Old 08-23-2014, 02:12 PM   #15
SOAZ
Drives: pinto
Originally Posted by Silver Ignition View Post
I will give credit when credit is due. I essentially used @that_guy 's idea in a slightly more crude fashion.
I don't have access to a fancy machine shop and all that jazz, but I do have a welder. So where he had a one-piece aluminum setup, mine is 3 pieces and made of steel.
So here's what I started with…I purchased two new tow hooks from my parts department
So, did you grind of sand down the end of the tow hook bar to get it inside of the tubing or is it really just welded right to the end of it?
SOAZ is offline   Reply With Quote
Old 08-23-2014, 03:31 PM   #16
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
It's got about 1.5" of overlap. I welded the circumference of it and drilled two holes on opposite sides to spot weld it also. They're strong.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-23-2014, 10:40 PM   #17
SOAZ
Drives: pinto
Agreed. I am going the same route and just wanted to make sure it was sleeved a bit. (I think it should be for strength and was thinking about a spot weld as well, but my buddy thinks it would be strong enough with just the weld itself holding it on the end with no overlap at all.)
I win.
Nice work and thanks for the idea, can't wait to be able to take my bike around.
Old 09-19-2014, 12:46 PM   #18
SOAZ
Drives: pinto
Copied your set up basically. Used an m20 bolt welded into the end. I am going to cut mine down. I went big, but I think in order to leave it attached more often I may make a short version for 1 bike and keep these for 2. We'll see.
Thanks for the idea!
Old 09-19-2014, 12:48 PM   #19
Silver Ignition
APEXHNTR
AWESOME dude nice work! I actually considered making a second set of tubes, just longer to carry 2 bikes...
#1867 of 2500
Old 09-19-2014, 01:06 PM   #20
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Damn that thing looks like a serial shin killer.
Like the idea of using one of my old roof racks on the car though.
murdoc is offline   Reply With Quote
Old 05-26-2015, 04:24 AM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I only managed to get a 1" galvanized steel tube with 1.6mm wall thickness. Do you think this will be strong enough to hold a dual suspension mtb?
@SOAZ @Silver Ignition
Fizz is offline   Reply With Quote
Old 05-26-2015, 08:28 AM   #22
cycleboy
Drives: 2013 Scion FR-S - Argento
AIR9 with Niner carbon fork? If so, we're MTB twins! Well, mine's blue with a bare carbon fork, but almost the same. I love my Niner! It takes me back to my early days of MTB before suspension existed. Climbs like a goat and descents require more skill.
In other news, it looks like you guys can use these things as spikes to kill zombies when the apocalypse comes.
cycleboy is offline   Reply With Quote
Old 05-26-2015, 10:37 AM   #23
SOAZ
Drives: pinto
It's actually a SIR9. I'm addicted to steel. I love the flex it has! (Until I break the frame) Niners have the best geometry, I've found nothing that rides like them in a hard tail. :-)
If it's galvanized "pipe" I would be worried. Tubing is meant to have strength and pipe is only made to carry something within it without leaking. They're made very differently and have varying wall thickness. I would just make sure it is in fact tubing (Cold rolled mild steal at least) and what the wall thickness is before trusting it with your bike.
Old 05-26-2015, 11:33 AM   #24
cycleboy
Nice! I considered the SIR before deciding I wanted to go Al/Sc alloy.
I agree steel rides great! Back in the day I rode a Wicked Fat Chance, then a Gecko Genesis (which I still have and will fix up someday).
Old 05-27-2015, 03:59 AM   #25
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hmm....do you think the Yakima crossbars will slide over the tow hook shaft? If so that would be ideal, since those bars should be strong enough and comes with a nice thick vinyl coat to help the bike carrier mounts grip better.
Old 05-27-2015, 11:37 AM   #26
SOAZ
Drives: pinto
I think they would if you extend the tow hooks. If you take your factory tow hook and screw it into place it doesn't stick out very much. I think the bike would be too close to the car. If you extend it like I did then I think using any type of tray carrier could be made to work with a little messing around.
Old 05-27-2015, 08:25 PM   #27
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yeah that's what I meant, extending the factory towhook like yours, but using the Yakima round crossbars instead of other steel bars. But those yakima bars aren't exactly cheap though...
Custom Tow-Hook Bike Rack that_guy Cosmetic Modification (Interior/Exterior/Lighting) 280 09-03-2023 11:36 AM
anyone fit a bike rack yet? earthsscum BRZ First-Gen (2012+) — General Topics 108 05-26-2019 11:39 AM
Rear Mounted Bike Rack?? Jkbarnes3 Scion FR-S / Toyota 86 GT86 General Forum 37 03-06-2016 10:24 PM
best bike rack ever! SeanBlader BRZ First-Gen (2012+) — General Topics 28 03-31-2014 09:45 AM
Bike rack for BRZ brzbiker BRZ First-Gen (2012+) — General Topics 1 05-27-2013 05:35 PM
