Old 05-25-2015, 04:29 PM   #71
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I have the BRZ limited and I had a rattle from the passenger door that I just couldn't find, until I checked out the switch cluster in the door panel itself. It is a hard plastic switch set pushed into an adapter sleeve, then into another sleeve attached to the detachable pod. This was loose enough to rattle at certain frequencies. I would recommend adhering something removable to the 4 sides of the switch at least as long as you have the door apart. I just ended up shoving pieces of business card in the gaps to take up the slack and prevent rattles. Excellent write-up and a good reference for when I do something similar to my own doors.
KoolBRZ is offline   Reply With Quote
Old 06-11-2015, 02:03 AM   #72
XtremeMaC
Drives: Asphalt Grey FR-S
Originally Posted by WolfSongX View Post
On a separate note, what is that socket for. I believe I don't have it on mine..
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 06-24-2015, 03:25 AM   #73
DatBackflipTho
Hella stock member
DatBackflipTho's Avatar
Drives: 2015 Halo FRS
Thanks for the DIY and pics. It helped me a lot throughout my install. I also used secondskin products. I used their products on my last 2 cars aswell. Very easy to cut and apply.
DatBackflipTho is offline   Reply With Quote
The Following 2 Users Say Thank You to DatBackflipTho For This Useful Post:
DAEMANO (06-24-2015), Fakk (06-27-2015)
Old 06-27-2015, 09:12 PM   #74
Fakk
Drives: 13 BRZ Limited 6MT CBS
Also got the Second Skin Door Audio kit. Was only able to do my driver's side door today, due to weather..
Did you guys have any problems with the screws that go through the handle into the door? The plate the top handle screw went into won't stay in the door anymore, so as soon as I pull on the door handle, the screw and the piece it screws into pops out. Then the door handle has a slight bit more play, and makes a squeaky noise. Also, 1 or 2 of of the bottom clips won't stay in, or will stay in but pops out when I shut the door. I tried taking it off and putting it back on a few times, but same results. Even tried trimming some of the foam further away from the holes where the clips are. Would it be possible its the huge piece of yellow foam on the door panel? Did you guys shave that down, or remove it, or nothing?
Fakk is offline   Reply With Quote
Old 06-28-2015, 11:26 PM   #75
DatBackflipTho
Hella stock member
I didn't have any problem with with the screws on the handle area. On my Wrx i broke one of the plastic pieces but the screw always screwed back in. I left the foam piece as is. My door closes fine. Do you have any pictures of your install?
Old 10-21-2015, 07:23 AM   #76
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'd like to try this out but I"m not sure it'll be a big difference. My concern with certain mods has been the fact that I don't notice them. Would sealing and deadening the doors (and seat, trunk, floor, etc) be a night and day difference?
tracerit is offline   Reply With Quote
Old 09-12-2017, 01:58 PM   #77
PerCompLLC
Drives: 2019 86 TRD SE
Great stuff! Thanks!
PerCompLLC is offline   Reply With Quote
Old 04-08-2020, 03:35 AM   #78
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Bump for this excellent DIY.
Intent > Content
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 01:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 02:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 03:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 10:09 PM
Window not sealing NOHOME Issues | Warranty | Recalls / TSB 9 12-12-2012 03:57 PM
