Old 05-22-2015, 01:56 PM   #43
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by jprice130 View Post
For clarification, I'd like to point out that you do not tune with OFT. OFT is simply a hand-held flashing and data logging device that comes with a catalog of free, unlocked OTS tune files. So when folks say that most tuners won't tune or touch OFT, what they're really saying is that they don't want to tune with RomRaider or any other open source tuning software.
Good point - and to make it even more of a point, most talented tuners would have no problem tuning an OFT to extract pretty much the same performance that an EcuTek system could do - it's just many won't because the maps are not locked, and the tuners are trying to make money (i.e. someone could just post their tune up on wherever for other people to download).
EcuTEK is better no doubt - OFT pretty much just modified the existing factory ECU tables, EcuTek's RaceROM is custom software that can do some pretty neat additional things that the OFT cannot.
That said, I have an OFT, why? Bought it used for $350. Maps are free. Makes my car smoother, peppier, and more fun to drive. I can run E85 if I want to. That's all I need. I don't need map switching, custom tunes, or any of the other awesome features EcuTek has, so why would I spend that much more for EcuTek? I think that's a point that some of the 'track heads' might miss - many people are fine with a plug n play no frills solution that gives you 95% of the performance for less than 1/2 the money.
It's great to have options people.
Old 05-22-2015, 02:00 PM   #44
gramicci101
Off Topic
Originally Posted by Wepeel View Post
What ECUTek tuners do you recommend?
@moto-mike of Moto-East is in PA; you can't go wrong with them.
Old 05-22-2015, 02:13 PM   #45
ovm_catalyst
Jax86Club
ovm_catalyst's Avatar
Drives: 2015 WRB BRZ Premium MT
update your oft firmware including the template file and pedal dance mode optionwill be in the on screen menu and the car does not need to be warmed up either.
see OFT TIPS link below
Updating my OFT won't wipe off my stock tune, right?
ovm_catalyst is offline   Reply With Quote
Old 05-22-2015, 02:32 PM   #46
gramicci101
Off Topic
No it won't. But if you're concerned, you could flash your car back to stock, update the OFT, then flash back to whatever map you were using.
Basically backing up the OEM map in the car's ECU before you update your OFT.
Old 05-22-2015, 02:35 PM   #47
ovm_catalyst
Jax86Club
Just hit 50 miles on my first flash... It just learned the fuel trims! Lol
Also, what is a good percentage for LTFT to be hovering at?
Old 05-22-2015, 02:41 PM   #48
gramicci101
Off Topic
That'll be a question for the software tuning section, because I have no idea.
The Following User Says Thank You to gramicci101 For This Useful Post:
ovm_catalyst (05-22-2015)
Old 05-22-2015, 03:22 PM   #49
DarkSunrise
DarkSunrise's Avatar
Within +/- 4% is probably where you'll end up unless you re-scale your MAF. Obviously the closer to 0 you can get, the better.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 05-22-2015, 06:31 PM   #50
steve99
Drives: FT86
No it wont, your stock rom is stored in oft untill you write it back and erase oft you only need to do that if you want to sell oft to another user.
updating oft just updates oft softwareit all tune files remain. no need to flash back to stock
you can also download your stock rom from oft to your computer as well, any of the other tune files can also be downloaded and saved as well.
Old 05-22-2015, 09:36 PM   #51
CSG Mike
CSG Mike's Avatar
Unless you plan on driving/shipping your car out here to California, my preferred tuners do not do any sort of remote or e-tuning.
They are, however, available for you to fly out to you, but it's not cheap...
Old 05-22-2015, 10:21 PM   #52
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
lol, my OFT tune will have to do, lol
Thrustin is offline   Reply With Quote
The Following User Says Thank You to Thrustin For This Useful Post:
CSG Mike (05-23-2015)
Old 05-22-2015, 11:24 PM   #53
gtslow
Drives: 2015 Halo FR-S
Are there any legitimate reviews on the forum from people that have switched from OFT to Ecutek or vice versa? I realize now that OFT is just a device used to flash, and it has the benefit of coming with a bunch of off the shelf tunes which are good provided you can't get your car on a dyno for a more custom tune.
gtslow is offline   Reply With Quote
Old 05-23-2015, 02:16 AM   #54
CSG Mike
CSG Mike's Avatar
Originally Posted by gtslow View Post
Are there any legitimate reviews on the forum from people that have switched from OFT to Ecutek or vice versa? I realize now that Ecutek is just a device used to flash, and it has the benefit of coming with a bunch of off the shelf tunes which are good provided you can't get your car on a dyno for a more custom tune.
This is the only one i'm aware of.
http://www.ft86club.com/forums/showthread.php?t=80260
Pat (05-23-2015)
Old 05-23-2015, 03:24 AM   #55
steve99
Drives: FT86
Ill try to as unbiased as possible
EcuTek is a good system and has advanced reatures like 4 map switching on the fly (no reflash required, auto blip on downshift flex fuel option and if your going FI their are more tuners arround that will tune with it.
But it will cost you more and it locks your ecu to ecutek untill you get a stock rom flashed back. The $350 ecu licience is non transferable the locked off the shelf tunes or dyno tunes that tunes that 99.9% of ecutek tuners supply are also locked. The only thing you can resell is the cable to flash a tune if you buy one.
Their are no free off the shelf tunes with ecutek
Your minium cost is $350 for a ecu licience and about $300 for a locked flash and go off the shelf tune.The licience is permanently locked to your car and the tune is locked. And the ecutek tuner has to flash it for you unless you pay another $350 for a ecutek cable of your own.
Its well supported for na and fi.
OFT $500 it is open no locks to tunes or ecu.
You get a set of free off the shelf tunes for basic na mods and e85 or petrol fuels.
you can go fi with oft and they provide free tunes but only for their specific fi kits.
The oft is the device to flash tunes so you can flash tunes yourself, like if you purchasded an ecutek cable
Because ther are no locks or liciences with oft the whole system is resellable (once you flash your stock tune back), they sell very quickly usually in a couple of days for about 90% of purchase price if you wish to move on
With both systems you can get custom e-tunes or dynotunes
But not many tuners will tune with oft as they cannot lock the tune, and all tuners like to tune with what they are familiar with.
both systems are only as good as the tuner as in effect they just flash tuned roms.
Pick the one that suits your needs budget and plans for now and in the future.
Alternativly if your a bit techo you could use Tactrix for $170 all up.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
Hyper4mance2k (05-31-2015), Pat (05-23-2015), Teseo (05-23-2015)
FS: Open Flash Tablet csraine86 Engine, Exhaust, Bolt-Ons 8 06-17-2015 08:24 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
WTB: Open Flash Tablet Beeboo4life Engine, Exhaust, Bolt-Ons 2 10-27-2014 03:23 PM
WTB: Open Flash Tablet CreinCrein Engine, Exhaust, Bolt-Ons 1 01-29-2014 12:55 PM
