Sam Strano
Old 05-20-2015, 11:15 AM   #3053
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Originally Posted by MTeator View Post
I was a holdout on the pedal dance until I tried it, won't go back.
Pedal dance is not going to fix your ICE mode ABS issue.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
The Following User Says Thank You to SeanRTR For This Useful Post:
TrqlessWonder (05-20-2015)
Old 05-20-2015, 11:36 AM   #3054
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Based on my experience, the pedal dance puts my car into ICE mode everytime I try it. With just the regular long hold of traction control, I never hit ice mode.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 05-20-2015, 03:22 PM   #3055
MTeator
First 86
Interesting, I've only had it go nuts with the 3 second button press. The above poster is having the same thing.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-20-2015, 04:05 PM   #3056
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Just to add to the first post, We can also run with no air filter at all if you choose to do so. I see nobody has edited the first post in a while.
SOLO Rules 13.10.A
"The engine air filter element may be removed or replaced provided the air flow path remains as originally designed (i.e., no additional openings)"
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
86_Insider (05-20-2015)
Old 05-20-2015, 08:10 PM   #3057
TrqlessWonder
Drives: 2014 FR-S
Yeah, but did you ever notice how filthy with dust your car gets when pulling your numbers off after an event? If it can get on a freshly waxed car, it can get in your intake.
In other words: Legal and smart aren't always the same thing.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following 2 Users Say Thank You to TrqlessWonder For This Useful Post:
Laloosh (05-20-2015), NJ10 (05-21-2015)
Old 05-21-2015, 01:29 AM   #3058
ksconekiller
Drives: Subaru BRZ
I've known a few attorneys who proved that...
ksconekiller is offline   Reply With Quote
Old 05-21-2015, 05:38 PM   #3059
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Originally Posted by des View Post
Very helpful. I won't do a build thread, but with such a limited amount of prep allowed, it might help to list the options available for each, and maybe even who has them:
Sway bars:
20mm Cusco (des)
20mm Whiteline (TRev)
It wouldn't hurt to include alignment, tires and wheels in the mix, either.
There's no point in repeating each others' mistakes, right?
I just bought myself a Cusco front 20mm sway bar, because I got a great deal on it. How do you like it?
And yes I'll be buying a matching 16mm for the back too.
sittinSideways is offline   Reply With Quote
Old 05-21-2015, 09:58 PM   #3060
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I don't know if Des still posts here. He's moved onto a Fiesta ST. I've driven his car with the Cusco before and the car felt really good.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
sittinSideways (05-22-2015)
Old 05-22-2015, 11:03 AM   #3061
scirocco78
Drives: Scion FRS
Has anyone shared alignment settings with the TRD setup yet?
scirocco78 is offline   Reply With Quote
Old 05-22-2015, 11:27 AM   #3062
MTeator
First 86
This is where I have mine set
The Following User Says Thank You to MTeator For This Useful Post:
mpicher (05-22-2015)
Old 05-22-2015, 11:37 AM   #3063
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
I managed 2 deg camber both sides in front, 1.9 deg camber both in rear.
Front toe out .05 each side, rear toe in .08 each side.
I've got Koni's, crash bolts and a whiteline front sway (on soft). I've only run one event on a lot I hate. I think I might move to the stiffer setting on the whiteline for the next event... I felt like there was too much oversteer for me with my current setup.
It might be the extra camber I was able to get in this last alignment causing this though and not the springs.
mpicher is offline   Reply With Quote
Old 05-22-2015, 11:49 AM   #3064
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Let me guess, you have the full replacement shocks and not the inserts. So who is going to be the first to say the full replacements are not legal cause their mounting location are clearly off lol
Old 05-22-2015, 12:31 PM   #3065
ButteR
Drives: 2015 Scion FR-S
With trd sway bars, trd springs, koni shocks and oem crash bolts my camber is -2.1 up front and -1.8 in the rear. Wasn't able to get this much camber up front when the car was oem.
ButteR is offline   Reply With Quote
Old 05-22-2015, 12:39 PM   #3066
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Do you also have full replacements instead of the inserts?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
