Old 05-21-2015, 11:15 AM   #393
SeanRTR
C-Street AutoX
SeanRTR's Avatar
That may true, but these tires don't need additional heat to operate. If it's 50+ degrees F outside, they're going to be fine. I get the decreased contact patch to generate heat theory, but this is autocross, not road racing. Our tires have tread, and are designed to operate in the cool -warm temperature range.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 05-21-2015, 12:01 PM   #394
MTeator
First 86
Originally Posted by SeanRTR View Post
31 dry
25 wet
Apologize if I missed this, but is this the 245's in CS?
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-21-2015, 12:11 PM   #395
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I bought the 235-45-17's But, the same #'s should apply. In CS, the 245/40's are going to be up against the limiter on national courses, so I went with the tall tires...and my car is turtle slow in a straight line now.
Old 05-21-2015, 12:20 PM   #396
MTeator
First 86
Thanks, wasn't sure how the 245's RE71's were working out on 7" rims, I've been a little not paying attention this year.
Old 05-21-2015, 01:36 PM   #397
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I run 245/40/17 RE71's and would advise against running 31 psi on the front. IMO you need at least 34-35 hot and you are still going to roll over to the triangles. In the rear I run 31 and its perfect.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 05-21-2015, 01:48 PM   #398
Biggins
Drives: Yes
I'm running 225/45/17 right now in CS and am nowhere close to the triangles at 31. I had 235/45 RS-3s last year and ran the same pressures. I have needed 3rd gear more this year with the 225s though.
Biggins is offline   Reply With Quote
Old 05-21-2015, 02:11 PM   #399
MTeator
First 86
Are you on concrete?
Old 05-21-2015, 02:33 PM   #400
Biggins
Drives: Yes
Only when I go to Lincoln (or maybe Toledo this year)... all of my local sites are pretty big but all sealed asphalt. The east coast does not do concrete for their parking lots and the airports are too busy.
The Following User Says Thank You to Biggins For This Useful Post:
MTeator (05-21-2015)
Old 05-21-2015, 03:00 PM   #401
MTeator
First 86
Thanks, just understanding what you're running on an adjusting tire pressures for. I'm still on older Rivals but we have Wilmington close and oh so grip. Soon as I wear these out going bridgestones.
My local local lots are sealed asphalt as well.
Old 05-21-2015, 03:01 PM   #402
SeanRTR
C-Street AutoX
SeanRTR's Avatar
31 PSI on concrete 235 45 17, no where near the triangles up front. I may try even lower pressures:
Last weekend Toledo Express, 8th or something on pax, 180 cars
[ame="https://www.youtube.com/watch?v=lutRPBSUbbQ"]Sean Grogan 5 17 15 Nwor express airport Scion Fr-S - YouTube[/ame]
The Following User Says Thank You to SeanRTR For This Useful Post:
Old 05-21-2015, 03:04 PM   #403
Jawnathin
Drives: Toyobaru FRZ
My experience is the same.
Maybe a 235/45 or a wider STX wheel doesn't need as much pressure, but I need 37 PSI up front on my 245/40 7" wheel setup to not rollover past the triangles.
Jawnathin is offline   Reply With Quote
The Following User Says Thank You to Jawnathin For This Useful Post:
Old 05-21-2015, 03:55 PM   #404
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I guess I should have specified that I'm running 225/45/17 on the OEM wheels. It seems like the 245/40 and 225/45 have a non-negligible difference in PSI settings.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
Old 05-21-2015, 06:39 PM   #405
Wheeljack
Wheeljack's Avatar
Drives: 2013 WRB BRZ Limited
Since the weather is getting hotter, where is everyone at on the necessity of a water sprayer on the current crop of tires? I used it on my old Z2s with great effect, but I'm not sure if I need it on the V2 RS3s. I ran rivals on my S2000, and those tires seemed to like heat. Any thoughts on the RE71s or Rival S?
Wheeljack is offline   Reply With Quote
Old 05-21-2015, 10:44 PM   #406
48Spoons
Drives: Ultramarine FR-S
The RE71s do pretty well in the heat, but definitely like being cool in my experince. Ran them with a co-driver at an event and we were double spraying and it made a world of difference. Though don't seem to need as much spraying as the previous ZIIs did. As it warms up more (I'm in NE) we'll see how it goes.
48Spoons is offline   Reply With Quote
The Following User Says Thank You to 48Spoons For This Useful Post:
Model Citizen (05-22-2015)
Areddi's Autocross Video Thread Areddi Mid-Atlantic 130 05-17-2015 06:19 PM
Anyone DD 200 Treadwear Tires? CraftyObeseCrunchyKitty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-09-2015 11:44 AM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
KW V3 autocross set-up thread -max- Tracking / Autocross / HPDE / Drifting 97 10-18-2012 08:02 PM
