Old 05-22-2015, 10:41 AM   #253
rlpaul
Drives: point A to point C. Screw point B!
Originally Posted by Poodles View Post
<snip>but CF is less durable for a street driven car.
Eh, there's a number of cars that come from the factory with CF driveshafts now. In the Mustang, Camaro, and GT3000 circles, there's people that have been running them on dailies for well over a decade.
The 'danger' is impact resistance. As long as you don't smack into a boulder, it should last just as long as any other type of material.
rlpaul is offline   Reply With Quote
Old 05-22-2015, 11:00 AM   #254
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
What you bring up is valid but you have to remember load...
Originally Posted by JDKane527 View Post
Definitely agree. The Kinetic Energy affects how much inertia the rotating assembly has. Decreasing overall inertia has benefits.
Angular kinetic energy is defined:
KE = (1/2)*(Iw^2)
I = moment of inertia
w = angular velocity
The faster a mass is rotating, the more effect it has on impacting Kinetic Energy. The crank pulley and flywheel are rotating at the same angular velocity. The flywheel would make a substantially larger impact than the crack pulley would make.
KE = (1/2)*(Iw^2)
I,flywheel >> I,crankpulley
The alternator pulley is rotating much faster than the crank pulley due to the pulley diameter. It could be argued that lightening the mass of the alternator would have more of a benefit than lightening the water pump pulley as the water pump pulley diameter is similar to the crank pulley diameter. It could also be argued that lightening the alternator may or may not cause harmonics/resonances in the engine as the rotating mass has been altered.
KE = (1/2)*(Iw^2)
w,alternator >> w,crankpulley
The case of the driveshaft, I is altered while velocity remains constant before and after.
KE = (1/2)*(Iw^2)
I,carbon << I,steel
I = mr^2
As m,carbon ~= (0.5) m,steel
Correct me if I'm wrong, but I hear the radius is slightly less for the carbon driveshaft.
r,carbon ~= (0.99) r,steel
I,carbon = (0.5)(0.99^2) I,steel
I,carbon = (0.4905) I,steel
KE,carbon = (0.4905) KE,steel
It would help for angular acceleration of the assembly slightly and for braking, but would not have as large of an impact as lightening a component with a higher angular velocity.
When talking about crank pulley affecting hp, you have to understand you're talking about two different things.
a lighter pulley won't have as much of an effect as an underdrive pulley.
An underdrive pulley will often be lighter as well, but it is reducing engine load from accessories by changing the rpm's of the accessories for a given engine rpm which reduces the engine load for accessories at any given rpm.
Anyone who tries to argue that under drive pulleys don't increase hp is smoking crack.
That would be like saying that super chargers don't increase load and take hp from the engine to operate.
Jaden
Jaden is offline   Reply With Quote
Old 05-22-2015, 04:18 PM   #255
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Jaden
This could be another discussion on the benefits of reducing mechanical drag and load, such as deleting the engine driven water pump and the effects of changing the final drive.
JDKane527 is offline   Reply With Quote
Old 05-22-2015, 04:34 PM   #256
wootwoot
Drives: FRS
From page 5 -
If you reduce the 30 lbs driveshaft to 0 pounds (removing the energy stored in it entirely!) and do otherwise equal runs 0-100 MPH you WILL notice a 44 millisecond difference in a 16.2 second run!
It doesn't matter if you win by an inch or a mile. Winnings winning!
The Following User Says Thank You to wootwoot For This Useful Post:
Strife26 (04-17-2017)
Old 05-22-2015, 04:44 PM   #257
Poodles
Drives: 2015 Series.Blue
The cars that came with them from the factory are more using what is more appropriately known as fiber reinforced plastics and it's quite a bit more durable. They also run guards under the driveshaft tunnel to prevent rocks from hitting them. It doesn't take a bolder to kill a CF driveshaft...
Old 05-22-2015, 06:59 PM   #258
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
The JDM/Euro model underpannels provide basically the same function. I have a set on my car, keeps everything under there SOOOOO much cleaner.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 05-22-2015, 07:51 PM   #259
Poodles
Nope, they cover the sides.
Old 05-25-2015, 03:29 AM   #260
GT86_PRAGUE
Drives: GT86
From page 5 -
I was looking for REAL WORLD experience, not crunching some numbers.
You dont have this on your car and you will never have. You obviously are against this, so you are disqualified from commenting on this question.
I believe there is at least Rick from Rallyspo* who claims very positive things on their FRS. Anyone who bought this agree or not?
GT86_PRAGUE is offline   Reply With Quote
Old 05-25-2015, 03:40 AM   #261
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
disqualified lol. Yes, lets not believe the engineer because that's not what he went to school for or anything. Totally doesn't know physics, or math. Nothin like that. I'm so glad you made assumptions he doesnt have it, or wont ever own it.
Old 05-25-2015, 04:14 AM   #262
GT86_PRAGUE
Drives: GT86
Dude, I was not asking for engineers point of view!
Old 05-25-2015, 04:23 AM   #263
JDKane527
JDKane527's Avatar
So real world experience point of view like butt dyno vs real dyno? Butt dyno registers over 9000 whp with rainbows being shat.
Old 05-25-2015, 04:25 AM   #264
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Except engineers quantify real world data. Given a statement that can have a lot of subjective reasoning to it, you're left with a ton of opinions. Person A says "I like this mod because it appears to make me rev my car faster". Person B says "well I didn't seem to notice much of a difference". Do you see where the bias comes in? If it can be measured and proven with something that is non arguable (ehem...with math), it gives you a non biased real world answer without anyone sponsoring it (positive raving godlike review) or leaving their own bias because the product didn't work for them (negative review based on possible improper installation or defect...etc).
TL;DR In the real world this will have minimal acceleration gains at best, assuming you can shift properly at the peak of the power band every single time. That's what the science tells you.
Old 05-25-2015, 04:29 AM   #265
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Don't forget the unicorn manned corndog vending machines.
Old 05-25-2015, 05:16 AM   #266
GT86_PRAGUE
Drives: GT86
I didnt told I value more some guy who need to justified his purchase (or sell it like Rick) over an engineer. I just want to hear an opinion from someone WHO HAS IT and I would than make some assumptions myself.
I read the science above and I dont believe it either.
I can save 10kg on battery for 1/3 price of propshaft, so there must be more to this. Again, not asking for any engineering stuff, but possible oppinion of someone WHO PERSONALLY DID THIS.
Lightweight aluminum drive shaft installed. stockysnail Northwest 18 02-05-2020 12:18 AM
Driveshaft Shop Aluminum Drive Shaft. FT-86 SpeedFactory Engine, Exhaust, Transmission 40 10-15-2015 10:11 PM
Invidia N1 interference with Driveshaft Shop aluminum shaft. xkalelx Engine, Exhaust, Transmission 6 03-03-2015 10:43 AM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 09:09 PM
