Old 05-03-2015, 08:27 AM   #43
stevo585
Drives: White 2014 BRZ
Originally Posted by brznoob View Post
Yes, NX makes E85 specific jets. I'm happy with the kit but the ultimate goal is to make it work with a supercharger. Then I'll run only a 35 shot on E85 probably using a progressive controller to avoid that sudden boost. I'm running E85 so no knocking whatsoever. I ran tests running the kit, no knocking, again I'm only running a 50 shot. I have been running it for 4 months, went through 5 bottles so far.
Thanks, sounds like kit really works well. Does that 50 shot hit pretty hard? calculations say you should have over 3 minutes of spray time per bottle you must really use it alot
stevo585 is offline   Reply With Quote
Old 05-20-2015, 10:50 PM   #44
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
not that hard but you can definitely feel it. It's a small hit
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
brznoob is offline   Reply With Quote
The Following User Says Thank You to brznoob For This Useful Post:
mrk1 (05-21-2015)
Old 05-21-2015, 07:52 AM   #45
mrk1
Drives: Sterling BRZ Ltd
I've been tossing around the idea of a 35 dry shot on my turbo car. I already have Ecutek and larger capacity fuel system so I could trigger a new fuel map to supply the fuel requirements. Boost compounds the shot size so a 35 would be something like a 60 shot normally.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-22-2015, 06:49 PM   #46
dramkissoon
Drives: ft 86 automatic
Brznoob was it easy to install the rpm window switch. Where did u take the rpm signal from?
dramkissoon is offline   Reply With Quote
Old 06-04-2015, 07:13 PM   #47
brznoob
brznoob's Avatar
LOL not really. Truth to be told, I haven't been able to figure it out because my friend's FR-S connections to the ECU are slightly different from mine and his solution didn't work from me.
Old 06-13-2015, 11:35 PM   #48
Zex_Frs
Just another bottled FRS
Zex_Frs's Avatar
Drives: 2014 Scion Frs on Bottle
Sorry to jump in I got mine connected fairly easy you can grab it from the computer inside the car if I get some time later on tomorrow I can check out the exact pin and connector or if you have the diagrams just get the ground output going to the cylinder 1 coil
Just a regular FRS powered by a purple Zex bottle!!!
Zex_Frs is offline   Reply With Quote
Old 06-13-2015, 11:36 PM   #49
Zex_Frs
Zex_Frs's Avatar
Have you try tapping into the ground output going to cylinder 1 coil from the computer
Any nitrous apps yet? 86pro Forced Induction 20 02-07-2014 12:00 PM
Nitrous System for FR-S/BRZ Titanmotorsports Engine, Exhaust, Bolt-Ons 18 04-26-2013 07:30 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 11:02 PM
nitrous eindio Forced Induction 17 09-22-2012 02:09 AM
Supercharged HKS car on nitrous? Lawnik Forced Induction 3 09-04-2012 12:47 AM
