Old 10-10-2014, 06:59 PM   #127
wheelhaus
wheelhaus's Avatar
Originally Posted by 37 View Post
4949 should work well. It might be a slight pain to remove but at least it's only 1/4".
Design is looking great, btw. Keep me in the loop on the GB.
Thanks! I did a test with the 4949 and it seemed to pull off without too much trouble. I never did get a 4947F sample from our rep... Unfortunately the 4947F only came in 1/2" wide at the narrowest, whereas the 4949 is 1/4" and 45mil thick, just a little firmer foam. There may be a slightly different adhesive formula, but this thing is so light it's not that critical.
The Following User Says Thank You to wheelhaus For This Useful Post:
DAEMANO (10-10-2014)
Old 10-10-2014, 10:40 PM   #128
wheelhaus
wheelhaus's Avatar
Vendor account is active! Thanks @Hachiroku!
I will have a group buy thread up very soon. Thanks for all the support guys, if this item sells well I will work on other projects that can make the 86 just a little bit better.
In the mean time, I will see what I can do about the tab mounted version some have requested.
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
DarkestBuddha (10-11-2014), DocWalt (10-11-2014)
Old 10-10-2014, 11:43 PM   #129
Creole
Creole's Avatar
Drives: Monogram FRS
3rd Brake Light *Low Profile Carbon Fiber (OMG CARBON)
When's the group buy thread going up?!
Take my money already!
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
The Following 2 Users Say Thank You to Creole For This Useful Post:
Heru Farukon (10-11-2014), wheelhaus (10-11-2014)
Old 10-11-2014, 02:22 AM   #130
Heru Farukon
Drives: MOARLOW BEEARRZEE
Oh man I need this. As I always what to relocate the brake light.
Take my money as well! !!!
Heru Farukon is offline   Reply With Quote
The Following User Says Thank You to Heru Farukon For This Useful Post:
Old 10-11-2014, 02:27 AM   #131
Heru Farukon
Forgot to add. Will yours be plug and play to the oe brake light connector?
The Following 2 Users Say Thank You to Heru Farukon For This Useful Post:
DocWalt (10-11-2014), wheelhaus (10-11-2014)
Old 10-11-2014, 02:24 PM   #132
wheelhaus
wheelhaus's Avatar
I am trying to source an OEM connector to pre-make the wire below, but as-is, no. I'm reusing the OEM connector and wire from the OEM light, but adding a connector with screw terminals where the tabs are (see pic 1 below). The OEM wire harness remains untouched.
The short wire can easily be removed from the original spaceship light (it pops apart, the wires are connected with push tabs). Cut an inch or two from the tabs, and strip about 5mm of the wire, tighten screws and done (see pic 2). I kept the leftover pieces with the tabs and just taped them to the OEM light incase I need to splice them back together.
Heru Farukon (10-12-2014)
Old 10-12-2014, 12:56 AM   #133
Heru Farukon
If I give you money now, can you make it for me...now as well hahaha
Old 10-12-2014, 05:30 PM   #134
xcelir8brz
Drives: 2013 BRZ Limited
I'm in. Great thing the OP is doing!
xcelir8brz is offline   Reply With Quote
Old 10-13-2014, 09:09 PM   #135
wheelhaus
wheelhaus's Avatar
Group buy is active! Thanks guys!
http://www.ft86club.com/forums/showt...46#post1982846
Rosticles (10-14-2014), SkAsphalt (10-14-2014)
Old 10-15-2014, 11:51 AM   #136
RaveSaint5
Drives: 2015 Subaru BRZ Series.Blue (White)
This is gorgeous!
Definitely going to get one in the future if it's still available.
RaveSaint5 is offline   Reply With Quote
Old 05-21-2015, 02:42 AM   #137
notout86
Drives: GTS 86 auto
Ideally I like the light up the top but as a simple compromise,can anyone see a problem with taking the LED-array
and its diffuser out of the housing and just putting it at the base?
I tried just laying it to one side of the housing and it is under half the height and 3inches/75mm closer to the glass making the view
out the back much better. It can actually be pushed in the crack for a simple friction fit.
Possibly a section could be cut out of the shelf to lower it more.
I tucked a bit of black felt under and up over the back and over the top and meeting the glass to stop reflection in the glass
and it will not rub or rattle. It looks neat and would match black felt covering the holes left in the shelf.
The wiring was not long enough for me to try driving around in that temporary position but it would reach if centred.
Any comments before I detach the three-legged monster?
Further thoughts ..... I will not know until I get the shelf out, but it may be possible to make only two slits in the shelf and push the bit between down to make a cavity for the array and make it flush with the shelf and simply lay one bit of felt over the shelf and light. Also, a magnet may be able to be attached below the array and use it to clamp to the metal. Then it would be easy to get it out for window cleaning. I'm getting excited.
GTS86 Auto (Australia)
Old 05-21-2015, 11:32 AM   #138
wheelhaus
wheelhaus's Avatar
Anything is possible, the only problems I foresee are visibility and rattling. If the plastic is touching the glass it could mar, or rattle. If the LED array is RIGHT at the bottom of the glass, the trunk edge or spoiler might hide it from certain low angles (driving over a crest, for example).
Creole (05-23-2015), notout86 (05-21-2015)
Old 05-21-2015, 01:59 PM   #139
Jake_86
Jake_86's Avatar
Very dope. Same as everyone, if the price is right game I'll play
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 05-21-2015, 02:00 PM   #140
Jake_86
Jake_86's Avatar
Oh... This is old, group buy over... Now what
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 04:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 10:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 11:10 AM
Low profile Seibon Carbon Fiber Spoiler pics mike_ekim1024 Cosmetic Modification (Interior/Exterior/Lighting) 0 04-17-2013 06:56 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
