor oil instead of OW-20. The manual says this is fine and so do other people I've heard from. Anyone ever have any bad experiences with this?
Westen is offline   Reply With Quote
Old 04-09-2016, 09:09 AM   #165
Delfin
Delfin's Avatar
Drives: 2019 Toyota 86 GT Manual Halo
I'm posting just to bump. Someone with knowledge please help this member out.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Delfin is offline   Reply With Quote
Old 02-23-2017, 11:39 AM   #166
p1l0t
p1l0t's Avatar
Ummmm the manual says you can put 5W-20 every other time. Not 5/30...
Old 07-21-2017, 01:22 PM   #167
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Stupid noob question but what is the factory oil drain plug torque specs? For some reason I'm having a hard time finding it. I'm pretty sure it's 33ftp but I'd like to make sure. Thanks in advance.
DandoX is offline   Reply With Quote
Old 07-21-2017, 01:28 PM   #168
DandoX
Senior gif poster
DandoX's Avatar
Found it, brain fart when searching:
Originally Posted by sparks View Post
Tightening torque=42N·m { 428kgf·cm} {31.0ft·lbf}
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) — General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) — General Topics 8 04-08-2012 02:06 PM
