Old 05-18-2015, 06:48 PM   #2745
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Seriously, why not the Walbro pickups? I'm sure it's a chore, so is anything to do with the fuel system. It's all internal to the tank, so no worries about a fire.
Old 05-19-2015, 10:17 AM   #2746
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
What are Walbro pickups?
Old 05-19-2015, 10:56 AM   #2747
superpenguin
Some Random
superpenguin's Avatar
Drives: 2015 FRS
You need to step up the pads and the fluid.
You're getting the pads hot enough that they're fading (overheating) at the end of the sessions, and losing their bite. If you haven't already, you'll boil the ATE 200 (mushy pedal) as you get faster and step up the pads.
We can help you with both. If you like the feel of the HC+800, try the Club Racer or 999 (approximately double and triple the cost of the HC+800).
What do you recommend instead of ATE? A lot of the guys out here in arizona have been using 200/super blue for years.
superpenguin is offline   Reply With Quote
Old 05-19-2015, 11:46 AM   #2748
CSG Mike
CSG Mike's Avatar
In order of boiling resistance from lowest to highest:
ATE 200/Superblue
RBF600/AP Racing/Brembo
RBF660/Ferodo
Endless
Project Mu
Torque
If you have a properly sized braking system for your given skill level, setup, and usage, you will not boil RBF600. However, keep in mind that most cars are street cars, designed for street use, so when you track them, the system will most likely be undersized.
You can go overkill and start with Torque, or start entry level with RBF600. Torque is about double the price of RBF600, and all the fluids in the bottom 4 rows cost roughly the same.
CSG Mike is online now   Reply With Quote
Old 05-19-2015, 11:51 AM   #2749
superpenguin
Some Random
Drives: 2015 FRS
Great, thanks. Going out tomorrow for the first time, just flushed the system with Type200; will be on all of the stock things. Just hoping the tires don't chunk apart!
Old 05-19-2015, 12:24 PM   #2750
EAGLE5
Dismember
EAGLE5's Avatar
Talking
http://lmgtfy.com/?q=walbro+pickups
Old 05-21-2015, 11:34 PM   #2751
marusteri
Drives: 2013 BRZ Limited AT
Essex AP Racing sprint kit caliper bracket removal?
After 20 track days on the puny stock brakes I was dead set to get the Essex AP Racing sprint kit, but I saw in the install instructions that the caliper bracket is bolted using high strength loctite
Once I install the Essex AP Racing sprint kit, what am I supposed to do if I want to swap de brakes? If the AP Racing brakes have a problem or if I just want to have them rebuilt, I need to be able to temporarily install the OEM brakes; the car is my dd too ...
I know that kind of loctite can be removed by heating to 500F, but heating the spindle to 500F is not my idea of easy, trouble-free maintenance.
What do you guys do to remove that caliper bracket? Or do you just accept the idea that the AP Racing brakes are forever?
marusteri is offline   Reply With Quote
Old 05-22-2015, 01:11 AM   #2752
SVLTE
Low strength loctite and safety wire?
SVLTE is offline   Reply With Quote
Old 05-22-2015, 01:18 AM   #2753
CSG Mike
CSG Mike's Avatar
You just undo the bolt. You can break it without heating it to 500F. I've done it before several times. Don't use a ton, a tiny dab is all you need.
Old 05-22-2015, 01:19 AM   #2754
CSG Mike
CSG Mike's Avatar
If you know of pre-drilled bolts the right size, I'm all ears; I'd prefer to safety wire it too.
Old 05-22-2015, 01:25 AM   #2755
SVLTE
Honestly I think it's silly a "racing" brake kit wouldn't come with drilled bolts. Definitely a concern worth bringing up with the manufacturer. It could be possible to convince them to change the kit and offer the bolts for sale separately. I bought the little jigs a long time ago to drill them out myself.
Old 05-22-2015, 02:10 AM   #2756
marusteri
Cool, I'll play with loctite on some spare bolts to see how much I can put and still undo it. If the aluminum thread on the bracket gets damaged, can I buy the bracket only?
Good idea, even if I have to drill these bolts myself.
Old 05-22-2015, 02:14 AM   #2757
CSG Mike
CSG Mike's Avatar
I find that very unlikely, but yes.
Old 05-22-2015, 10:14 AM   #2758
Lateral G
Drives: 2017 Series.Yellow + Perf Package
Disable power steering. Seriously.
It's a great "guide" for when you're pretty close to overworking the front tires and understeering; it helped me learn the car much faster than I would have without.
Wait. This is possible!? Been wanting to do this since I bought the car. Is there a How To out there?
Lateral G is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
