Old 05-25-2015, 03:33 PM   #15
jshadeck
jshadeck's Avatar
Originally Posted by Curtis View Post
Running a 255/35 on front and back? Do the front and back end up being a different height?
No. Same exact tire size front and rear, so the height cant be different
jshadeck is offline   Reply With Quote
Old 05-25-2015, 03:36 PM   #16
jshadeck
jshadeck's Avatar
Old 05-25-2015, 03:39 PM   #17
wparsons
wparsons's Avatar
8.5" is the narrowest rim width Hankook suggests on a 255 for the Ventus Evo2, so I doubt it's flush, it'll definitely have a slight bulge. They're also rated for up to 10", so they shouldn't be stretched on a 9.5" wheel.
In any case, I wouldn't suggest running square tire sizing on staggered rims. The narrower wheel is going to feel mushier. I'd still suggest 225/235 front and 245/255 rear.
255's up front have a chance of rubbing on stock shocks as well.
flickr
Old 05-25-2015, 03:41 PM   #18
jshadeck
jshadeck's Avatar
No issues on mine, i even added a little more front camber recently -0.8f and i hit twisties as often as i can
Old 05-25-2015, 04:24 PM   #19
tyrantcf
Drives: '16 WRX, CBR1000RR
You got some strange advice. I've never heard of anybody running different brands/compounds on the front and rear for performance reasons. Unless you're thinking DRs on the rear.
Don't mix load index and speed ratings. I would have recommended a square setup but since your wheels are already en route, 235/40 for the front and 255/40 rear.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 05-25-2015, 05:10 PM   #20
wparsons
wparsons's Avatar
TC/VSC probably won't like that. It would be happier with 235/45 and 255/40.
flickr
Old 05-25-2015, 07:45 PM   #21
jshadeck
jshadeck's Avatar
235/35 and 255/35 are closer to stock diameter. A 235/45 is almost 6% larger than stock, a 235/35 is less than 1%
The Following User Says Thank You to jshadeck For This Useful Post:
Curtis (06-20-2015)
Old 05-25-2015, 08:59 PM   #22
wparsons
wparsons's Avatar
The problem isn't difference from stock, it's difference from the other end of the car. 235/35 and 255/35 are 0.5" different to each other.
flickr
Curtis (06-20-2015)
Old 05-25-2015, 09:17 PM   #23
jshadeck
jshadeck's Avatar
2.2% difference, but moving away from stock diameter will affect gear ratios, mpg, speedo, and may very well result in rubbing depending on the setup
Curtis (06-20-2015)
Old 05-25-2015, 09:42 PM   #24
wparsons
wparsons's Avatar
I'm not disputing that, but having wheels too different front/rear will definitely make the TSC and VSC freak out. Not sure what the threshold is, but it's very real.
225/40/18 is almost bang on stock diameter too for the fronts.
flickr
Old 05-26-2015, 04:39 PM   #25
Curtis
Curtis's Avatar
Drives: 2013 Subaru BRZ, 2005 Chevy Halfton
Well thanks for all the information guys!
Definitely got some mixed views but I'll take what I learned and pick the best tire
2013 BRZ Sport tech, Saskatchewan
Curtis is offline   Reply With Quote
Old 05-27-2015, 01:08 AM   #26
jshadeck
jshadeck's Avatar
Size:  243.9 KBName:  ImageUploadedByTapatalk1432703200.657346.jpg
255 on 9.5, the edge of the wheel is exposed from the side, and the sidewall is not 90degree angle, thats what i call a slight stretch
Size:  320.6 KBName:  ImageUploadedByTapatalk1432703226.234547.jpg
255 on 8.5, perfect fit imho
Old 05-28-2015, 01:12 PM   #27
Curtis
Curtis's Avatar
Attachment 110651Attachment 110652
Attachment 110653Attachment 110654
Yeah that does look good, the front is perfect
Old 05-28-2015, 02:34 PM   #28
jshadeck
jshadeck's Avatar
Thanks im happy w it, and you had mentioned you didnt want to mess up the speedo etc. i had square 18x9.5, but w the 8.5 fronts they fit the car better both functionally and form, they are lighter, and i like the flat face front wheel w the concave rear wheel. Keeping the square 255 prevented any issues with getting two different tire sizes to work well together, as well as retaining the square fitment for handling purposes.
Tire size help! brzee_vic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-09-2015 08:36 AM
Tire size for 8.75 brz23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-08-2015 04:30 PM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Need help choosing wheel/tire sizes jonbonazza Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-28-2013 08:20 AM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 08:09 PM
