Old 05-21-2015, 08:59 AM   #29
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I see CSG sells this now. I assume this is why they are providing this "independent" yet somewhat biased review of a header that is only available via drop ship from ACE $1400 or through CSG $1495. I really like the design as they have incorporated the runners where the overpipe existed and eliminated the need to have exhaust pipes stuffed behind the rad like with the nameless design. The downside may be that since this header is only being produced in limited volume (only 2 per month according to CSG's website) it will generate some serious wait times if more than a few people buy these.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
funwheeldrive (12-20-2015)
Old 05-21-2015, 09:20 AM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
Seeing how other companies with succesful products hired extra staff, it's very possible to happen with Aceheader aswell, given enough orders.
Old 05-21-2015, 12:16 PM   #31
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Very impressive results. It was always only a matter of time to see these kinds of optimization on this platform.
That said, yes, I run the PTuning header, so call me biased, but I don't think its fair to include their results given it wasn't done by you or tuned by you and the configuration was in no way comparable...
A totally stock car with a header and tuning vice a fairly modded car we have no idea the pedigree of...Speaking as an engineer, that comparison is meaningless. But again, call me biased if you will.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
endless_pain (05-28-2015)
Old 05-21-2015, 12:25 PM   #32
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Or we can just wait for PLM to buy one and rip it off. LOL
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
Calum (05-21-2015), civicdrivr (05-22-2015)
Old 05-22-2015, 12:33 PM   #33
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
Just ordered a set, have to say they have amazing customer service and mine should be stateside by the 28th
Very impressed they even sent me photos
AlexBinJackson is offline   Reply With Quote
Old 05-22-2015, 05:42 PM   #34
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Will there be a catted Ace Front pipe?
Alltezza is offline   Reply With Quote
Old 05-22-2015, 07:59 PM   #35
CarGuy
Track Rat
CarGuy's Avatar
Drives: '14 Subaru BRZ
From the CSG web site the last line of the product description reads:
"- Aftermarket motor mounts recommended (not required)"
I suspect the wider twin-tube over pipe is in closer proximity to the motor mounts on one side and heats up the mount rubber more than with a stock header. Could header wrap solve the issue?
CarGuy
'12 BMW 128i (daily driver)
'14 Subaru BRZ (track car)
Racing is life. Anything before or after is just waiting. - Steve McQueen
CarGuy is offline   Reply With Quote
Old 05-22-2015, 08:50 PM   #36
juliog
juliog's Avatar
Drives: 86
I'm the owner of the car with the PTuning header used for the last dyno plot in OP's post. Same dyno (Church Automotive Tuning), same software. Same 91CA gas, although winter (December) vs summer blend (May) could have a small impact in the results. Tuner spent 3.5 hours on my car, and used suggested intake cam timing data from Ptuning as a starting point.
So, totally comparable results IMHO. I've seen plenty of dynos from that shop, and results are usually very consistent and repeatable. I have had my S2000 tuned over there as well. The setup on my FR-S makes more peak power than most (all?) NA twins tested on 91 CA over there, which is great for the track but not so fun on the street. Have also driven many friend's twins tuned there, and the "butt" dyno always matches the dyno charts.
The way I see it:
  • UEL headers such as Tomei (<$700) provide the most value. Filling the torque dip makes this car so much more enjoyable on the street.
  • For track use (always above 4500rpm), Ptuning EL gives big AOE gains where it matters. It's also pricey, at ~$1200. Torque dip still there though, not so fun on the street and in some canyons it makes me downshift into 2nd for the slowest corners if I want to keep up with a car with UEL or something faster like an S2K.
  • ACE header seems to give you the best of both worlds, but it's also the most expensive (~$1500). However I feel the price is justified, and worth the extra over Ptuning if you have the budget.
juliog is offline   Reply With Quote
The Following 6 Users Say Thank You to juliog For This Useful Post:
Hyper4mance2k (05-22-2015), Pat (05-22-2015), phobos512 (05-22-2015), raven1231 (05-26-2015), RJasonKlein (05-23-2015), ShoShin (05-26-2015)
Old 05-22-2015, 09:30 PM   #37
phobos512
phobos512's Avatar
The way I see it:
Thanks for the data. Makes it much easier to talk about. I am surprised at the magnitude of the dip though as compared to PTuning's numbers. I know 93 makes a significant difference. Your having been on winter blend makes a difference also, though I couldn't quantify it.
Old 05-23-2015, 11:58 AM   #38
OkieSnuffBox
Drives: '23 BRZ Limited
No, it's the stock mounts allow the engine to move around so it might contact the subframe.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
CarGuy (05-24-2015)
Old 05-23-2015, 12:37 PM   #39
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
Well I'm convinced. I'm gonna order one today
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 05-23-2015, 12:53 PM   #40
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
whoa...freaking awesome!
Old 05-23-2015, 01:08 PM   #41
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, if one substracts price of average overpipe from price of ACE's header .. suddenly price doesn't look THAT much more expensive vs price of other top headers.
The Following 4 Users Say Thank You to churchx For This Useful Post:
CSG Mike (05-26-2015), DustinS (05-29-2015), sw20kosh (05-26-2015), twag4 (05-23-2015)
Old 05-26-2015, 03:27 PM   #42
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by churchx View Post
[/LIST]
Wow I never thought of that. OP's generally run $300 new...
The Following User Says Thank You to sw20kosh For This Useful Post:
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
