Old 04-20-2015, 02:07 PM   #15
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
Originally Posted by niceguy21 View Post
If the fiberglass fleece cured already and have already added a good amount of fiberglass layers underneath the fleece, you can use an orbital sander and try to sand it flat as you can, then use body filler to fill in any pores and imperfections. Once done shoot some primer, sand at 800 to have as flat finish for paint. Shoot paint coats and then cleat coat and should be ready to go.
the fleece is cured already but I don't have any actual fiberglass on it yet. just one layer of resin to keep the fleece in place. Did you put fiberglass on the inside of the enclosure? did you have to work through the speaker hole? That couldn't have been easy...
ハチロク is offline   Reply With Quote
Old 04-20-2015, 02:41 PM   #16
wheelhaus
wheelhaus's Avatar
If you think about it, the first layer is only there to hold a shape. So, you can grind and shape it however you like before/while you add thickness. If you burn through some small areas trying to smooth it out, you can lay some glass to patch over it. If its a larger area, you might need to stretch another piece of fleece. Once you're happy with the shape you can sand down any rough/sharp protrusions. Later in the process once it's built up thicker with glass, you can smooth it out even more, just be cautious to not get too crazy with material removal. You'll be able to see each layer as you grind it away as an indicator of how deep you're going.
If the wrinkles are in an area where it already overlaps the main shell, just sand/grind it away. The fleece doesn't need much overlap on the shell, even 1/2" is plenty to hold the shape until more glass is wrapped around it.
Instead of bondo, you can make a paste with resin and microballoons as a thickener. Using this instead of bondo to smooth the outer wrinkles will create a stronger bond than having a layer of brittle bondo in between layers of glass. Mix it quickly (so it doesn't kick too early) until it has a consistency like frosting.
If you want to add strength inside the enclosure, you can use this thickened resin like caulk around the inside corners where the fleece meets the shell. This isn't quite as strong as fabric, but the microballoons add structure to the resin, and you can smear it around blindly into the corners without having to see everything. Use a mirror on a stick to see what's going on in there. I recommend starting at the farthest, hardest to reach area first, and working toward your opening. (Again this isn't necessary but can help add some strength).
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
IBill4You (04-29-2015), niceguy21 (04-21-2015)
Old 04-29-2015, 11:09 PM   #17
ハチロク
ハチロク's Avatar
Talking Build Update:
I finished fiberglassing and did a test fit in the car. It fits like a glove and I think it looks pretty good. Next step is body filler and sanding, then more body filler and more sanding and so on and so on...
Let me know what you think!
The Following 3 Users Say Thank You to ハチロク For This Useful Post:
Busybee (02-21-2019), IBill4You (04-29-2015), wheelhaus (04-30-2015)
Old 04-29-2015, 11:36 PM   #18
IBill4You
Drives: 2015 Subaru BRZ
Looks great! When can you build mine? Lol
IBill4You is offline   Reply With Quote
Old 04-30-2015, 03:55 AM   #19
labskaus
labskaus's Avatar
Drives: Toyota GT86
poor Woofer ... with some holes in it. You need a Grill
labskaus is offline   Reply With Quote
Old 04-30-2015, 10:45 AM   #20
ハチロク
ハチロク's Avatar
they're not holes. Just dents. and it was free lol can't argue with free.
Old 04-30-2015, 02:40 PM   #21
Fender0122
Drives: 2013 BRZ Limited SWP 6MT
Looks good! I've been wanting to do this in my audi for years.
OVR-SCCA Course Design and SSSI
Fender0122 is offline   Reply With Quote
Old 04-30-2015, 03:24 PM   #22
wheelhaus
wheelhaus's Avatar
Looks great so far!
Old 05-08-2015, 04:26 PM   #23
ハチロク
ハチロク's Avatar
Build Update:
I went a little crazy with the bondo but it looks really smooth now. I'm pretty happy with this for now. The fit is perfect. I was worried layers of fiberglass and bondo might make it not fit quite as well but it still fits.
Here are a couple pictures of the build so far. This is mostly stuff I finished over the weekend but haven't gotten a chance to upload the progress yet. I just ordered some carpeting to cover it but I have to wait for that in the mail so I am sort of stuck for now. My plan is to start working on some wiring and maybe look into plans for an amp.
as you can see from this picture I left the back a bit unfinished but hopefully none of that will show so it won't be a problem. I still put a layer of bondoglass in some of the weak looking areas on the back, that's why its a different color. I also knocked down some of the high spots so at least it slides smoothly.
I do also need to think about a terminal cup. I might have shot myself in the foot by not taking it into consideration earlier but I hope there is a flat enough spot to put one that won't require too much fabrication. I'm thinking I will probably put it on the back in that flat spot towards the right hand side.
Old 05-09-2015, 01:57 PM   #24
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Great work! Fitting a 12 in our trunk is a challenge, and everything is coming out looking professional.
There's no shame in Bondo. You could paint or vinyl it with that smooth of a finish.
Thanks for taking the time to post it up.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
ハチロク (05-09-2015)
Old 05-21-2015, 11:02 AM   #25
ハチロク
ハチロク's Avatar
Build Update:
I'm almost done!!!
here are a couple of pictures of my progress so far. I am working on wiring and installing an amp now and hopefully I'll be able to post the final build after the weekend.
The Following User Says Thank You to ハチロク For This Useful Post:
niceguy21 (05-24-2015)
Old 10-02-2015, 11:17 AM   #26
niceguy21
Socal Valley 86 Member
niceguy21's Avatar
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
I'm almost done!!!
Nice!!! Came out pretty clean. Props to ya!
niceguy21 is offline   Reply With Quote
12", build, enclosure, fiberglass, subwoofer
FR-S / BRZ / GT 86 - Fiberglass Subwoofer Enclosure Prototyping by Integrity Concepts Integrity Concepts Electronics | Audio | NAV | Infotainment 302 11-16-2018 11:47 PM
How do I create a "build thread" link? NWFRS Site Announcements / Questions / Issues 2 02-25-2015 03:14 PM
Meet "Cloud" Errol's FR-S Build Thread RainEG Member's Car Journals 12 08-01-2014 05:18 PM
Vicious LED "BABYLFA" Asphalt FR-S Build Thread! Vicious LED Member's Car Journals 111 01-24-2014 02:20 AM
