Old 05-22-2015, 09:45 PM   #267
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Calum View Post
Obligatory what fuel were you using? Also, what size pulley are you running these days?
Thanks for keeping us updated.
Given the torque numbers, and the fact that it still has factory exhaust, I predict its some higher percentage ethanol mix with a larger pulley (70mm or a bit bigger). 290 torque is insane - and I'm sure it's in the high 200's over most of the rev range. Beast.
bfrank1972 is offline
Old 05-22-2015, 10:21 PM   #268
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
E70, 80mm pulley still. We're up about 10 hp from the winter numbers with the header change. Likely a bigger effect since it was cold then and warm now, and both are uncorrected.
Now, we did some additional testing today going down as far as a 72.5mm pulley. This places the blower at a speed that should allow for the rated 500 engine HP or about 430 whp. However, looking at the data, we see airflows that are only up about 10-15% in the mid-range. Power is up there clearly--we're spinning in 4th on RE71Rs--but up top we have nearly identical air flow values over 6500 RPM. So either belt slip, or more likely we have an intake or exhaust restriction.
To figure this out I retrospectively went back and compared airflow values of JRSCs, KWSC, and turbo cars. What I'm seeing is that we're hitting a similar value at the very top end, but with this kit we're seeing higher boost levels to achieve the same airflow. What I think is happening is that we're either choking the blower on the intake side (throttle body) or choking it on the exhaust side (header/exhaust). The exhaust makes more sense since we're seeing a high boost, but low airflow scenario. We see a very similar thing with plugged up cats.
Recently we did a massive 2" primary header for a 2.5l NA MX5, and picked up significant HP as a result. I bet we can achieve the same thing here.
The good news? I really think there are not going to be many issues running this kit on pump gas with the 85 or even 80mm pulley, and 80 on e85 for sure.
With whatever restriction we're seeing, the actual load on the motor is not really all that huge. So yes, you do see high boost levels going into the motor, but that is a measure of restriction rather than workload. The actual airflow consumed is what really represents the load on the rods/ring lands etc...and all of those are not far off from turbo setups we've done that have lasted quite a long time.
In fact, the June 1st track day we have scheduled might very well end up with this car.
Until then, here's a video of some torture testing, including some 5th gear runs on the dyno (processing but should be ready shortly):
[ame]http://youtu.be/NyCVyrOAKWM[/ame]
Xero-Limit is offline
The Following 9 Users Say Thank You to Xero-Limit For This Useful Post:
8686 (05-23-2015), brianhj (05-22-2015), Calum (05-24-2015), CK_Bladesmith (05-22-2015), LS1M (05-23-2015), sam69 (05-23-2015), stockysnail (05-23-2015), Toyota86.ir (02-09-2016), Urmyson (05-23-2015)
Old 05-22-2015, 10:32 PM   #269
brianhj
Drives: 2017 Camaro 1SS
You're doing the lord's work, moto-mike
brianhj is offline
The Following User Says Thank You to brianhj For This Useful Post:
Xero-Limit (05-23-2015)
Old 05-23-2015, 12:45 PM   #270
stockysnail
Just the tip
stockysnail's Avatar
Cool beans. Once you guys get the 335 completely sorted I may want to upgrade my 210 to the 335. More power never hurts unless you blow an engine or spin out into a ditch!
stockysnail is offline
The Following User Says Thank You to stockysnail For This Useful Post:
CK_Bladesmith (05-23-2015)
Old 05-23-2015, 12:58 PM   #271
LS1M
Drives: 2015 BRZ
I'd like to see a run with the hood down. How loud is it compared to a centrifugal blower, at both part & full throttle?
LS1M is offline
The Following User Says Thank You to LS1M For This Useful Post:
Dream20b (05-23-2015)
Old 05-23-2015, 02:27 PM   #272
Xero-Limit
Xero-Limit's Avatar
[ame="https://www.youtube.com/watch?v=1zh7886tuKI"]Moto East Supercharged Intake - YouTube[/ame]
This is with the 210 but awfully similar. The SC whine is substantial with our short intake. Even with a perrin CAI it is much more subdued. Barely audible with a stock plastic intake.
Old 05-23-2015, 03:40 PM   #273
350matt
Drives: toyota mr2/ Toyota GT86
is this all on a built engine or stock engine internals?
350matt is offline
Old 05-23-2015, 05:07 PM   #274
Kodename47
Kodename47's Avatar
Drives: UK GT86
Stock
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 05-23-2015, 06:10 PM   #275
LS1M
Drives: 2015 BRZ
That's kind of what I figured. The larger blower won't be spinning as fast so I guess the pitch wouldn't be quite as high, but there's no mistake it's a blower. Main reason I'd prefer the 335 rather than getting the 210 & upgrading later ... Don't want to advertise something that I can't back up on the street
So the whining noise is actually coming out the air filter, and the longer the intake tract, the less noise. Interesting.
LS1M is offline
Old 05-23-2015, 09:53 PM   #276
brianhj
The whining is from the spinning of the lobes inside the supercharger. The shorter intake just allows more of it to be heard since it reduces the number of noise traps (resonators, air filter box, etc) in the intake system.
brianhj is offline
Old 05-24-2015, 04:40 AM   #277
sam69
Drives: GT 86
Pics of the stock 65mm TB against the Raptor 80mm TB that I just recieved.
sam69 is offline
Old 05-24-2015, 04:44 AM   #278
Calum
That Guy
Drives: 2013 asphalt FRS MT
@moto-mike, could you post a dyno plot showing a 210 vs 335 on pump gas, both taken to what you feel is the max for the compressor?
Calum is offline
Old 05-24-2015, 05:32 AM   #279
350matt
cool
is that a like for like fit in terms of bolts holes and electrical connector?
350matt is offline
Old 05-24-2015, 09:17 AM   #280
sam69
Drives: GT 86
No I will have to modify the SC manifold to take the big TB .
They are both 6 pinouts on both TB's but I have to get hold of the wiring diagrams for both vehicles to see if I can make an adaption harness so if anyone has these for either TB and post them up would be much appreciated
sam69 is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
