Old 05-22-2015, 11:31 PM   #2269
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Originally Posted by Jmonty View Post
So with a header and this kit should I get a bigger MAF sensor? My tuner just maxed out one on a stock + JRSC at 7000 RPM?
IF so which one and where do I get it?
Someone mentioned this at a meet tonight with the Kraftwerks kit. In for the response. :P
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 05-23-2015, 02:17 AM   #2270
CSG Mike
CSG Mike's Avatar
Your tuner should be able to tune your car without an aftermarket MAP sensor. The factory MAF is never replaced under normal cirumstances.
Most tuners will tell you to get a MAP sensor and tune the car via speed density, because this makes their work very easy. They don't want to spend the time re-doing the VE tables to be specific to your setup, so that you can have a MAF based tune.
The Jackson Racing Factory tune is MAF based. The stock BRZ/FRS is MAF based.
The CSG BRZ has a hybrid MAF/MAP based tune, and can run in either mode or both, so that we can maximize the benefits of both; we have our cake and eat it too.
CSG Mike is online now   Reply With Quote
Old 05-23-2015, 01:37 PM   #2271
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Got a quick question for CSGMike: I have just come back from my first track session after my JRSC install. I run the JR factory tune at the moment but my oil temps are through the roof. 2 laps in and I hit 260 and it kept climbing. Slowed down to drop the temps and tried to keep it below 240. What can I do to keep the temps down? I have the oil cooler as well and am running 5w30 oil. Ambient temps tonight were about 110 so that does not help.
Any thoughts or suggestions
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 05-23-2015, 02:00 PM   #2272
DaiTT500
DaiTT500's Avatar
Drives:
What kind of oil cooler do you have. What part of the country are you at?
DaiTT500 is offline   Reply With Quote
Old 05-23-2015, 08:25 PM   #2273
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You need a bigger cooler. A nice big series-9 20-row will probably cut it. If it doesn't, you can run the one you have and the 20-row in series, but you also might start struggling with oil pressure.
Old 05-24-2015, 02:58 AM   #2274
Lone Starr
Drives: WRB Limited
Has anybody had an issues with the rotrex oil reservoir leaking during track use? I ran SoW today and noticed oil leaking on the top of the reservoir after the first session. I cleaned and retightened both the banjo with copper washers and the plastic cap, went out for the second session and it was still leaking. I went from Max to Min in 3 sessions and decided to call it a day since I forgot extra fluid. I've not had any problems during street use, but have noticed some fluid on the top of the reservoir. I periodically check fluid level and there's no significant loss, only under track conditions. Any help would be appreciated!
Tony
So...at last we meet for the first time for the last time...
Lone Starr is offline   Reply With Quote
Old 05-24-2015, 04:19 AM   #2275
RevoG
RevoG's Avatar
JR oil cooler along with the SC. And I am in Dubai, UAE
Old 05-25-2015, 09:07 PM   #2276
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
Tony
mine was doing the same thing when i first got it installed, i just put too much oil on it. it will eventually level out to the right amount over time.
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
Old 05-26-2015, 04:24 AM   #2277
CSG Mike
CSG Mike's Avatar
We've tested in 115F without hitting 260. What is the exact brand and model/formulation of oil you are using?
Old 05-26-2015, 04:25 AM   #2278
CSG Mike
CSG Mike's Avatar
Tony
You may have slightly overfilled the system. THis is common, since the proper level inside the reservoir is actually very low, as per the dipstick. This unnerves people, and it's often overfilled, leading to overflowing when the fluid gets hot.
Old 05-26-2015, 09:06 AM   #2279
RevoG
RevoG's Avatar
Total Quartz 9000 5w30. It is the same as the specified OEM 0W20 oil
Old 05-26-2015, 09:37 AM   #2280
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I think you need to go thicker on your oil and found your issue. Mike nailed it. You can get away with a 0w20 on a street car, daily driven, but the second you do any sort of highly spirited driving or tracking, it will roast.
2016 Camaro SS is offline   Reply With Quote
Old 05-26-2015, 12:30 PM   #2281
RevoG
RevoG's Avatar
Agreed, which is why I am running 5w30. Do I have to go higher?
Old 05-26-2015, 12:38 PM   #2282
2016 Camaro SS
Drives: Fast
May want to try a different brand. I could be wrong though. Maybe some of the tracking folks here could better help, but to me that sounds like the right weight but I've seen people go even higher depending on conditions.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
