Old 05-25-2015, 04:22 AM   #267
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Originally Posted by GT86_PRAGUE View Post
Dude, I was not asking for engineers point of view!
This says a lot. Opinion can't stand up to science; I've heard that before.
How much of my money will you be needing for this "miracle?"
Old 05-25-2015, 04:22 AM   #268
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I didnt told I value more some guy who need to justified his purchase (or sell it like Rick) over an engineer. I just want to hear an opinion from someone WHO HAS IT and I would than make some assumptions myself.
I read the science above and I dont believe it either.
I can save 10kg on battery for 1/3 price of propshaft, so there must be more to this. Again, not asking for any engineering stuff, but possible oppinion of someone WHO PERSONALLY DID THIS.
As an engineer and someone who has personally installed lightened driveline components, dropping 10 lbs of rotating mass will make a bigger difference than dropping 10 lbs of static mass. But I'm an engineer...
JDKane527 is offline   Reply With Quote
Old 05-25-2015, 04:26 AM   #269
themadscientist
Hotlink Terrorist
The Following User Says Thank You to themadscientist For This Useful Post:
raven1231 (05-26-2015)
Old 05-25-2015, 04:34 AM   #270
GT86_PRAGUE
Drives: GT86
Originally Posted by themadscientist View Post
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
themadscientist (05-25-2015)
Old 05-25-2015, 09:21 AM   #271
burdickjp
Drives: 2013 ultramarine Scion FR-S
But what is the benefit/cost ratio? Is it more than the battery?
burdickjp is offline   Reply With Quote
Old 05-25-2015, 11:33 AM   #272
JDKane527
JDKane527's Avatar
Battery
Pros:
Dropping weight off front passenger corner to shift center of gravity rearward to the driver side of the car
Mass is high relative to the car's center of gravity, so removing would lower it slightly
Cons:
Lower capacity battery
May require a special charger to balance charge
Driveshaft
Pros:
Dropping weight in rotational mass
Carbon driveshaft helps reduce shock to drivetrain
Cons:
Dropping weight from the lowest most central part of the car, so should in theory slightly raise the car's center of gravity
Aluminum driveshaft transmits shock and vibration through the drivetrain.
Would dropping 25 lbs in a battery be equivalent to dropping 12 lbs with a carbon drive shaft? Could you even feel either modification? You would more likely feel the effect of a lighter driveshaft did than you would the effect of a lighter battery.
I'm not sure what battery and if you were thinking about an aluminum or carbon shaft. I'll assume its a Ballistic life pack that weighs 3 lbs.
Battery (3lbs, 28-3lbs = 25lbs savings) - $250
Aluminum shaft (13.2lbs, 24.2-13.2lbs = 11lbs savings) - $420
Carbon shaft (12.1lbs, 24.2-12.1lbs = 12.1lbs savings) - $1000
Battery would net you most static weight drop per dollar
25 lbs / $250 = 0.1 lb/$
11 lbs / $420 = 0.026 lb/$
12.1 lbs / $1000 = 0.0121/$
Dropping rotational mass will make the most noticeable effect, but it would be to a very small magnitude still and difficult to quantify. If you were looking to drop rotational mass, get a lightweight clutch and flywheel to get mass that is rotating faster, and then get a driveshaft. If your battery needed to be replaced, then it would be a great time to get a lightweight battery. I have a lightweight battery and honestly didn't notice much of a difference in handling. Then again I haven't had the car corner balanced since installing it so that may have a part.
FWIW, I plan to get a carbon driveshaft in the future.
The Following User Says Thank You to JDKane527 For This Useful Post:
Strife26 (04-17-2017)
Old 05-25-2015, 12:13 PM   #273
stugray
Drives: 2013 GBS BRZ Limited
You asked a question, I answered with a fact.
If you cant handle the answer, dont ask the question.
YES a CF driveshaft will make a difference - less than 1/10th APPARENT hp.
Reducing rotating mass DOES NOT increase horsepower in any way. PERIOD. FACT.
Can it result in faster acceleration - yes.
Can it provide Higher engine RPMs - yes.
Do you think the engineers that designed the space shuttle tested the whole assembly before they launched it the first time, or did they CALCULATE the total thrust of all three SMEs + SRBs?
GUESS WHAT - THEY CALCULATED IT and ... wait for it.... they were RIGHT.
Old 05-25-2015, 01:05 PM   #274
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
But but but...i dont believe you
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
raven1231 (05-26-2015), stugray (05-25-2015)
Old 05-26-2015, 02:28 AM   #275
GT86_PRAGUE
Drives: GT86
You claiming to be an engineer doesnt mean that you are automatically right. You failed to understand I asked for someone with real experience and you didnt changed you propshaft obviously, you only crunch some numbers. So yes, you might be right on the numbers but thats not what I was asking for.
Old 05-26-2015, 02:49 AM   #276
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You claiming to be an engineer doesnt mean that you are automatically right(1). You failed to understand I asked for someone with real experience(2) and you didnt changed you propshaft obviously, you only crunch some numbers(3). So yes, you might be right on the numbers but thats not what I was asking for.(4)
1. Being an engineer is being an applied mathematician. We go to school to get it right, over and over and over again. Eventually it becomes second nature to us, thus doing the math for a real world problem (LIKE THIS ONE) give numbers that (when all other factors are negligible) will give you minimal difference.
2. I still think you fail to understand, experience is biased no matter how hard you try and make it not be.
3. Here's a question from my physics textbook chapter 8 rotational kinematics, (the same principles used to do all this fancy unicorn work with the driveshaft);
The angular speed of an automobile engine is increased uniformly from 1170 rev/min to 2880 rev/min in 12.6 seconds. a) find the angular acceleration in rev/min^2 b) how many revolutions does it make in this time?
can you see how the math can numerically quantify a real world problem?
4. You're looking for approval for buying the driveshaft. You keep wanting someones experience review for it, yet this thread basically disproved its ability to significantly, even minimally improve acceleration. You've already made up your mind about it and refuse to believe that it doesn't do any good.
Old 05-26-2015, 03:00 AM   #277
GT86_PRAGUE
Drives: GT86
Thanks for playing, I give up.
Old 05-26-2015, 03:02 AM   #278
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Here's a great idea, how about instead of looking for someone else's experience about the driveshaft, why not buy it and make your own experience. Don't look for approval in the internet.
Old 05-26-2015, 03:30 AM   #279
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
just get both and be happy!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 05-26-2015, 05:35 AM   #280
themadscientist
Hotlink Terrorist
They think you should get the CF driveshaft. Their slide rules all agree.
The Following 2 Users Say Thank You to themadscientist For This Useful Post:
cdrazic93 (05-26-2015), Ultramaroon (05-26-2015)
Lightweight aluminum drive shaft installed. stockysnail Northwest 18 02-04-2020 11:18 PM
Driveshaft Shop Aluminum Drive Shaft. FT-86 SpeedFactory Engine, Exhaust, Transmission 40 10-15-2015 09:11 PM
Invidia N1 interference with Driveshaft Shop aluminum shaft. xkalelx Engine, Exhaust, Transmission 6 03-03-2015 09:43 AM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 08:09 PM
