Old 05-22-2015, 12:59 PM   #3067
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Originally Posted by Laloosh View Post
Let me guess, you have the full replacement shocks and not the inserts. So who is going to be the first to say the full replacements are not legal cause their mounting location are clearly off lol
Inserts for me...
mpicher is offline   Reply With Quote
Old 05-22-2015, 01:08 PM   #3068
SeanRTR
C-Street AutoX
SeanRTR's Avatar
http://sololive.scca.com/timeslip/73CS.html
Fenter and Harvey lead the Lincoln Pro solo right now, and Harvey especially is killing all the twins in '60 fit times.
Ogburn III is in third, and Manfred in 4th.
Manfred is the only twin driver remotely close to the NC Miata on 60' times. What is your launching RPM and strategy, and what do you think of the Rival-S tires? Which size did you go with? Good luck this weekend guys.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 05-22-2015, 01:23 PM   #3069
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Man, how are you guys getting 2* of negative camber up front?!
DylanFRS is offline   Reply With Quote
Old 05-22-2015, 01:28 PM   #3070
mpicher
Autocross Nut
mpicher's Avatar
A good alignment guy who will actually loosen everything (including the top hat), then lean hard on the tire while it's tightened.
I was shocked when he was able to get that much out of the struts w/inserts.
Old 05-22-2015, 01:49 PM   #3071
MTeator
First 86
Did that on mine as well and clearly not near 2 degrees :/ And we used the biggest fat man we could find to lean on it all.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-22-2015, 01:51 PM   #3072
ButteR
Drives: 2015 Scion FR-S
Do you also have full replacements instead of the inserts?
Full replacements
ButteR is offline   Reply With Quote
Old 05-22-2015, 01:52 PM   #3073
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Inserts for me...
That's the first insert car I heard of getting 2 or more degrees out of the front.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 05-22-2015, 06:37 PM   #3074
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I loosened everything and jacked the hub up before torquing everything down. Nowhere near 2 degrees.
Old 05-22-2015, 09:11 PM   #3075
ButteR
Perhaps try an alignment shop with experience in setting up alignments for racing applications? It took the tech 15 minutes, and he barely put any effort into it. I explained to the tech that I replaced one of the strut bolts with a smaller bolt which allowed for the "loosen n push" technique. He then asked about camber plates n other suspension pieces n i told him nope, just loosen n push...once I explained this process they didn't need any further explanation..15 minutes later he had the camber at -2.6 and I told him to bring it down to -2ish.
I figured if I didn't explain the idea behind "getting more camber up front while staying c street legal" was neccessary unless this guy was autocrossing an 86 in c street.
Old 05-22-2015, 09:14 PM   #3076
ButteR
My last sentence has grammatical errors but that's just how I roll. Not correcting it...gangsta.
Old 05-22-2015, 09:16 PM   #3077
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
The shop that did my alignment does nothing but autox cars. -2.6 ? Bullshit, not on the factory camber bolts unless you are using something else.
Old 05-22-2015, 09:32 PM   #3078
MTeator
First 86
I'd protest that just to find out how to do it to mine :-)
Old 05-22-2015, 10:11 PM   #3079
ksconekiller
Drives: Subaru BRZ
The Koni full replacements allow too much camber up front. If you are using the full Koni struts along with the smaller camber bolts maxed out, you will have an illegal amount of front camber. I'd say over 2.5 degrees is easily possible. I personally wouldn't have a problem with someone using the replacements as long as they keep the camber where it's possible with OEM struts (1.5 or less).
ksconekiller is offline   Reply With Quote
Old 05-22-2015, 10:14 PM   #3080
ksconekiller
Drives: Subaru BRZ
Looks like most of the BFG drivers went with 245/40, and the Bridgestones seem to be split pretty evenly between 225/45 and 245/40. Most Scions are on the TRD springs and bars.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
