Old 05-19-2015, 11:51 AM   #1
philooo
Drives: 13' Scion FRS Track car
school me on Open Flash Tablet
I am looking to get the latest firmware for my car, and I was thinking about the open flash tablet to simply get the latest flash to fix the old seal problem and such....
my engine is 100% stock, exhaust and all.
do you think that makes sense ?
the idea is to use it later once I change stuff on my car ...
Or should I just buy the ecutek one ?
PS: total newbie in term of edu flashing here
phil.
philooo is offline   Reply With Quote
Old 05-19-2015, 12:02 PM   #2
Do it once, and do it right. Get ECUTek.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
jonbonazza (05-19-2015), Sportsguy83 (05-19-2015), tahdizzle (05-19-2015)
Old 05-19-2015, 12:29 PM   #3
sstfnv
sstfnv's Avatar
what are the advantages of ECUTek vs OFT for track on lightly modified car?
I understand that for FI applications ECUTek would be preferred but for just intake/exhaust/headers I think it shouldn't be a big difference between them unless I'm missing something.
sstfnv is offline   Reply With Quote
Old 05-19-2015, 12:36 PM   #4
Who's gonna tune it for you? I don't know very many tuners that will touch an OFT.
The OTS maps that come with OFT leave a lot to be desired in my experience.
Old 05-19-2015, 12:50 PM   #5
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Sub'd. FT86club's go to race/track guy CSG Mike vs one of FT86club's favorite tuners Shiv....
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Blu-by-U (05-19-2015)
Old 05-19-2015, 12:50 PM   #6
sstfnv
sstfnv's Avatar
I see your point about finding tuners but I have always had bad experience with custom tunes for my STI and S2000. Even with highly reputable tuners most times I felt like the tune was rushed and I had to make some adjustments to make it drivable and safe same as with OTS tunes....
If you have a real good tuner that will spend time to make sure the tune is perfect then pick whichever method he works with and recommends.
Old 05-19-2015, 01:09 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
If it's for the latest firmware and light tuning, OFT is pretty painless. It doesn't leave fingerprints on the ecu, can be unmarried and used on a different car (it can thus be resold) and still gets decent results out of the box.
If you're already working with a tuner, go with what they will tune, of course. For maximum results, you'll want to work with a tuner...
Old 05-19-2015, 01:13 PM   #8
DarkSunrise
DarkSunrise's Avatar
I have OFT. Here's one of my logs from my last track day.
http://datazap.me/u/darksunrise/data...4?log=0&data=1
Running ~97 octane fuel and OTS OFT stage 2 UEL 93 octane tune (v2.066). Ambient temps were 85F. Relevant mods were as follows:
- JDL UEL header + OP
- Berk catted FP
- Perrin CBE
- Perrin oil cooler
- K&N drop-in
Overall, the tune felt good and, as a reference, I was able to pull slightly on S2000's on the straights. As a negative, I was seeing a fair amount of FLKC (fine learning knock control) during my warmer sessions even on 97 octane fuel. Thanks to tuning suggestions from folks on this board, I should be able to make changes to my tune directly using OFT and romraider (namely editing fields in the IAT/timing compensation table). Another good thing about OFT is it can serve as an engine logging device, which is great at the track so you can keep track of how your engine is running.
There is merit in what CSG Mike is saying about most tuners supporting ECUTek (either exclusively or primarily). If you think you'll need a lot more than what an OTS tune can provide (e.g., FI tuning) then you're probably better off using ECUTek from the start.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (05-19-2015), strat61caster (05-22-2015), Takumi788 (05-19-2015)
Old 05-19-2015, 01:39 PM   #9
Takumi788
JHerbert Racing
Takumi788's Avatar
Originally Posted by philooo View Post
PS: total newbie in term of edu flashing here.
As a "newbie" my suggestion, as an OFT user, is to go OFT and run an OTS tune. Are Shiv's tunes conservative? Yes. Can you get more power with a custom tune? Of course. But as a newbie, there is nothing better than knowing your tune is a safe tune.
If you decide to educate yourself on the matter to become less of a newbie, Steve99 has some of the best information on this site concerning the OFT and you can edit your tune yourself to your liking.
Old 05-19-2015, 02:13 PM   #10
wparsons
wparsons's Avatar
Just a bit more food for thought, you can load the OFT OTS maps using EcuTek as well...
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (05-19-2015), Takumi788 (05-19-2015)
Old 05-19-2015, 03:25 PM   #11
Most tuners are just that... tuners. Find a tuner who actually races himself, and you'll find that the tunes behave completely differently from shops that only do street cars and cars that their customers casually track.
@Element Tuning is a great example of a tuner who actually races, and that race experience is reflected in the cars they tune.
Stumpygt86 (05-22-2015), wparsons (05-19-2015)
Old 05-19-2015, 03:27 PM   #12
- Berk catted FP
- Perrin CBE
- Perrin oil cooler
- K&N drop-in
While you have had great results tweaking your own tune, what you're doing is far beyond what most members here will do with their car.
Even then, I think we can agree that while your tweaks show results, there is still quite a bit being left on the table that you will never be able to realize just casually tweaking the calibration based on logs and street pulls.
I've spent hundreds of hours tweaking my own tunes, and still defer to CSG's tuner when actual results are needed. Every time, he is able to get more power, with lower EGTs, lower in-cylinder pressures, and better fuel consumption, in a few hours on the dyno, than I was able to accomplish in 20 hours on my own.
Old 05-19-2015, 03:30 PM   #13
Now, CAN an OFT tune be just as good as an Ecutek tune? Absolutely. However, finding someone to create an OFT tune of that grade will not be easy, if at all even possible.
86CUP is a great example. How many people run OFT? Zero. Many had OFT, and swapped to EcuTek.
steve99 (05-22-2015)
Old 05-19-2015, 03:40 PM   #14
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Well yeah, OFT is an affordable tuning solution that's great on the fly. It's not a dedicated system like EcuTek nor has the long amounts of research tossed into it.
Given a few years it could be better, but right now it's a good and affordable solution for the casual user wanting to get the most out of their bolt ons. No harm there.
megamarines is offline   Reply With Quote
FS: Open Flash Tablet csraine86 Engine, Exhaust, Bolt-Ons 8 06-17-2015 08:24 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
WTB: Open Flash Tablet Beeboo4life Engine, Exhaust, Bolt-Ons 2 10-27-2014 03:23 PM
WTB: Open Flash Tablet CreinCrein Engine, Exhaust, Bolt-Ons 1 01-29-2014 12:55 PM
