Old 03-19-2015, 04:16 PM   #239
androopoo
androopoo's Avatar
Drives: 2014 Lighting Red BRZ
Originally Posted by tigermack View Post
Yeah, it's like all over the thread...
yeahh its hard to tell between the titan and hyper :P just wanted some clarification i dont think anyones labeled theirs
androopoo is offline   Reply With Quote
Old 04-04-2015, 07:37 AM   #240
steveholt
Drives: 2015 BRZ Limited 6MT
Originally Posted by F1point4 View Post
I like technical data. I like photography. Here is a thread about both. Enjoy
Goals:
Stay Functional
Max Grip
Lower weight than OEM combo.
Went with:
WedsSport TC105N 17x9 +35 square setup (Thanks @RavSpec)
Hubcentric Rings 65mm to 56mm
Dunlop Direzza Sport Z1 Star Spec 245/40R17 (Thanks Discount Tire)
Stock TPMS sensors
Stock Suspension
Factory Geometry settings
The 17x9 +35 in a 5x100 setup is a limited run for the 86. Thus official weight is unlisted on the Weds website. Here is what my human scale told me.
20120921-TC105N_Z1StarSpec-17 by VictorN07, on Flickr
Sports Utility Vehicle. I don't have a picture of when I had the OEM wheels in my car, but they fit dammit
20120921-TC105N_Z1StarSpec-2 by VictorN07, on Flickr
The setup. Discount Tire was cool about letting me be in the garage and learning about what they do. I was super happy to be there cause they almost put on my wheels with impact tools. Nope!
20120921-TC105N_Z1StarSpec-16 by VictorN07, on Flickr
Discount Tire told me they'd dismount the OEM tire and pull the TPMS sensor to transfer to the new setup as part of the deal. Here is a picture of the sensor. It is attached to the valve stem.
20120921-TC105N_Z1StarSpec-14 by VictorN07, on Flickr
20120921-TC105N_Z1StarSpec-15 by VictorN07, on Flickr
I don't know how calibrated my scale was. What was important to me was the difference in weight. Stock wheels are 40.6 lbs. TC105N with Star Specs were 42.4. Damn.... Anyway it is pretty good for what I'm putting on. Yeah, I brought a scale with me to Discount Tire. Hah
20120921-TC105N_Z1StarSpec-18 by VictorN07, on Flickr
20120921-TC105N_Z1StarSpec-19 by VictorN07, on Flickr
Thoughts so far
I drove 200 miles so far on this setup. Haven't taken it to a track yet. It definitely gives me more confidence in what I'm doing. Just grip for miles. Since the wheels now weigh more, I can definitely feel the sluggishness at start. Brakes fine. I figure a headerback exhaust may balance out the unsprung weight gain. The Star Specs do have a different audible characteristic. I find the OEM Michelins to grumble and have a deeper tone. These Star Specs definitely howl, but it's not annoying. I could probably fix some of that with sound deadener. For rubbing, I believe that other people threw on 17x9 +42s and they fit fine so the +35 offset should be good. I haven't felt anything bad in my driving so far.
In terms of looks, the rear looks great. The front sticks out a little bit as the pictures below show. However, stance. I got plenty of that now. Overall it looks sorta hokey, but I love the way it drives and that is what counts. Now for photos; please enjoy them as much as I did taking them.
20120922-TC105N_Z1StarSpec-16-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-1 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-22-Edit by VictorN07, on Flickr
Front
20120922-TC105N_Z1StarSpec-30 by VictorN07, on Flickr
Rear
20120922-TC105N_Z1StarSpec-25 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-28 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-33-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-32-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-37-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-41 by VictorN07, on Flickr
Questions I have
If anyone would like to help me answer these quick questions, I'd appreciate it greatly
* Since my wheels stick out, I have to add negative camber if I lower it?
* What is the daily driving PSI for this setup? Discount Tire said 35psi, but I have no experience with aftermarket wheels.
* Will a headerback gain balance out the unsprung weight gain? I was just guessing up there.
did your stock tpms sensors fit flush/flat on your weds wheels? no gap?
steveholt is offline   Reply With Quote
The Following 2 Users Say Thank You to steveholt For This Useful Post:
15limited (11-12-2015), JMon85 (10-17-2017)
Old 04-04-2015, 07:45 AM   #241
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
Can anyone tell me what size hub centeric rings you are using for your current setup with these wheels ?
Pish is offline   Reply With Quote
Old 05-14-2015, 06:35 PM   #242
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by CircuitJerk View Post
Quick n dirty HDR shot to show the gap. Not much for detail but that will come after the final bits.
245/40/17 Direzza ZII's, Kics R40 lugs.
Eibach Prokit, Cusco adjustable LCA's next.
I seem to have a good amount of camber resulting in a visible 1.5" reduced contact patch on the right side. Really accentuates the stock camber. Can't wait to get an alignment after the springs so see how big the difference is.
Originally Posted by TouchMyHonda View Post
This thread makes me happy.
LOL!
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 05-25-2015, 09:45 PM   #243
cjd
cjd's Avatar
Drives: 2017 BRZ
DGM on CBS
Lowered ~1.4" (recommended settings for Tein SRC) with -3.3° front, -2.8° rear camber. 255/40/17 Bridgestone RE71-R. Pondering ordering a run of those custom centercap/centering rings.
The Following 2 Users Say Thank You to cjd For This Useful Post:
BeRZed (09-11-2015), JMon85 (10-13-2017)
Old 09-10-2015, 07:34 AM   #244
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
These take a 56mm x 65mm hub centric ring @Pish
SOOOO excited about these Weds I just picked up second hand. Took them straight to the powdercoater. Finished in a Spanish gold plus clear coat at Killer Koatings in Cincinnati Ohio. Couldn't be happier. These are 17x9+35 wrapped in 245/40r17 Hankook Ventus R-S3s. Cant wait to see these mounted on my black BRZ!
xkalelx is offline   Reply With Quote
The Following 7 Users Say Thank You to xkalelx For This Useful Post:
BeRZed (09-11-2015), JMon85 (10-17-2017), Metabrz (09-11-2015), oldlostcory (09-11-2015), Pish (09-10-2015), Plumbus (08-02-2020), Timmy_Jones (09-10-2015)
Old 01-10-2016, 12:47 AM   #245
420zn6
Pothead
420zn6's Avatar
Drives: Dark grey GT86
Finally put my wheels on
Tires are GT Radial champiro sx2 245/40/17
Needs moar low
420zn6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 420zn6 For This Useful Post:
itsibarra (01-27-2016), PMok (01-10-2016)
Old 04-19-2016, 05:11 PM   #246
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I suppose I'm the newest member with these wheels and couldn't be happier!
Specs to help others:
17x9 +35 (obviously)
245/45 Hankook Ventus V12
MachV lowering springs for about a 1" drop
Front Camber: -1.5* (SPC camber bolts in the LOWER hole)
Rear Camber: -2.0* (Au naturel)
No rubbing at all, roughly 1cm of clearance to the spring perch.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
MisterSheep (02-08-2017)
Old 04-19-2016, 07:38 PM   #247
Marat
Drives: '15 Ultramarine FR-S
Cant wait to have my weds installed. Waiting to get my coils before I do...
Marat is offline   Reply With Quote
Old 04-20-2016, 01:05 AM   #248
Kaotic Lazagna
Drives: GR Corolla
Hyper silver with 245/40/17 Continental tires
Got the Weds from Gruppe-S and tires from America's tire.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
JRRIII (05-11-2016)
Old 04-20-2016, 01:06 PM   #249
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Mine are 17x9 +25 Titan Silver version.
I'm toying with the idea of dipping them white. they look so good here:
DuMa is offline   Reply With Quote
The Following 3 Users Say Thank You to DuMa For This Useful Post:
JMon85 (10-17-2017), MisterSheep (02-08-2017), ryann.mendoza (02-19-2018)
Old 04-23-2016, 12:36 AM   #250
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Any profile pictures? What are you lowered on?
SG02WRX is offline   Reply With Quote
Old 04-23-2016, 01:09 AM   #251
ARTBRZ
Aloha!
ARTBRZ's Avatar
That would look awsome in my opinion! Especially with a red car. I'd say do it!
ARTBRZ is offline   Reply With Quote
Old 04-23-2016, 02:07 AM   #252
Kaotic Lazagna
Drives: GR Corolla
Lowered on Tein Flex Z. Completely maxed out in the front (two rings removed) and maxed out shock length in the back with half an inch to an inch (can't remember exactly) of pre-load left.
As for side shots, I didn't think of doing any, but these might suffice:
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
15limited (05-10-2016), SG02WRX (04-23-2016)
dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport
Wedssport TC105N 17x9+25 5x100 YDNA Wheels and Tires 24 04-04-2014 02:05 PM
FS: Wedssport TC105n 17x9 +25 donutfilling Wheels and Tires 19 03-26-2014 07:59 PM
Wedssport TC105N 17x9 and 17x8 donutfilling Wheels and Tires 9 09-27-2013 05:04 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 12:49 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
